06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Quality filter for 2017 Subaru 2.5 Ltr
by Ishmael - 11/19/19 10:39 AM
Kendall GT-1 Max vs PP
by c5z06 - 11/19/19 10:25 AM
Cubez007, dshadow, Hansvoytek, DeltaP71, 300Kncounting
69918 Registered Users
113 registered members (02vito, 69Torino, 53' Stude, 2oldtommy, 2002 Maxima SE, 12 invisible), 1,938 guests, and 20 spiders.
Topics297,645
Posts5,119,915
Members69,917
Most Online3,589
Nov 2nd, 2019
Quiet Oil--Cause? #5240836 10/15/19 10:05 PM
J
jimbrewer Offline OP
J
Anyway, I've been pleased with the UOAs I get from Motorcraft synblend and the Quicklane service. But I saw jugs of Castrol Edge EP for cheap at WM and I somewhat impulsively bought it. As we all know, products that come in gold colored jugs are the best. Also, I was hoping I could get a solid years' worth of service out of the oil. The MC would be pretty close to failure at 9K. An extra 3-4K would be good.
Anyway, the engine (3.7L Ford) was noticeably quieter with the new oil. I'm about 95% sure it wasn't just my imagination.
What causes this? Does this signify that it's lubricating better? I figure unless it's out and out consumer fraud, the Castrol Edge EP ought to make it to 13K, (although I'll UOA) But what makes an oil 'quiet'?
About 85K on the unit, in good condition.
Re: Quiet Oil--Cause? [Re: jimbrewer] #5240871 10/15/19 11:47 PM
G
geeman789 Offline
G
You never said what grade of oil you were / are using.
A motor oil grade, say xW30, is a range. One 30 grade oil can be thicker than another 30 grade oil. Both are still 30 grades, but one can be on the thin side of the range, the other the thick side of the range. The thicker one can run a little quieter in the engine.
Also, the oil you took out could have thinned out somewhat due to wear / shear / or fuel dilution. The new oil is at the new viscosity spec, and thus thicker, and quieter, for awhile.
And, hot oil is much, much thinner than cool oil. Even oil at room temperature ( 70*F) is way thicker than oil at 212*F. If you compare the engine sound with hot, old oil, then you change it out to new, still cool oil, the new oil is way thicker, and usually quieter, at least until it warms up.
And sometimes IT IS our imagination ... and that's ok. Your engine won't complain about clean, fresh oil !
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Quiet Oil--Cause? [Re: jimbrewer] #5240886 10/16/19 01:36 AM
CharlieBauer Online Content
Online Content
Castrol oils are typically on the thicker side of the range for that grade.
And you're also removing an oil that has thinned even more in use.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Quiet Oil--Cause? [Re: jimbrewer] #5240954 10/16/19 05:36 AM
B
buster Offline
B
Oil and noise depends on a lot of variables - placebo, base oil type, viscosity, additive package, ambient temperature and engine. Your groups I, II and III have better P-V coefficient than PAO's and that could play a role as well. EDGE EP was quiet in my truck, but so was the OE fill. Even quieter is the new Rotella Gas Truck. EDGE became a bit noisier as I put miles on it. Don't know why. Wasn't anything significant though.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Quiet Oil--Cause? [Re: jimbrewer] #5240961 10/16/19 05:46 AM
A
aquariuscsm Offline
A
Does gold bottle Edge contain moly?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Advanced Durability 10W30
Re: Quiet Oil--Cause? [Re: geeman789] #5241152 10/16/19 08:28 AM
P
perfect_oil Offline
P
geeman789,
What makes thicker oil quieter?
Re: Quiet Oil--Cause? [Re: jimbrewer] #5241273 10/16/19 10:29 AM
M
Mad_Hatter Offline
M
Castrol has a unicorn blood in it. It envelopes the valve train in this essentially making metal to metal contact impossible.😂
Ok, seriously...dunno. I've used lubes that, at least to me, seemed to elicit more VT noise...but who knows if that's actually the case and not some psychosomatic effect.
Re: Quiet Oil--Cause? [Re: aquariuscsm] #5241376 10/16/19 12:42 PM
V
volk06 Offline
V
Yes, along with boron and titanium.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Quiet Oil--Cause? [Re: jimbrewer] #5241377 10/16/19 12:43 PM
V
volk06 Offline
V
duplicate
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Quiet Oil--Cause? [Re: jimbrewer] #5241467 10/16/19 02:07 PM
P
paoester Offline
P
Castrol Edge, like Magnatec, probably has some kind of ester to attach to the surfaces. They have claimed a 1.7 dB reduction in sound power in some past marketing materials.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Quiet Oil--Cause? [Re: jimbrewer] #5241473 10/16/19 02:12 PM
N
nthach Online Content
Online Content
N
Castrol Edge has Ti as part of the add pack, Magnatec uses a little ester to cling onto metal. P66 also uses Ti in Kendall and Philips 66 lines with Liquid Titanium.
I haven't seem an VOA of Castrol's oil in a while.
SOPUS and Chevron are fans of moly, and so is Idemitsu.
