"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
AGM vs Traditional Battery
by jayjr1105 - 11/13/19 06:07 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
84 registered members (alarmguy, ArrestMeRedZ, 4WD, Andrei, 53' Stude, 7 invisible), 2,002 guests, and 16 spiders.
Topics297,389
Posts5,114,517
Members69,856
Most Online3,589
Nov 2nd, 2019
2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI #5238942 10/13/19 10:19 PM
Spetz Offline OP
Hi everyone,
I had a UOA done on my 165,000m Mitsubishi Diamante.
7,7xx miles on this oil which was Shell Helix Ultra 5W40 and a half can of Liquimoly MoS2.
My last UOA on this car (same oil, no MoS2 though):
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4900608/2003-diamante-shu-5w40-6817m-oci
The car is used on short to medium trips most of the time.
I towed a heavy load for about 1,000miles in this OCI (roughly 3,500lb load).
1. There is much more nitration, oxidation and sulphation this time around - Could this be the MoS2 additive?
2. Wear metals went down slightly though this oil has about 1,000 miles more than the last UOA, though tin is up.
3. My fuel dilution is high (I believe that is percentage) even though this sample was taken after towing for 150 miles straight. Could this be from blowby?
4. Some numbers (soot, TBN) look like they weren't tested? Though other items not tested have N/A next to them.
Comments greatly appreciated!
Code
Lead 		41
Iron 		11
Aluminum	5
Copper		7
Chromium	0
Tin		4
Nickel		0
Silicon		31
Sodium		5
Magnesium	21
Zinc		112
Molybdenum	262
Calcium		2624
Phosphorus	858
Boron		64
TBN		0
Soot		0
Glycol		0
Water		0
Fuel Dilution	5 (% or ppm???)
Oxidation	23
Nitration	41
Sulphation	29
TAN		0
f.debrus (mg fe/l)	1
Viscosity @100 C	0
Viscosity @40 C 	88
2003 Mitsubishi Diamante 6G74. 165k miles.
Penrite HPR10 10W50, 12K km OCI
UOA:
https://www.bobistheoilguy.com/foru...ante-shu-5w40-1-2-can-mos2-7-8k-mile-oci
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239005 10/14/19 02:45 AM
demarpaint Offline
I'm far from an expert but Lead and Silicon stand out to me. I'd be checking the air filter assembly for sure, and the plumbing associated with it for unfiltered air entering the engine.
Not sure what the answer is for #4 regarding if they did the testing or not, I'd confirm with the lab. Fuel Dilution? Not sure. Subscribed for the expert analysis.
God Bless Our Troops
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239199 10/14/19 08:52 AM
T
Trav Offline
T
Wear has not benefited from the MoS2, either something wiped the zinc out or its a mistake. If this car see the track go with a heavier oil 20w50?
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239423 10/14/19 01:11 PM
M
Mad_Hatter Offline
M
Something's screwy here to me..is this Shell Helix Ultra 5/40 you're using rated API SN???
- where'd the zinc go?
- where'd the Mag go?
- 2600+ppm Cal doesn't jive with VOA's I've seen on Shell Helix Ultra 5w40. (1200/900ppm cal/mag respectively)
- where'd the boron go? (recent voa shows +200ppm boron)
- it's interesting that your previous run of Shell Helix 5w40 showed a TBN of 10.3 after a nearly 7k mile run.. that's a full point above the virgin TBN of 9.3. So the reserve alkalinity went UP after a 7k mile run, how's that?🤔
VOA Shell Helix Ultra 5w40 - 9/2019
(either this voa is off or your uoa is)
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Mad_Hatter] #5239617 10/14/19 05:48 PM
Spetz Offline OP
This is the daily driver which tows the track car for about 1,000 miles per OCI.
Most trips are relatively short (within 10 miles).
It takes the occasional longer trip (100+ miles).
This is a 2017 bottle of SHU I used, in Australia. Not sure of this is different to other areas?
I too questioned some of the results though (specifically TBN and fuel dilution) but cannot confirm in any way.
When I took the sample though the oil did not smell like petrol, and it was after a long 150 mile trip of towing a heavy load.
I will be changing oils and using something thicker too.
Likely the local Penrite oil, 15W50 as it is currently on special and pretty cheap.
UOA:
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: demarpaint] #5239660 10/14/19 06:24 PM
J
JAG Offline
J
+1
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239691 10/14/19 06:47 PM
PimTac Offline
Can the company retest your sample? Some will hang on to the samples for a while just in case a retest is requested. As for the TBN you will have to verify if those tests are included. Some companies charge extra for TBN/TAN.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239732 10/14/19 07:31 PM
M
Mad_Hatter Offline
M
With all the highway driving you're doing I wouldn't expect a lot of fuel dilution, that is unless you have loose rings which case all bets are off.
Yeah dunno about the regional thing? The VOA I linked to is from Russia and it's even different than your UOA. It (the VOA) looks more like a API SN rated lube.
But I can't say that I've ever seen an oil analysis with zinc that low. I guess it's possible, it's not like I've seen every UOA ever done 😂.. and you do have some relatively high wear metals, so maybe it depleted?🤔
Me personally.. I'd send off another sample of that oil to a different lab (if you still have some laying around) or ask it to be retested. While you're at it ask them if they have reference values for TBN on this lube... I'd be curious to how that stacks up to your prior UOA.
Re: 2003 Diamante, SHU 5W40 + 1/2 can MoS2, 7.8k mile OCI [Re: Spetz] #5239815 10/14/19 10:16 PM
Spetz Offline OP
I have done a smoke test to find leaks past the air filter previously but everything seemed fine.
I have also purchased a new (and better quality) air filter in response to the high silicon ratings.
Yet that remains high (albeit lower than the 1st UOA).
I will be using a different oil and the next UOA I will be sending off to a different lab just in case.
As far as TBN, the previous UOA showed a fairly high TBN so 0 is surprising. Likely not tested or something (though it should have been included in the testing).
UOA:
