Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
Cummins ISX15 OCI
by The Critic - 11/20/19 04:07 PM
It's A Radial Robert
by Yah-Tah-Hey - 11/20/19 04:02 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
118 registered members (addyguy, 4WD, 69Torino, 379KITTY, 2015_PSD, 10 invisible), 1,786 guests, and 23 spiders.
Topics297,698
Posts5,120,900
Members69,924
Most Online3,589
Nov 2nd, 2019
2010 Infiniti G37x Feedback? #5240740 10/15/19 08:30 PM
M
maverickfhs Offline OP
M
Do we have any owners with 2010 Infiniti G37x with some feedback on it? Looking at one with ~120K miles and wanted to get some inputs smile
Oil galleys issue and some electronics gremlins are popping up on 'google', also many people suggest to go above 2010 - is that accurate?
Anything other particular weak spots? Thanks all thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5240805 10/15/19 09:22 PM
JohnnyJohnson Online Content
Online Content
The weak spot I see is they are very popular with the younger crowd and check out Carfax and see how many of them have been wrecked.
2004 Corolla 137003
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5240813 10/15/19 09:32 PM
The Critic Offline
Need 2013 and newer to avoid the oil gallery gasket issue. I’ve done them before, picture of one here:
https://www.bobistheoilguy.com/foru...infiniti-g37-p0011-and-p0524#Post5167562
The rear differential bushing is also a weak spot; most are leaking fluid and need replacing by 100K. We replace them with the whiteline bushing kit instead of replacing the rear subframe.
You can also plan on doing the rear brakes every 30-45K unless you have the Akebono BBK’s.
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5240815 10/15/19 09:33 PM
The Critic Offline
Also, the ones which came equipped with green coolant (most of the 08-10’s) tend to seep externally from the head gaskets. The engines which came with blue coolant do not have this issue. Not sure why.
Re: 2010 Infiniti G37x Feedback? [Re: The Critic] #5240835 10/15/19 10:05 PM
M
M
Thanks for the feedback. It's a sedan and I'll stay away from it, rather run from it!!!
Thanks again thumbsup
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5240840 10/15/19 10:20 PM
The Critic Offline
They only seep and form a crust. The seepage does not evolve into bigger issues. It wouldn’t scare me.
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5240977 10/16/19 06:07 AM
M
MachMarcus Offline
M
Water leaks on cars with sunroofs. Huge design error that allows water into car. Probably the biggest electrical gremlin contributor. Leak comes from sunroof front drains at the firewall connection. Dealers charge big $$ to fix with the repairs failing within a year or so of the repair. Re-route the drain lines and no more issues with smell, electrical, water leaks.
2011 Infiniti G37xs Sedan
2013 Kia Optima Sedan
2003 Lincoln Town Car Sedan
2003 Ford Mustang Mach 1
2002 Ford F150 Harley Davidson S-Crew
1969 Ford Mustang Mach 1 CJ
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5241029 10/16/19 07:01 AM
J
Jimzz Offline
J
I have worked on many of them, my inlaws have a G37x, and I have a Q50s with the same 3.7 motor.
That car is known to cook the trans fluid. So drop the pan, clean, and then put some new fluid in. Takes a special tool as you have to pump it back in through the pan. I did that on my inlaws and then did a drain/fill 10k later.
The valve cover gaskets start to leak around 100-110k on average i have noticed. As long as the spark plugs are not wet then just use a high mileage oil to slow down.
Valley Gaskets, as you and other posted about, are a known issue also. Have not done that job or seen it pop up in the cars I have works on.
Rear brakes ten to wear out a little faster than normal. So keep a eye on those. Cheap and easy to do but still a thing.
Replacing the starter is a pain as it requires moving the driver axle/suspension/sway bar to get it out. Not a common failure part just a FYI from experience.
Other than that they are reliable if taken care of.
yup
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5241070 10/16/19 07:30 AM
M
M
I know maybe I am spoiled by the reliability of current and past Honda cars. Any major repairs like in north of $2K-$3K I'll rather avoid and buy something with at least not expensive known issue.
I'll check out 2011 or higher for G37. Thanks all.
Re: 2010 Infiniti G37x Feedback? [Re: maverickfhs] #5241142 10/16/19 08:18 AM
J
jeepman3071 Offline
J
I would also test drive one extensively. I researched them before buying my BMW, and learned about the issues mentioned above. In the luxury sport sedan category as a whole they rank as being quite reliable, but I hated the few I test drove. The seating position was strangely high, the steering has a numb point right on center which made highway driving a bit "twitchy", and the transmission/throttle input programming was just awful on the 7 speed auto. I was also spoiled because I had driven many BMW 3 series cars before the G37x, so if I hadn't done that my comparison likely would have been different. The VQ does have a wonderful sound, especially with an exhaust.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
