06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Quality filter for 2017 Subaru 2.5 Ltr
by Ishmael - 11/19/19 10:39 AM
Kendall GT-1 Max vs PP
by c5z06 - 11/19/19 10:25 AM
dshadow, Hansvoytek, DeltaP71, 300Kncounting, Bill67
69917 Registered Users
110 registered members (2009Edge, 2oldtommy, 69Torino, 53' Stude, A310, 8 invisible), 2,004 guests, and 21 spiders.
Topics297,645
Posts5,119,891
Members69,917
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Pennzoil Ultra 5W-30, 4K miles, 2016 Ford 3.5L EcoBoost [Re: ZiTS] #5237307 10/11/19 05:19 PM
P
paoester Offline
P
Viscosity dropped too low for your tune and mods, especially. I'd use Shell Rotella T6 Multi-Vehicle 5W-30 to counteract the fuel dilution and maintain wear protection better. It also has strong dispersant for DI turbo carbon soot. Walmart can get that for pickup at the store from their website.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Pennzoil Ultra 5W-30, 4K miles, 2016 Ford 3.5L EcoBoost [Re: ZiTS] #5237365 10/11/19 06:43 PM
Z
ZiTS Offline OP
Z
Mods I've done along with the tune include K&N panel filter in stock airbox, 170* thermostat, heat range colder spark plugs, MSD ignition coil packs, and 3-BAR MAP sensor, along with a catted down-pipe and catback exhaust system. All of these were done during probably the last 1,000 miles or so of the oil life, and they're pretty much the most common mods in the SHO world.
Interesting comment about the viscosity and changing oils. I may look into that. Thanks
Re: Pennzoil Ultra 5W-30, 4K miles, 2016 Ford 3.5L EcoBoost [Re: ZiTS] #5239590 10/14/19 05:15 PM
I
Impatient Offline
I
It would be interesting to see what an Amsoil/Polaris UOA would say about your fuel dilution. If still around 1-2%, you’re one of the lucky EB owners; they use GC to measure, not “estimate” based on flash, or however BS “measures.” I had low visc with Pennzoil too.. 8.2 at 6k, a bit higher (8.4) at 1k into next fill. And a tad of Ti, and a tad of Potassium. Tad = 1 ppm. It appears to me, Pennzoil Plat & Ultra VOA’s show they start out with less visc than they claim, and then shear down after that...or maybe it’s fuel dilution not true “shear,” dunno. I will look for a Rotella UOA in an EB, but the advice to try Rotella Multi-vehicle, or Gas Truck is worth investigating. You don’t think your SHO would be offended by using something called Gas Truck, do you? Somewhere in BITOG there is a chart showing Pennzoil, Rotella, QSUD virgin spec comparison.
15 Ford Transit 250 3.5EB Turbo PPPUP 5w30
07 Subaru OBXT 2.5 Turbo Castrol Euro 0w30
Re: Pennzoil Ultra 5W-30, 4K miles, 2016 Ford 3.5L EcoBoost [Re: ZiTS] #5239658 10/14/19 06:21 PM
Z
ZiTS Offline OP
Z
Definitely considering the Rotella, but curious to think what everybody's thoughts are on using Mobil 1 Extended Performance? I'm still not going to go past 4,000 mile OCI's. The Mobil 1 EP seems like it is also a very stout oil that would hold up well in my application.
Z-
Page 2 of 2 1 2
