Alternative to 10w-40 in Rotella?
USA
I like using Rotella oil. Unfortunately, the application I need oil for in this particular case calls for 10w-40. I can't seem to find Rotella in that weight. Any advice on what I should use?
Originally Posted by mechjames
Rotella 5w40 or 15w40
This👆.. don't pigeon hole yourself into a single grade. If you're thinking you need a thicker oil for some reason, go with the 15/40... otherwise a 5w40 will work just as well as a 10w40. Heck, even the 15/40 will be fine depending on what the engine originally calls for.
Btw, Valvoline, NAPA, Castrol, QSAD are all fine 10w40's.
Originally Posted by blupupher
What application requires only 10w-40 and not 5w-40 or 15w-40?
Both the motorcycles in my sig specify 10w-40, that being said I use the 15w-40 Rotella in both of them without issue. Most people don't ride motorcycles below freezing anyways so it's a non issue.
Originally Posted by jakewells
tsc carries 10w40 rotella if you have one near.
Never heard of Rotella 10W-40.
Here in Spain we have Shell Rimula 10W-40, Rimula is Shell's HDEO line outside the USA.
Indeed...Shell Rimula R6 (M or ML)....look at its PDS...with cst of 13.1 @100C it is almost 10w30 in grade...
I would use either "your" Rotella in 5w40 /15w40 or 10w30 flavour...
Originally Posted by dlundblad
Originally Posted by OilReport99
Fuchs Titan Cargo Maxx SAE 10W-40
Kendall GT-1 HP 10W-40
Redline 10W-40
Amazon Basics 10W-40
Castrol GTX 10W-40
And last but not least... Rotella 10W-40
https://www.homedepot.com/p/ROTELLA-128-fl-oz-10W40-Motor-Oil-550019907/204999686
Does an HD around you have Rotella 10w40 in stock?
My bad, sorry. I didn't notice it's discontinued. You can buy in Amazon though...
https://www.amazon.com/Shell-ROTELLA-550019897-10W-40-Synthetic/dp/B00HJWM40G
What application (vehicle/engine) calls for 10W-40 ONLY?
Where do you live? (what weather conditions year-round)
Do you use Rotella T4, T5 or T6?
Need more info to offer advice suggestion ...
