Hey MolaKule -
Thanks for the reply. Yeah, I don't know what AW or friction modifier additives might be in the CO company products might have in them. The company is called Colorado Petroleum. They make a line of conventional products called "Rugged". The Rugged Euro 75W90 is the product I was looking at. They also have a line of synthetics called "Silver State", though it looks like those are only motor oil.
How do you know your Frontier "speced" at 10.5 @100C? Is that info available somewhere from Nissan? Or, did you analyze the OEM Nissan fluid? That info would be very helpful to know. I'm now trying to choose a gear oil for my front/rear DIFFs (LSD in the rear) and the "80W-90" oils are giving me the same issue - huge variance in the viscosity across them. I'm also super confused about what has happened in the market of these gear oils over the past 15 years. Back in the day, you just bought a 75W-90 GL4 for the trans, a 75W-90 or 80W-90 for the front DIFF and and the same with LSD additive in it already for the rear.
Now, it seams like it's really hard to find a conventional one at all. It appears the synthetics have the LSD friction modifier "in them already", however people are saying it's not enough for LSD DIFF's anyway and should only be used to "top off" the DIFFs if necessary. Plus, it makes me wonder if the FRONT DIFFs are better suited without those additives in them. Nobody seems to be asking that question either.
I'm hoping to choose a DIFF oil that can be applied to both the FRONT and REAR DIFF's on all my Xterras/Frontiers, as I plan to build many more of them (I have a small business restoring them). After looking through the various data sheets on the various 80W-90's, I'm seeing kinematic viscosity all over the map.
I'd love to know what Nissan "speced" these transmissions and differentials at for their respective oils. I noticed the 2000-2001 Factory Service Manual for the Nissan Xterra and Frontier, they had a footnote suggesting the "Standard Differential Gear" could also apply the SAE Viscosity Graph to adjust for geographic climate /temperature, suggesting the colder temp areas could even use a 75W-90 in the DIIFs. I'm guessing the "Standard Gear Differentials" are the non-LSD DIFFs, which could mean all the front DIFFs and any non-LSD rear DIFFs (if there were any). It's also known that the 200-2001 Xterras/Frontier rear DIFFs had LSD with much higher break-away-torque figures (138-180 lb-ft), compared with the 2002+ (at 29-43 lb-ft). Perhaps that's why the manual suggested you could get away with the 75W-90 in the cold??
It seems the more I investigate this, the more I have questions.
