You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
102 registered members (Andrei, 4WD, 1foxracing, alchargo, Alfred_B, alarmguy, 8 invisible), 2,243 guests, and 18 spiders.
Topics297,396
Posts5,114,659
Members69,856
Most Online3,589
Nov 2nd, 2019
Oil recommendation for my flat tappet cam? #5238884 10/13/19 09:02 PM
F
fusseli Offline OP
F
She's beautiful, isn't she? Specified for API SF. How can I keep those cam lobes intact. I've researched ad nauseum and the answer keeps changing over the last few years.
I've ran in the last 7 years:
Mobile 1 HM 10w40
Quaker Defy 10w40
Rotella T6 5w40 -- recently reformulated, not sure if I should use it again...
2019 Ford Ranger 2.3L Turbo
1984 Ford Thunderbird 2.3L Turbo
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238891 10/13/19 09:21 PM
O
oldhp Offline
O
PP 10W30
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238901 10/13/19 09:34 PM
Capt Offline
Seems like a decent amount of zinc and phosphorus is the common hero for those flats tappets.
http://pqiadata.org/NAPA_15W40.html
http://pqiadata.org/Valvoline_15W40.html
http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
http://pqiadata.org/Motorcraft_15W40.html
^Here are a few decent newer formulas (CK4) 1000+ zinc and phos
It seems that most house brands also have a add pack similiar to those listed above.
There's also that VR1 Valvoline High Zinc 10w-30 or 20w-50
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238904 10/13/19 09:40 PM
SteveG4 Offline
I would give one of these a whirl:
AMS Oil -- Designed for flat-tappet engines:
https://www.amsoil.com/shop/by-prod...n-10w-40-synthetic-motor-oil/?zo=1206638
Schaeffer's -- Extra zinc to protect flat tappet cam engines and other components from wear:
https://www.schaefferoil.com/7000-race-oil.html
Royal Purple -- Yes. For stock, non-performance valve trains, Royal Purple API-licensed oils (API SN and ILSAC GF-5 licensed) are OK.
For upgraded performance flat tappet camshafts, and vintage high performance engines, we recommend our HPS or XPR engine oils.
For a specific recommendation, contact our tech department at 888-382-6300.
Valvoline VR1 racing oils:
- ZDDP additive provides tough anti-wear protection.
- Enhanced with friction modifier to improve horsepower.
https://sharena21.springcm.com/Publ...bd3/a61538b4-0cbd-e711-9c12-ac162d889bd1
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238918 10/13/19 09:53 PM
F
FordCapriDriver Offline
F
Valvoline VR1 10W-30
Cheap and has 1300ppm of Zddp, so you can forget about any valvetrain wear woes.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: Oil recommendation for my flat tappet cam? [Re: FordCapriDriver] #5238921 10/13/19 09:55 PM
SteveG4 Offline
+1
Schaeffer 7000 racing oil is STOUT as well. I would think it's spendy though...
https://www.schaefferoil.com/documents/276-709-td.pdf
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238926 10/13/19 10:00 PM
J
jongies3 Offline
J
I run regular old Traveller (TSC brand) 15W-40 in all my older flat tappet engines, including a wound up Ford 390 FE that is putting more pressure on the cam lobes than your 4 cylinder ever will without problems. I think any HDEO will be adequate, I'd use 10W-30 in that particular engine.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238933 10/13/19 10:08 PM
clinebarger Offline
Your Lima 2.3L camshaft doesn't care what oil you run.
2001 Chevy Camaro L92/4L80E
Re: Oil recommendation for my flat tappet cam? [Re: clinebarger] #5238937 10/13/19 10:13 PM
SteveG4 Offline
Well, there you go, fusseli.
Valvoline VR1 10W-30... 6 qts for $32 and change on amazon.
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5238996 10/14/19 02:00 AM
demarpaint Offline
You can also buy a bottle of Rislone's ZDDP additive for a few dollars and tweak you're favorite oil for that application.
God Bless Our Troops
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5239015 10/14/19 03:07 AM
L
Lubener Offline
L
The cam looks great, why mess with success. I would stay with the oil(s) you have been using, except the 5w-40.. Why change the program now? Todays oils are much better than the SF rated stuff back in the 80's.
The "thinking" man's friend.
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5239027 10/14/19 04:19 AM
dlundblad Online Happy
Online Happy
Every oil you've mentioned has been recently changed.
VR1 is a good choice, but it's not for extended use with vehicles with cats. No idea if yours has any. Another good option is either a 10w30 HDEO or 0/5w40 A3/B4.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Oil recommendation for my flat tappet cam? [Re: SteveG4] #5239040 10/14/19 04:57 AM
F
F
Yeah doesn't hurt to play it safe especially when you have very good oils with high Zddp like VR1 that are not that expensive.
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5239057 10/14/19 05:29 AM
T
Trav Offline
T
The cam in that engine is not really a "flat tappet" the lobe is riding on a slipper that is not subjected anywhere near the forces of a true flat tappet cam lobe. This type of cam does not require very high zinc levels, possibly a little more than a roller or shim on bucket but not the levels normally associated with a flat tappet. 900-1100 ppm is plenty.
Engines requiring higher levels of zinc and phosphorus for cam lobe protection use push rods, rocker arms and lifters riding on a smaller and narrower cam lobe. Because the rocker arm ratio increases the force of the valve spring pressure exponentially and transmits it through the rocker arm to the lifter and cam lobe face the small contact area is subjected to many times the force of they type this engine uses.
Other types of valve/lobe arrangements can be problematic with lobe wear eg single cam lobes operating multiple valves through a fork style slipper but these are not very common in automotive designs. IMO Mobil 1 or Castrol Edge 0w40 would be a good fit for the turbo engine, 1100ppm zinc 1000 IIRC phosphorus and able to handle the heat of the old style non liquid cooled turbo.
Re: Oil recommendation for my flat tappet cam? [Re: fusseli] #5239133 10/14/19 07:25 AM
R
ragtoplvr Offline
R
Motorcycle oils have plenty of additives for flat tappet cams.
Rod
