Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
126 registered members (Aichiguy, ammolab, Aero540T, 69GTX, 15 invisible), 1,919 guests, and 19 spiders.
Topics297,608
Posts5,119,125
Members69,908
Most Online3,589
Nov 2nd, 2019
Outside Temperature Gauge #5238723 10/13/19 05:59 PM
R
rrretiree7 Offline OP
R
My gauge sticks at a certain temperature, lets say 68. I know it is hotter than 68. It takes ten minutes, but it never
reaches the correct temperature. Any ideas? Thank you
Re: Outside Temperature Gauge [Re: rrretiree7] #5238744 10/13/19 06:19 PM
JohnnyJohnson Online Content
Online Content
Is your outside gauge have batteries? If how long since you changed them?
2004 Corolla 136950
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: Outside Temperature Gauge [Re: JohnnyJohnson] #5238787 10/13/19 07:14 PM
csandste Online Content
Online Content
Don't want to crawl around under the car but I never heard that there were batteries in the sending unit. Why wouldn't it run off of the car's electrical system?
2017 Kia Soul Plus-- VWB 5w30-- 70,000 miles
Re: Outside Temperature Gauge [Re: csandste] #5238795 10/13/19 07:21 PM
Online Content
Still under warranty?
2004 Corolla 136950
2006 Duramax 76703
Re: Outside Temperature Gauge [Re: csandste] #5238806 10/13/19 07:36 PM
F
ffhdriver Offline
F
When my gauge on my Buick gave bad readings, it was simple job for the mechanic to change the sending unit in front of the radiator.
Re: Outside Temperature Gauge [Re: rrretiree7] #5238825 10/13/19 07:55 PM
CR94 Offline
Mine works as intended, probably, but I have a complaint anyway. Evidently Toyota's internal programming rounds the temperature to the nearest 1°C, then rounds that to the nearest equivalent 1°F. Because of this double rounding, it skips certain numbers. For example, the hottest temperature I've ever seen on it (other than immediately after starting when sun was hitting the car) was a few days ago around the Virginia-North Carolina border, when it was alternating between 95°F and 97°F. It never showed 96°. That, I suspect, is because 35°C is exactly 95°F, and 36°C is 96.8°F, which rounds to 97°. If the temperature is 35.5°C, which is 95.9°F, it should round correctly to 96°.
2011 Toyota Prius now at 106K
Re: Outside Temperature Gauge [Re: rrretiree7] #5239065 10/14/19 05:39 AM
Sayjac Offline
What vehicle? Many years ago had a Pontiac Grand Prix that sensor went bad, front of radiator. Just replaced it, problem solved. Based on the information provided, bad temp sensor would be my first thought.
Re: Outside Temperature Gauge [Re: ffhdriver] #5239119 10/14/19 07:04 AM
W
WyrTwister Offline
W
I did that on our 2006 Lacrosse and my cousin and I did it on his 2005 Lacrosse . Not sure it really helped much , but the part was not expensive .
Wyr
God bless
