Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
97 registered members (alarmguy, 14Accent, alchargo, 2015_PSD, 4WD, 10 invisible), 2,374 guests, and 22 spiders.
Topics297,402
Posts5,114,712
Members69,856
Most Online3,589
Nov 2nd, 2019
Non-DPF engine oil in Diesel BMW F10 #5239011 10/14/19 03:00 AM
L
L93013 Offline OP
L
Hi, I have BMW f10 525d 2013 make with 65k KM on it, I have done engine oil change diy for the first time,
I brought 5.5 ltrs of Castrol Edge 5-W-40 for it. I have two queries regarding oil change I did.
The Castrol jugs that I brought were of BMW long-lige-01 spec, but I have heard that BMW recommends long-life-04 spec oil for diesel engine cars, but the problem is that no long-life-04 spec engine oil is available in my city
should I be worried running non-DPF oil in Diesel BMW 525?
The second query is that I brought three jugs of Castrol Edge 5-W-40, one of 3.5 ltr and two of 1 ltrs (since no packing of 5.25 ltrs was available)
3.5 ltr jug was labeled "5W40 A3/B4" and 2x 1 ltrs was labeled "5W40 SN"
are A3/B4 & SN same thing?
anything else you guys would like to recommend to a newbie that should be kept in mind while doing an oil change?
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5239032 10/14/19 04:29 AM
rooflessVW Online Content
Online Content
At a minimum you want an ACEA C3 / API CK-4 oil.
"Zed's dead baby, Zed's dead."
Re: Non-DPF engine oil in Diesel BMW F10 [Re: rooflessVW] #5239047 10/14/19 05:12 AM
B
BMWTurboDzl Offline
B
+1
ACEA C3 for sure. In addition these oils will very likely have Mercedes Benz 229.51 / VW 504/507 / Porsche C30
435i
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5239198 10/14/19 08:51 AM
B
Boomer Offline
B
Clearly the one on the left says "Not suitable for vehicles fitted with with diesel particulate filters" in the red band!!!
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Non-DPF engine oil in Diesel BMW F10 [Re: BMWTurboDzl] #5241940 10/17/19 03:57 AM
K
Kamele0N Offline
K
+1
This...or BMW LL-04 spec! These are all "DPF friendly" specs!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5242900 10/18/19 03:58 AM
L
L93013 Offline OP
L
Thank you guys for all your responses & pardon me, I am new to this whole car maintenance scene so I am learning about how components work in car,
I am trying to find that how long can I run this oil in my engine before problem can occur? What type of problem could occur using LL01 engine oil in DPF equipped car? Should I change the engine oil before driving further or I can drive the car for few thousand miles? is there anyway to find out this by checking DPF state or any other method?
Thanks
PS: can someone recommend me source like book or videos to understand the working of modern car?
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5243028 10/18/19 06:54 AM
B
BMWTurboDzl Offline
B
Thanks
You should change the oil as soon as possible. Your DPF has a fixed service life and using LL01 will reduce the service life by some amount. How much, entirely depends on your driving conditions and miles driven. If I remember correctly there is software which you can hook up to your vehicle to determine the remaining life of your DPF and force the vehicle to regen* the DPF.
*Regeneration: The DPF loads up with soot after a certain amount of miles and once the pressure differential reaches a certain point fuel will be injected into the exhaust stream to burn off this soot. After burn off some ash remains behind. Oil additives are a component of this ash and it's why you want to use LL04 because they leave less ash behind than LL01.
If you want videos I would just search YouTube.
435i
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5243827 10/19/19 01:00 AM
K
Kamele0N Offline
K
Change your FULL saps oil ASAP....you will block your DPF soon...
Full saps oils produce more ash when they get burnt...and that ash will block your DPF...moreover ash from FULL saps oils is different then that from mid/low saps oils....it can not be burnt that easily as one from oils wich are intended for DPF equiped cars...
Get the oil with specs mentioned above....in reality it doesnt really matter if spec come from MB or VW or BMW as long as it is "DPF friendly"
Change your oil in dependency how clean/eco (Sulfur levels!) is your diesel fuel there...
If you have sulphur free diesel go aprox 10-15kkms...if not split that interval by half...
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5246646 10/22/19 02:03 AM
P
Parikshith Offline
P
As others have suggested, please move to an LL-04 oil.
Here are a few options on Amazon india.
Liqui Moly TopTec 4100 5w40 - https://www.amazon.in/Liqui-Moly-9511-Synthetic-Petrol/dp/B00VP51BIE/
Liqui Moly TopTec 4200 5w30 - https://www.amazon.in/Liqui-Moly-5W-30-Synthetic-Motor/dp/B00CPL8R8O/
Mobil 1 ESP 5W30 - https://www.amazon.in/Mobil-5W-30-F...obil+1+esp&qid=1571731136&sr=8-1
Amsoil Synthetic 5W-40 I-ESP Euro Oil - https://www.amazon.in/Amsoil-Synthetic-5W-40-I-ESP-Euro/dp/B00BSQIEEE
Motul also have an oil in India that is BMW LL-04 rated. Its called 8100 X-clean. Please reach out to Motul via their Indian page, the are prompt in responding with the local dealer for your city.
Re: Non-DPF engine oil in Diesel BMW F10 [Re: Parikshith] #5246755 10/22/19 07:10 AM
K
kschachn Online Content
Online Content
K
Not all the oils in your list have BMW Longlife-04 approval. "Rated" is not the same as approved.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: Non-DPF engine oil in Diesel BMW F10 [Re: Kamele0N] #5247121 10/22/19 01:23 PM
K
Kamele0N Offline
K
hide
Re: Non-DPF engine oil in Diesel BMW F10 [Re: L93013] #5247618 10/22/19 10:09 PM
E
edyvw Offline
E
Thanks
The car will not explode or DPF will not clog fast. You should change it as soon as possible, but running full-SAPS oil does not mean DPF will clog, it means if you run that oil constantly, DPF lifespan will be cut short.
As many mentioned, you want ACEA C3, BMW LL04 and in addition to that look that oil also carries VW 504.00/507.00 and MB 229.51.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
