Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
55 registered members (anthonym6, Char Baby, 92saturnsl2, cb_13, 2010Civic, bullwinkle, 7 invisible), 1,298 guests, and 22 spiders.
Topics297,760
Posts5,121,989
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 1 of 3 1 2 3
Reusing oil filter #5238611 10/13/19 03:11 PM
B
Brojo Offline OP
B
Started an oil change and realized I didn’t have any spare filters in stock. The filter currently on the car is a Fram ultra guard and it only has 5k on it so I have no issue using it again.
My question is would you guys normally uninstall it and drain it out? I thought I remembered a thread about filters not resealing well once unscrewed. Just wanted to get some opinions.
2012 Honda Pilot if that makes any difference
Re: Reusing oil filter [Re: Brojo] #5238613 10/13/19 03:13 PM
L
LotI Offline
L
Leave it in place.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Reusing oil filter [Re: Brojo] #5238614 10/13/19 03:13 PM
J
JeffKeryk Offline
J
I would leave it on; no question.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Reusing oil filter [Re: Brojo] #5238619 10/13/19 03:28 PM
danez_yoda Offline
you will get some dirty oil retained but it should be small compared to what you replaced,
1/2qt vs 5qts. you're running 5k mile oci and probably running a synthetic. protection wise youll be fine,
Re: Reusing oil filter [Re: JeffKeryk] #5238620 10/13/19 03:28 PM
4WD Offline
Jeff: how does the law work there on oil filters ? - seems BrocL had mentioned a requirement to run 2X oil changes ?
Re: Reusing oil filter [Re: Brojo] #5238622 10/13/19 03:35 PM
4WD Offline
When I run 2X I never break the seal - in my case it leaves 1 quart out of an 8 quart fill - but I'm not running over 7K on 10k+ oil … so no worries
Re: Reusing oil filter [Re: 4WD] #5238630 10/13/19 03:49 PM
W
Whimsey Offline
W
Like 4WD if I use Fram Ultra's or Mobil 1 oil filters I'll use them for 2X without breaking the seal. This could be 10,000 to 15,000 miles of total use. Our vehicles were bought new and well taken care of so I don't worry about the filters clogging.
Whimsey
Re: Reusing oil filter [Re: Brojo] #5238633 10/13/19 03:53 PM
R
ragtoplvr Offline
R
I have dumped them and they resealed. I have left them on and they reseal. This is changing from summer 20W50 to winter 5W40 I see no difference when I replace the filter in the spring in the color of the oil or in the clean of the engine.
Rod.
Re: Reusing oil filter [Re: Brojo] #5238637 10/13/19 03:58 PM
P
philipp10 Offline
P
You can leave it on or drain it. Makes no difference. Oil filter gaskets are simple rectangular cross-section o-rings and the pressure they seal is low. THEY WILL RE-SEAL....contrary to the worry-warts on here.
Re: Reusing oil filter [Re: Brojo] #5238647 10/13/19 04:08 PM
K
ka9mnx Online Content
Online Content
K
When I reuse an oil filter I always remove, drain, reinstall.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Reusing oil filter [Re: Brojo] #5238652 10/13/19 04:17 PM
B
Brojo Offline OP
B
Advocates for both sides! Just as I expected lol, thanks fellas
Re: Reusing oil filter [Re: Brojo] #5238656 10/13/19 04:28 PM
slacktide_bitog Offline
Leave it on!
If you want to reuse the filter for another OCI, DO NOT unscrew it for any reason! If you unscrew it, replace it!
Re: Reusing oil filter [Re: Brojo] #5238660 10/13/19 04:30 PM
U
Ursatdx Offline
U
You could buy another and install it.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Reusing oil filter [Re: Brojo] #5238664 10/13/19 04:45 PM
R
Rolla07 Offline
R
Why you running only a 5k interval? Personally, id just run the oil longer and change the oil and filter.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Reusing oil filter [Re: Brojo] #5238674 10/13/19 04:53 PM
L
Linctex Offline
L
I have NEVER EVER EVER had a "seal problem" reusing a filter after being screwed back on again.
But, anyway - - leave it in place. It is not hurting anything.
Page 1 of 3 1 2 3
