Originally Posted by Quattro Pete
Originally Posted by Wolf359
In terms of warranty if you pick up an MB, they come with a 4 year/50k warranty and if you get a CPO warranty, they go up to 7 years, unlimited miles. If you pick up a private party use one that still has the original warranty left, you can go up to 7 years/100k on the MB warranty, just have to check with the dealer to make sure it's still eligible.
CPO warranty is 5 years, not 7.
Quote
Every Certified Pre-Owned Mercedes-Benz is covered by any remaining portion of the Mercedes-Benz four-year/50,000 mile New Vehicle Limited Warranty. Then, the CPO Limited Warranty provides comprehensive coverage for another 12 months with unlimited miles.
This means up to 5 years of unlimited mileage coverage, extending to the engine and powertrain, steering, suspension, brakes (excluding wear of discs and pads), electrical system, climate control system, and more.
https://www.mbusa.com/en/cpo
CPO cars come with 1 year unlimited miles, but you can buy up to 2 extra years of CPO coverage. Same with the extended warranty, up to 7/100k. That goes with the 4/50k new car warranty. Of course extended and CPO isn't as good as factory warranty because there were a few things that it didn't cover like ripped MB-Tex seat and faded wood trim which was an early problem with the W212 which was the 2010-2013 E-350.
https://mbworld.org/forums/extended...-best-discount-mb-extended-warranty.html
Oh yeah, I've also replaced the alternator on one of the cars, it's about $185 from Autozone. They carry a reman Bosch unit which was OEM and it comes with a lifetime warranty. That might be a little bit more than what I paid for my previous Taurus, that car I think I replaced the alternator 3 times. That car was really difficult to remove, the book had you dropping the subframe to remove the alternator, but if you fliped it around, it would come out the wheel well. The Mercedes wasn't as bad. MB also likes to use Torx and external Torx bolts. So far working on it hasn't been as bad.
