Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
127 registered members (Astro14, 01rangerxl, 14Accent, 4WD, 92saturnsl2, AndyB, 11 invisible), 1,964 guests, and 18 spiders.
Topics297,608
Posts5,119,102
Members69,908
Most Online3,589
Nov 2nd, 2019
ATF contamination in PS Fluid--Honda CR-V 2007 #5238559 10/13/19 01:53 PM
B
Blurider24 Offline OP
B
Hey All,
I recently drained the PS of a '07 Honda CR-V.
Put 26-27 oz of the old fluid into a Valvoline Maxlife ATF container--had a few dribbles of ATF left in the bottle.
I had two fresh 12oz bottles of Honda PS fluid and put them back in the system and ended up a couple ounces short to make it to the Minimum line.
So, I dumped back ~2-3 oz of the old fluid back into the reservoir--forgetting that the bottle was not cleaned before
Should I be concerned about 10 ish drops of MaxLife ATF in the PS system (0.99L capacity) or should I buy 3 bottles and flush the system??
Thanks all!
2007 Honda CR-V EX AWD 165k miles
Quaker State UD Syn 5w-20 (7-8k OCI)
Fram Ultra Synthetic (Every other OC)
Valvoline MaxLife ATF (Every OC)
Re: ATF contamination in PS Fluid--Honda CR-V 2007 [Re: Blurider24] #5238571 10/13/19 02:12 PM
T
TmanP Online Content
Online Content
T
I'd not lose any sleep over it, particularly since many cars call for ATF to be used as PSF.
(I did a turkey baster change in the Sienna using ST ATF.)
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: ATF contamination in PS Fluid--Honda CR-V 2007 [Re: Blurider24] #5238572 10/13/19 02:12 PM
9
92saturnsl2 Online Content
Online Content
9
No worries, even though the Hondas take a special fluid, that small amount of ATF is not going to hurt anything. ATF is a hydraulic fluid after all.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: ATF contamination in PS Fluid--Honda CR-V 2007 [Re: Blurider24] #5238644 10/13/19 04:06 PM
2
2010Civic Offline
2
That amount will definitely not matter.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: ATF contamination in PS Fluid--Honda CR-V 2007 [Re: Blurider24] #5238671 10/13/19 04:52 PM
L
Linctex Offline
L
ATF is pretty much all I run in every power steering system.
Re: ATF contamination in PS Fluid--Honda CR-V 2007 [Re: Blurider24] #5238952 10/13/19 10:36 PM
K
KneeGrinder Offline
K
Ok, I'm the 30 year die hard Honda/Acura snob, just kidding on the snob part. Form what I have read, learned, learnt... Honda approved P/S fluid is a different chemical composition. Honda P/S Fluid is a mineral-oil type I believe, and may very well have a bad reaction with any other type of fluid you may add that is not compatible. I have no idea what the composition of the fluid you may, or "may" not have slightly contaminated it with. It's not your pump you have to worry about, it's your rack and pinion. A bit more costly and difficult to replace than your P/S pump.
Walmart may carry Honda approved fluid, my local does not! I used to buy it there. It also used to cost me $2.00 per bottle and have recently had to buy BECK/ARNLEY for $4.00 per bottle plus shipping, so cost has go up. I never used Honda branded fluid, pffft. I never had any problems with compatible fluids and I have logged many many miles in Honda/Acura's.
I would flush it. For the few bucks its not worth risking the rack. Like I stated, the pump does not care. I have replaced a few pumps, never once have I had to replace a rack!
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
