5 and 10 30 valvoline conv 1.49 a qt at TS
by Chesterr - 04/04/20 02:34 AM
Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
23 registered members (bachman, dishdude, blufeb95, cjolson140, Chesterr, Danimal1q2w3), 1,186 guests, and 17 spiders.
Topics303,559
Posts5,237,373
Members71,086
Amsoil SVG 75W-140-Ford PTU #5238449 10/13/19 11:37 AM
W
Whimsey Offline OP
W
My wife bought a new 2017 Explorer in Feb 2017. Afterwards I started reading and seeing videos of the PTU and it's abuse of the gear oil. This appears to be because the PTU only holds ~13-18 oz of 75W-140 gear oil and is surrounded by major heat sources, especially in the 3.5 EB. Of course Ford says it's a "lifetime fluid" and not to change it crzy. Plus it's a real challenge to change it in the 3.5 V-6, no drain plug. Luckily our Explorer is the 2.3 EB and the PTU holds 23.7 oz and has a drain plug. In addition being a 4 cylinder it's subject to less heat exposure. I had the dealer drain and fill it at 9,000 miles and I had it done again at 22,000 miles with Amsoil Severe Gear 75W-140. This was run for 22,435 miles and changed again with the Amsoil. I did an UOA to see how the fluid held up and whether I can run it more miles. I asked Blackstone about going 35,000 miles on the next change of Amsoil. They thought that would be fine. Comments are welcomed.
Whimsey
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5238468 10/13/19 12:27 PM
08z06 Offline
good stuff. thanks
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5238518 10/13/19 01:35 PM
4WD Offline
Seems to be working.
Something I found to be weak: In my 2015 owners manual you'd find this 150k nonsense. But Ford had buried severe service in another part of the manual - and now only 30k.
That's one heck of a spread to start with and not even side by side on the same chart.
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5238597 10/13/19 03:46 PM
bdcardinal Offline
I had the fluid changed in my mom's Fusion earlier this week. The car had jsut over 40K miles and the factory fill came out pretty dark and thin. I had the tech doing the oil change put Amsoil back in. I will probably change it out again at 60K. I still need to do a drain and fill on the transmission.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5238629 10/13/19 04:48 PM
Rat407 Offline
Here is my 2002 Silverado UOA on the rear diff fluid using AMSOIL's Severe Gear 75w-90.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Amsoil SVG 75W-140-Ford PTU [Re: bdcardinal] #5238667 10/13/19 05:48 PM
W
Whimsey Offline OP
W
It's amazing for a Ford "lifetime fluid" how short the lifetime is. Hopefully your Fusion has the same larger capacity PTU with the drain plug. Will this be your first drain of the factory fill ATF? I have the 6F35 in the Explorer and did a d&f of the ff at 12,000 miles, it was nasty black. I did it again at 22,000 miles and it was dark grey with a hint of dark red. I did it once again at 32,000 miles and it was more dark red with a strong hint of grey. I'm at 50,000 miles now and will change it within the next week. The Explorer is a heavy vehicle and the 6F35 is a light duty car transmission, not a good combination for a long life if neglected. I've been using Mercon LV for my drain & fills but I now I have 12 qts of Castrol Transmax Full Synthetic Multi-Vehicle ATF which is licensed by Ford for vehicles using Mercon LV. It'll be interesting how this last fill of Mercon LV looks like at 18,000 miles of use.
Whimsey
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5238957 10/13/19 11:46 PM
bdcardinal Offline
The factory ATF was drained when a leak was discovered at 7K miles. The side cover was leaking so it was fixed under warranty and the fluid changed out.
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5239152 10/14/19 08:42 AM
W
Whimsey Offline OP
W
[Linked Image]
One of our kind members let me know my black out job of my info was not so swift so I re did it.
Whimsey
Re: Amsoil SVG 75W-140-Ford PTU [Re: bdcardinal] #5239160 10/14/19 08:49 AM
W
Whimsey Offline OP
W
Speaking of leaks, the front engine/timing cover was fixed at 40,000 miles for leaking. I was having the tires replaced last week and at 49,000 miles I noticed the cover is leaking again shocked2.
Whimsey
Re: Amsoil SVG 75W-140-Ford PTU [Re: Whimsey] #5334619 01/28/20 12:39 PM
M
metroplex Offline
M
Whimsey: The problem is with the PTU's used on the 3.5/3.7 V6 Explorer/Edge/Taurus, not the 2.0/2.3, so basically your PTU is not going to run into the same overheat problems because it is a different design. The Fusion Sport 2.7L EcoBoost uses a different PTU as well and has a water cooling system with drain and fill plugs. Still, this was interesting to read, thanks for submitting the UOA!
