2001 Toyota Sequoia
by Tlhfirelion - 11/14/19 11:02 AM
Creation date
by Duffyjr - 11/14/19 10:36 AM
Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
contraption22, Caydel, Bull58, Koncrete_Cam, DirtyTony
69863 Registered Users
96 registered members (aquariuscsm, 69Torino, bdcardinal, bigal51, atikovi, 10 invisible), 2,455 guests, and 30 spiders.
Topics297,407
Posts5,114,779
Members69,863
Most Online3,589
Nov 2nd, 2019
Maxlife ATF #5239432 10/14/19 01:18 PM
charmer37 Offline OP
Hello, Anyone ever tried maxlife synthetic Atf in a BMW 6HP transmission? I know it works in the older 5HP transmissions but I don’t hear much about people using it in the 6 speed automatic transmissions....Thanks
Re: Maxlife ATF [Re: charmer37] #5239436 10/14/19 01:27 PM
blupupher Offline
What is the spec'ed fluid for it?
5k OCI: '18 Santa Fe: PP 10W-30/OEM, '18 Soul: Mobil Super 5W-20/OEM
1yr OCI: '12 xB: M1 EP 0W-20/CQ Blue, '02 F150: Magnatec 5W-20/Bosch D+, '94 VT1100: Peak 15W-40/Bosch D+
Re: Maxlife ATF [Re: charmer37] #5239448 10/14/19 01:43 PM
The spec is: Shell M1375.4. and ZF Lifeguard 6 is the approved fluid for the ZF 6HP transmissions.
Re: Maxlife ATF [Re: charmer37] #5239463 10/14/19 02:17 PM
SubieRubyRoo Offline
I'm not sure (don't own a Beemer or ZF trans) but I seem to recall there was a thread about something very similar and it said there were special things in the ZF fluid that were not present in the MaxLife, and henceforth made it a bad idea. I'd double and triple check your info before doing it, likely not a cheap fix if its something caused by the fluid and you're left picking up the repair bill.
Re: Maxlife ATF [Re: charmer37] #5239464 10/14/19 02:18 PM
blupupher Offline
Maxlife has that spec on their MaxLife ATF PDS, so I would say it is safe to use.
No I have not used it in that specific application, but have used it in multiple other vehicles that have the spec listed without issue, as have many here (and sure millions in the real world).
Re: Maxlife ATF [Re: charmer37] #5239474 10/14/19 02:30 PM
Thanks for the info.
Re: Maxlife ATF [Re: charmer37] #5239695 10/14/19 06:55 PM
W
working_title Offline
W
I have a 6HP (2010 135i) and had a heck of a time trying to find a decently priced compatible fluid for the car. I ended up using Pentosin ATF-1 (part # 1058206), which so far has worked just fine with no issues. I have about 15,000 miles on the fluid at this point. http://www.pentosin.net/specsheets/Pentosin_ATF1.pdf
Pentosin ATF-1 lists ZF No. 5671 090 255 under "OE REFERENCE NUMBERS/RECOMMENDATIONS" which happens to be Lifeguard 6.
'15 F150 3.5 Ecoboost Havoline Pro DS 5w-30
'13 335iX (N55) Castrol 0w-40
'10 135i (N54) Castrol 0w-40
Re: Maxlife ATF [Re: working_title] #5239713 10/14/19 07:11 PM
Pentosin is another good Atf alternative for 6HP transmissions, A lot of guys that have Bmw”s, Jaguars and Land Rovers is also using Ford Motorcraft Mercon SP in there ZF 6 speed transmissions, It’s a few more dollars than Maxlife Atf.
Re: Maxlife ATF [Re: charmer37] #5239946 10/15/19 07:02 AM
B
BMWTurboDzl Offline
B
MERCON SP is another option.
435i
