Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69937 Registered Users
73 registered members (atikovi, 53' Stude, 2K2AcuraTL, Bailes1992, 01rangerxl, avi1777, 10 invisible), 1,519 guests, and 22 spiders.
Topics297,761
Posts5,122,046
Members69,937
Most Online3,589
Nov 2nd, 2019
Rate Thread
How Much Does ATF Expand With Heat? #5238406 10/13/19 09:42 AM
W
Whalstib Offline OP
W
Howdy,
I always wondered why ATF must be checked at a certain temperature range and figure it must expand quite a bit. Old dip stick method had a ~2" of variance. My new Tundra uses the "open valve" method like a differential but needs to be in a specific temperature range that makes it a PITA compared to dip stick although more accurate..
So if I have a 15 qt capacity how much would it measure at 50°F vs 120° F ? As temperature rises does it expand more? Does it even expand or need to be thin enough to fully immerse all the little ports and be flowing fully?
Thanks
Re: How Much Does ATF Expand With Heat? [Re: Whalstib] #5238441 10/13/19 10:21 AM
H
hallstevenson Offline
H
I can only relate my experience and it's this: On 3 separate occasions, I drained between 3.5 and 4 quarts of ATF from two different vehicles. Did this while the ATF was "hot", in excess of 150º F (after a good 30 minute drive). Poured it into a container and marked the level. Using an infrared thermometer and waiting close to an hour, it eventually dropped to around 75-80º F and for all practical purposes, the level did not change. Certainly not enough to visually notice.
Re: How Much Does ATF Expand With Heat? [Re: Whalstib] #5238454 10/13/19 10:43 AM
demarpaint Offline
Here's a picture for the NAG 1 transmission fluid level graph. You can get an idea of how much the ATF used for that unit [ATF+4] expands and take an educated guess based on that. [Linked Image]
God Bless Our Troops
Re: How Much Does ATF Expand With Heat? [Re: Whalstib] #5238455 10/13/19 10:48 AM
simple_gifts Offline
Of course the container it is held in is also expanding or contracting... grin2
2004 Prius; 118K; ALM
2007 Yaris 98K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: How Much Does ATF Expand With Heat? [Re: Whalstib] #5238466 10/13/19 11:18 AM
spk2000 Offline
Quote below hope it helps:
Link:
https://www.dieselplace.com/forum/5...llison-fluids-engineer-here-help-29.html
Coefficient of thermal expansion for oils and transmission fluids is around 0.0007 per degree C (0.07%/C). So, if you've got 12 liters in the pan, it will expand 0.0084 L per degree C. Since there's increased volume, and the surface area of the fluid does not change appreciably, the fluid goes higher on the dipstick.
Volume = Area x Height. So, Height = Volume/Area. Therefore, height on the dipstick is proportional to volume change.
Summer time temperature change might be ambient air temperature 68F (20C), at start up, to around 180F(82C) at operating temperature. Or, around 62C.
Therefore, during the summertime, the fluid could be expected to expand 0.0007 x 62C = 0.0434 (4.3%).
Share
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
