Originally Posted by kschachn
Originally Posted by ARB1977
DW1 isn't anything magical. If your worried about it then use the Honda fluid.
Stick to DW1 spec fluid. Valvoline, Amsoil or even Castrol. Ran Valvoline in our 08 CRV with no issues. I may run Amsoil in our 19 Pilot.
I was only pointing out the reality is that no other fluid including Amsoil, Castrol or Valvoline have the ATF DW-1 specification, so if you really wanted to "stick to DW1 spec fluid" as you said there is only one way to do so.
And as far as it being "magical" that's not a technical term I use. However, it is different as MolaKule has shown.
This topic seems to be a difficult one for some certain boutique brand users.
I was referring to any aftermarket fluid that has the DW1 label go with that. There's plenty of aftermarkets out there that fit the bill.
