78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
who made this??
by ted s - 11/16/19 11:41 AM
Drill Bits
by MasterSolenoid - 11/16/19 11:32 AM
2000 Honda Insight Crunchy 1st & 2nd
by Rmay635703 - 11/16/19 09:32 AM
Update Site to VerticalScope Inc board?
by CB900F2 - 11/16/19 09:27 AM
Replace brake clips with each pad change
by Donald - 11/16/19 08:26 AM
HDEO in motorcycles
by kebabaluba - 11/16/19 08:14 AM
More on Cord Cutting - costs going up
by Donald - 11/16/19 07:24 AM
Bosch 3423 C&P
by FordBroncoVWJeta - 11/16/19 05:50 AM
Monroe wouldn’t patch a trailer tire
by dlundblad - 11/16/19 05:06 AM
Ruger Wrangler .22LR
by ZeeOSix - 11/16/19 03:09 AM
aka_Claus, Diverdown, natas, matt3540, ChrisWild
69885 Registered Users
86 registered members (10ecfarmer, 2oldtommy, 77GrandPrix, 14Accent, 92saturnsl2, 1978elcamino, 8 invisible), 2,443 guests, and 19 spiders.
Topics297,507
Posts5,117,035
Members69,885
Most Online3,589
Nov 2nd, 2019
Can I Use Dexron 6 in my 2012 Honda Civic EX-L? #5242340 10/17/19 11:40 AM
K
kelsdawnj Offline OP
K
I’m wanting to change my transmission fluid. I work at a Chevrolet dealer and the only fluid they said they have is the Dexron 6. Is this okay to use?
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5242344 10/17/19 11:47 AM
K
kschachn Offline
K
What does your owner's manual say? Is that a CVT?
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kschachn] #5242346 10/17/19 11:50 AM
B
benhen77 Offline
B
2012s only had 5 speed autos.
2012 Kia Forte EX 2.0 I4 6AT 49k- Valvoline Synpower 5w20
1994 BMW 530i, 5MT 201k M1/Castrol 0w40
2009 Honda Accord 2.4 I4, 5AT, 178k- RP 0w20
2004 BMW X5 4.4l 239k- M1 0W40 FS
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5242374 10/17/19 12:13 PM
J
jeepman3071 Offline
J
I would only use Honda Genuine ATF DW-1 in that car. You can get it cheap enough on Amazon.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5242418 10/17/19 12:41 PM
G
Gebo Online Content
Online Content
G
Nope.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: jeepman3071] #5242498 10/17/19 02:56 PM
T
The_Cams Offline
T
+1 on the Honda ATF DW-1. No way I'd put Dex 6 in that tranny.
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5242516 10/17/19 03:34 PM
R
RyanY Offline
R
I would only put DexVI in the Honda if the oil company recommends it. For example, Pennzoil Platinum LV is DexVI approved but Pennzoil also recommends it for DW1 applications. I have been using it for the past 3 or 4 years in my Odyssey and it works well...and seems to perform a little better than DW1 for towing a trailer (DW1 seemed to break down after a few towing trips whereas the shifts remained smooth with the PPLV). Otherwise DW1 worked fine for normal driving, so I would go this route unless you need a more robust fluid for specific conditions.
2007 Cadillac CTS 3.6L >127k miles (Castrol Magnatec 5W-30 + ACDelco PF2129G)
2012 Honda Odyssey EX-L >103k miles (Pennzoil Platinum 0W-20 + Fram XG7317)
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5242647 10/17/19 06:14 PM
slacktide_bitog Offline
welcome
it *might* work, but you can easily get a good ATF that meets DW1 standards, such as the popular Maxlife ATF. Another very good choice is Castrol Full Synthetic ATF smile
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5243422 10/18/19 01:16 PM
MolaKule Offline
Global Moderator
Global Moderator
I'll alert you to what I posted in another Honda thread:
Quote
If it specs DW-1 and before making a decision I would seriously look at the differences in chemistry between DW-1 and Valvoline MaxLife ATF:
Quote
Original Honda DW-1™ (Part # beginning with 08200-):
Boron - 272
Silicon - 4
Sodium - 3
Calcium - 353
Magnesium - 204
Phosphorus - 2
Zinc – 320
[email protected] – 6.93 cSt
Commentary and Opinion: The chemical signature for this ATF is essentially the same as Honda’s Z-1 fluid and is indicative of fluids used in Automated Manual transmissions. To the author’s knowledge, no Step-Shift ATF chemical signature compares. Notable is the level of the Zinc compounds needed for the internals of Automated Manual transmissions.
Owners’ of Step-Shift automatic transmissions should avoid using this product in any Step-Shift automatic transmission.
Label - Valvoline MaxLife™ (Part # beginning with 773):
Boron - 272
Silicon - 2
Sodium - 8
Calcium - 230
Magnesium - 3
Phosphorus - 579
Zinc – 3
[email protected] – 5.91 cSt
Commentary and Opinion: The chemical signature for this ATF is indicative of the later Dexron and Dex/Merc series of ATF’s based on the original Dexron through the Dexron III(H)) and Dexron VI series of ATF’s. It is closely comparative to the GM Dexron VI formulations as well as to their own Dexron VI offering, and can be classified as a low Viscosity ATF. What is notable is a boost in the Ant-Wear Phosphorus compound of about 200 ppm.
The manufacturer claims coverage, or “Suitable for Use in” (no equivalency claims) for Honda/Acura’s Z-1 and DW-1. I do not see how this could be the case when compared to the DW-1 analysis above.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5169998/three-atfs-analyzed#Post5169998
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Can I Use Dexron 6 in my 2012 Honda Civic EX-L? [Re: kelsdawnj] #5243680 10/18/19 07:18 PM
ctechbob Offline
If you work at a chevy dealer, look up the part number for the fluid on the old Saturn Vue with the Honda Motor/Tans. That should be DW1 in a GM Bottle.
Should be the 2004 Vue with 3.5L engine.
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
