Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
135 registered members (ammolab, askani79705, 69GTX, 2010Civic, Astro14, 01rangerxl, 11 invisible), 1,937 guests, and 18 spiders.
Topics297,608
Posts5,119,119
Members69,908
Most Online3,589
Nov 2nd, 2019
Powerstop Brake kits #5239457 10/14/19 02:00 PM
R
RhondaHonda Offline OP
R
My wife’s 2017 Yukon XL is due for brakes and since I have plenty of free time on my hands I will be doing them myself.
Rockauto has Powerstop front and rear kits that include pads and rotors. The standard kit is $145 and the Evolution geomet coated rotor kit is $232. Centric also has a kit for $235.
Are the coated rotors a necessity? I’m looking for a stock type replacement. No squeaks or excessive dust and I don’t need slotted/drilled/dimpled rotors. Any concerns with the cheaper Powerstop kit? Thanks.
Re: Powerstop Brake kits [Re: RhondaHonda] #5239500 10/14/19 03:03 PM
P
Pew Offline
P
Coated rotors won't last more than the first few passes. The hubs might last a bit longer before rusting but that's about it.
Re: Powerstop Brake kits [Re: RhondaHonda] #5239525 10/14/19 03:45 PM
J
JMJNet Offline
J
Is the rotor worn out? It is a 2017?
  • 2017 Toyota Sienna
Re: Powerstop Brake kits [Re: RhondaHonda] #5239537 10/14/19 04:09 PM
R
R
It’s got 50k on it and the pedal pulses like mad when coming to a stop from highway speed. The cost of new rotors makes machining them not worth the hassle.
Re: Powerstop Brake kits [Re: RhondaHonda] #5239576 10/14/19 04:59 PM
B
benjy Offline
B
like most rotors today they are prolly chinese castings, for better but not cheaper EBC's higher carbon UK castings + brake pads from the USA. braking is a place to get better not cheaper IMO.
Re: Powerstop Brake kits [Re: RhondaHonda] #5239677 10/14/19 06:36 PM
A
andyd Offline
A
A 2 yr old trucklet with 50K shouldn't need much more than a pad slap and a system flush. Pulsing pedal is like pad transfer . There should be obvious signs of warping and damage if the rotor is bad. heavy sand paper or a knotted wire wheel will scrub off old pad residue. Disk brakes are nothing to be scared about. Once a good pedal is achieved the most likely failure mode is a seizure. It is a PITN to deal with but not dangerous, Sudden LOSS of brakes is a non issue in a car less than 20 yrs old. grin2
Thick oil is better grin2
Re: Powerstop Brake kits [Re: RhondaHonda] #5239701 10/14/19 06:58 PM
J
JustinH Offline
J
amazon sells the powerstop kit. I ordered a solid rotor kit with pads for my sonata, and they sent a drilled and slotted kit.
Not bad for 79 dollars, I'm happy with it.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: Powerstop Brake kits [Re: RhondaHonda] #5239705 10/14/19 07:02 PM
rooflessVW Offline
Had the Z23 kit on my X3. Decent parts.
"Zed's dead baby, Zed's dead."
Re: Powerstop Brake kits [Re: RhondaHonda] #5240107 10/15/19 09:52 AM
G
GMBoy Offline
G
I have used both the powerstop and Centric kits off Rockauto - good value and I recommend them.
Re: Powerstop Brake kits [Re: RhondaHonda] #5241686 10/16/19 06:05 PM
R
R
I’ll try cleaning the rotors to remove any old pad material first and see if that does anything.
Re: Powerstop Brake kits [Re: RhondaHonda] #5241697 10/16/19 06:24 PM
G
gonefishin Offline
G
I put the Z23 Evolution front rotors/pads on my '15 Cadillac about 1 1/2 years ago. No regrets. All positive things to say about the package.
2015 Cadillac SRX
2014 BMW 528i
2007 Nissan Altima 2.5l
2004 Chevrolet Trailblazer 4.2l
