Direct Injection (DI) in gasoline engines is another can of worms.
One problem is that the PCV junk still goes into the intake and over the intake valves.
All the detergents in the fuel bypass the intake/intake valves and intake valve seats, so the detergents (even the ones you add) in the fuel are not able to keep them clean.
A system of keeping the valves clean is an issue for DI engines.
