GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
who made this??
by ted s - 11/16/19 11:41 AM
Drill Bits
by MasterSolenoid - 11/16/19 11:32 AM
2000 Honda Insight Crunchy 1st & 2nd
by Rmay635703 - 11/16/19 09:32 AM
Update Site to VerticalScope Inc board?
by CB900F2 - 11/16/19 09:27 AM
Replace brake clips with each pad change
by Donald - 11/16/19 08:26 AM
HDEO in motorcycles
by kebabaluba - 11/16/19 08:14 AM
More on Cord Cutting - costs going up
by Donald - 11/16/19 07:24 AM
Bosch 3423 C&P
by FordBroncoVWJeta - 11/16/19 05:50 AM
Monroe wouldn’t patch a trailer tire
by dlundblad - 11/16/19 05:06 AM
Ruger Wrangler .22LR
by ZeeOSix - 11/16/19 03:09 AM
aka_Claus, Diverdown, natas, matt3540, ChrisWild
69885 Registered Users
92 registered members (2oldtommy, 928, 10ecfarmer, 77GrandPrix, 14Accent, 92saturnsl2, 7 invisible), 2,520 guests, and 23 spiders.
Topics297,508
Posts5,117,045
Members69,885
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Oil Recommendation For A 2012 Tacoma 2.7L #5241124 10/16/19 08:07 AM
cast71 Offline OP
Hi, I wanted to get oil recommendations for a 2012 Tacoma 2.7L with 70,000 miles on it. I did search allot of threads, and got allot of different answers crzy . Some say Toyota went to thin oil, only to boost fuel economy and it will end up ruining your valves and pistons . Others say they used it especially because it has VVTI system and others oil can ruin it. The manual recommends to only use 0W20. I've been using that, since brand new. I change the oil yearly, at about 7000 miles. I use a Toyota factory oil filter. Thanks for any input.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241130 10/16/19 08:11 AM
J
jeepman3071 Offline
J
I don't think running 0w20 in that engine will ruin anything, especially since it is the recommended grade. I think those who claim to have damage from 0w20 have issues related to extended drain intervals or incorrect oil levels instead of the oil viscosity itself. If you run the factory recommended oil and change it at the interval you mentioned I doubt you will have any oil related issues.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241140 10/16/19 08:17 AM
cast71 Offline OP
Thanks for the quick response. I was reading allot of people here, like 0w40. You think that's something I could run, or just stick with 0w20? Also the manual says 5000 mile oil change interval. The dealer did that for the first to changes, than they said, the interval changed to10,000 miles. Is it ok to run the 0w20 and stock Toyota oil filter to 10,000 miles?
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241157 10/16/19 08:30 AM
F
Farnsworth Offline
F
Internet mythology. Go by what Toyota says. In days of yore, 20w 20 was common. I used it in my American Motors straight six, made coast to coast trips in the summer, and the engine ran smooth as glass and consumed no oil. This was on 1960's oil. Toyota is not so dumb to put oil in that increases wear, they know what they are doing.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241162 10/16/19 08:37 AM
Chris142 Offline
We have a 1996 Tacoma with the 2.4 for a shop truck. It gets beat on with minimum maintenance.It's now somewhere around 440K on the original engine,never even had the valve cover off. It usually gets Pep boys Proline 10w40 and whatever filter is cheapest.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241163 10/16/19 08:39 AM
J
jeepman3071 Offline
J
I think 10,000 miles or 1 year is a safe bet if the oil is kept full on most engines out there.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241169 10/16/19 08:43 AM
K
ka9mnx Offline
K
Use the 0w-20 Toyota recommends. You could also use 5w-30. Stay with the 5k oil/filter changes.
Edit: Your yearly/7k OCI interval is fine if recommended by Toyota.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241184 10/16/19 08:55 AM
P
paoester Online Content
Online Content
P
Best to side with Toyota and use 0w20. You can get some of the best 0w20 in Castrol Edge Extended Performance 0w20 or the top Mobil1 Annual Protection one. That Castrol gold bottle actually is good enough to meet Mercedes 229.71 according to Mercedes themselves, a spec tough to meet and proof it is great 0w20.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241187 10/16/19 08:58 AM
H
Hot_Ajax Offline
H
Go with what toyota says. I have an older taco with 300K on it. and no engine work.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241193 10/16/19 09:03 AM
cast71 Offline OP
Thanks for the help guys. Just wanted to make sure. I really like this truck and want to keep it for a long time grin2. I always check my fluid levels, at least once a month. I was changing my oil spring and fall. I thought it was a big waste, because at that OCI, I had about 3,500 miles. So this was the first time, I went to yearly OCI. I'd rather do it at 7,000 , so it ends up yearly in the fall. I'm upstate and don't have a garage,. Changing oil below zero, is not fun LOL. I did find it weird that Toyota changed OCI from 5,000 to 10,000. The manual recommended 5,000 for the four cylinders and 10,000 for the six cylinders. I'm not sure why they should be different OCI's. The dealer said they have a TSB, stating four cylinders are 10,000 OCI's??? I have been following this site, since around 2005. I do understand that oil can go much longer, than the manufacturer recommends.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241204 10/16/19 09:18 AM
T
Tdog02 Offline
T
If you are having no issues then keep doing what your doing. You are in NY so different temps and conditions than what a different driver may have. If you are short tripping your vehicle (you said @7000 miles a year) then consider shortening your oil change interval. In any event, that is a low stress engine that will go 200,000 with routine maintenance.
09 Venza 2.7 104k 5w-30 Magnatec
16 F150 2.7TT 52k 5w-30 Magnatec
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: Tdog02] #5241212 10/16/19 09:23 AM
cast71 Offline OP
I do a mix off short trips and long trips. Most of the milage is long trips though. I do a two hour drive, about 4 times a month. Than about 24 short trip drives a month. So that's about 5000 miles highway and 2000 miles local.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241220 10/16/19 09:34 AM
PimTac Offline
You will be fine with 0w20. Run it with no worries.
That 2.7 is a great motor.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241238 10/16/19 09:51 AM
Delta Offline
Odd, the manual for my '09 is 5K OCI's for both the 4 and 6 cylinders. I know the newer 3.5 is 10K OCI's, but never knew they upped the 4.0. The only changes to the 4.0 in '12 was added emissions equipment. 0w20 will serve you well in your climate and 7K intervals sounds about right. That's what I plan on with mine with the 4.0.
'17 VW GTI 2.0T - 6MT - 18K - Edge 0w40
'15 Camry SE - 2.5 - 25K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 135K - Edge 0w40
Re: Oil Recommendation For A 2012 Tacoma 2.7L [Re: cast71] #5241262 10/16/19 10:22 AM
Dave1027 Offline
Agree with the rest. You'll be fine going with a good 0w20 synthetic. That said, I run a little Rotella T6 5w40 mixed in with the 0w20 in our '18 4runner with the 4.0L which also calls for 0w20. The 4.0L seems to love it.
Page 1 of 3 1 2 3
