Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
AGM vs Traditional Battery
by jayjr1105 - 11/13/19 06:07 PM
Mail in mailbox notification devices
by atikovi - 11/13/19 05:46 PM
Canned marinated artichoke hearts, good or bad?
by atikovi - 11/13/19 05:35 PM
Shattered glass
by bdcardinal - 11/13/19 05:11 PM
Oil filter Cutter, Pet Peeve
by 10ecfarmer - 11/13/19 05:05 PM
Reducing radiator air flow during winter
by Backstache - 11/13/19 04:30 PM
Mower thrown to the curb..
by Eric Smith - 11/13/19 04:29 PM
valve body torque difference
by HyundaiAbuser - 11/13/19 04:07 PM
Mahle OC 142 oil filter
by Fattylocks - 11/13/19 04:03 PM
12 Toyota Tacoma 2.7L 4cyl. 90,000 mi. M1 0W-20 EP
by wagsrk08 - 11/13/19 03:29 PM
Seeking Battery Charger Advice
by lancerplayer - 11/13/19 12:46 PM
2019 Consumer Reports Tire Tests
by SubLGT - 11/13/19 11:07 AM
2020 Camaro LT1 V8, Wow.
by dareo - 11/13/19 11:01 AM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
102 registered members (69Torino, BAKOC5, 1WildPig, Aero540T, atikovi, 12 invisible), 2,218 guests, and 17 spiders.
Topics297,372
Posts5,114,257
Members69,842
Most Online3,589
Nov 2nd, 2019
200cc pressure washer sae 30 oil or something better? #5236868 10/11/19 10:15 AM
slybunda Offline OP
seen a petrol powered pressure washer with a 4 stroke 200cc engine rated at 6.5hp. it states to use sae 30 oil.
from what iv been reading up on here the 30 rating is when the oil is hot, so why not use a fully synthetic car engine oil that is multigrade like 5w30 or 0w30? since when up to temperature it would be a 30 grade like sae30 but when cold / startup it would flow a lot better than the straight sae30 grade?
or are these types of engines very particular on using the conventional sae30 thats specced in the manual?
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5236897 10/11/19 10:37 AM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
I don't know how important the non-detergent (ND) aspect of the oil is, but that may be a consideration for staying with 30W oil.
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5236906 10/11/19 10:41 AM
J
Jimzz Offline
J
I run HM 10w30 in my mowers and pressure washer.
yup
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5236918 10/11/19 10:55 AM
A
ad244 Offline
A
I run Mobil 2 and change it once a year
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5236954 10/11/19 11:27 AM
Donald Offline
I assume we are talking for the engine.
SAE 30 would be fine as would a 5W30 or 10W30. I doubt you will be doing much pressure washing in cold weather so an oil's cold weather properties are not very important.
2015 Ford F250 w/Powerstroke
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5236979 10/11/19 11:55 AM
B
bubbatime Offline
B
One of those Chinese Honda GX200 clone engines? 196cc? Great engines.
I doubt you are going to pressure wash under 65 degrees F (18 degrees C) ?? I tried pressure washing at that temp and my hands froze and was very cold. As long as you are pressure washing above 5 degrees C, SAE 30 will be fine. Yes it is harder to pull start at that temp.
10W30 car oil is thinner at temp than SAE 30 usually, and breaks down and thins to a 20 weight pretty rapidly.
That being said, synthetic 10W30 car oil, diesel/fleet 10W30, and diesel/fleet 15W40, all will work perfect in this engine.
Briggs and Stratton actually recommends synthetic 15W50 for pressure washing applications, which I have used with great success as well in many engines.
Your engine will be fine with practically any 30 to 50 weight oil in the crankcase. The fact that you are on this website, means you will probably check and change your oil at normal intervals, so as long as their is oil on the dipstick it really doesn’t matter.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237090 10/11/19 01:47 PM
sleepery Offline
I generally use SAE 30 in my pressure washer . It gets used mostly in warm weather . I use 5w30 in my snow blower and have used it in the pressure washer without any issues The pump oil is a separate oil and is a non detergent oil .
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237169 10/11/19 02:47 PM
slybunda Offline OP
How fast would fully synthetic 5w30 oil break down in this application?
I would be using the pressure washer twice a year and it would be used for around 12 hours of run time per use so thats 24 hours of running time per year. Probably less if its faster at cleaning than my electric one that burnt out.
Id Change the oil every year since 5w30 is very cheap and i have it already for the cars.
Just dont want to have it die on me like my nilfisk electric one did. Only had it just over 2 years and 24 hours of use a year so it ran less than 50 hours and it was dead.
By the way the 12 hours per use is not constant. Its like 4 hours a day. So total of 6 days of pressure washing the block paving a year to get 6 days x 4 hours = 24 hours a year.
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237185 10/11/19 03:00 PM
9
92saturnsl2 Offline
9
The reason air cooled engines have always spec'd SAE 30 oil is that cheaper multigrade oils will degrade when exposed to the hotter oil temps that air cooled engines experience. In the last decade or two, oils have improved dramatically, so you started to see engine manufacturers include 10w-30, 5w-30, etc. as a recommended viscosity for various temperatures.
If you use a high quality oil, you can certainly use your choice of multigrade-- 5w-30, 10w-40, etc. If you run primarily in warm weather, I'd stick with what works. SAE30 or a 15w-40 would be my choice.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237677 10/12/19 08:28 AM
slybunda Offline OP
can these small engines take a fully synthetic 5w40 or will it be too thick?
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237803 10/12/19 11:37 AM
N
nobb Offline
N
Are you sure this spec is for the engine and not the pump? Typically it's the pump that requires a ND 30 wt oil.
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5237901 10/12/19 01:48 PM
F
Fastzntn Offline
F
I use Pennzoil 30 weight oil in my pressure washer engine. It’s a Briggs & Stratton XR950. It’s held up well for several years with this oil. In fact, in addition to me using it, I encourage my friends to borrow it too (I’d rather it run than sit). So it gets a fair amount of use.
Actually just changed the oil in it today. Ran a magnet in the sump before refilling and found very little metal. Everything seems to be wearing very well and I plan to keep running 30 weight.
Re: 200cc pressure washer sae 30 oil or something better? [Re: nobb] #5238367 10/13/19 08:27 AM
B
bubbatime Offline
B
No where did the OP say that engine manual called for a non-detergent SAE30 oil.
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5238369 10/13/19 08:29 AM
B
bubbatime Offline
B
Like I said in my previous post, Briggs and Stratton, one of the worlds largest small engine manufacturers, recommends 15W50 for engines that are used for pressure washing.
I have 20W50 oil in my GX200 clone pressure washer engine right now.
You wont notice any difference at all from a SAE30 to a 20W50. The engine runs the same, sounds the same, starts the same.
So YES, I can unequivocally say that your engine will run fine on 5W40 synthetic.
Re: 200cc pressure washer sae 30 oil or something better? [Re: slybunda] #5238463 10/13/19 11:14 AM
slybunda Offline OP
https://www.parkerbrand.co.uk/petrol-pressure-jet-washer-6-5hp-engine-2900-psi
Thats the product i thinking of buying. There is a user manual link in the product description.
Seems a good price. Its probably made in china but i do know stuff can be made to a high or low quality standard all depending on price.
