Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
47 registered members (92saturnsl2, cb_13, 2010Civic, bullwinkle, avi1777, 87sammy, 7 invisible), 1,248 guests, and 26 spiders.
Topics297,760
Posts5,121,987
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Strange lighting issue in house... #5238395 10/13/19 09:27 AM
dja4260 Offline OP
Basement laundry room recessed can lighting. 6 total cans all on 1 switch. I recently noticed that only 1 can light works out of the 6. All cans show power when using a tester stick. I can't get any of them to work except the 1 light?
What gives?!?!?!
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Strange lighting issue in house... [Re: dja4260] #5238409 10/13/19 09:45 AM
double vanos Offline
They all show power? Is it 110 volts? If so the lights should work. We have electricians here so maybe they’ll chime in with an answer.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Strange lighting issue in house... [Re: dja4260] #5238410 10/13/19 09:46 AM
E
edwardh1 Offline
E
what size bulbs - maybe an overheat switch tripped and did not reset?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Strange lighting issue in house... [Re: double vanos] #5238412 10/13/19 09:48 AM
dja4260 Offline OP
They ALL show power as in the hot leg makes the tester stick beep. I checked the swith and it's a single pole, working as it should.
1997 HD Sportster
Re: Strange lighting issue in house... [Re: edwardh1] #5238414 10/13/19 09:49 AM
dja4260 Offline OP
The cans all have LED lights that plug into the bulb socket. I tried the working LED light in other cans as well as a working light blub. No luck.
1997 HD Sportster
Re: Strange lighting issue in house... [Re: dja4260] #5238418 10/13/19 09:56 AM
V
vwmaniaman Offline
V
I have had this issue with LED's. The large base won't let them contact the center button. They won't go in deep enough.
Don't waste your time on a slipshod repair.
Re: Strange lighting issue in house... [Re: vwmaniaman] #5238420 10/13/19 09:57 AM
Cujet Offline
I was going to say this too.
Re: Strange lighting issue in house... [Re: dja4260] #5238427 10/13/19 10:02 AM
dja4260 Offline OP
All cans show 124 volt. The can base closest to the working light has the middle contact pushed in, which maybe not allowing it to contact the LED screw in. I'm going to investigate further, I gotta lay my daughter down to nap. I still feel like the other lights should work though?
1997 HD Sportster
Re: Strange lighting issue in house... [Re: dja4260] #5238433 10/13/19 10:07 AM
Danno Offline
The pain of LEDs, been there and don't like it.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Strange lighting issue in house... [Re: dja4260] #5238447 10/13/19 10:33 AM
B
billt460 Offline
B
LED's.... They save so much energy, they don't work.
Re: Strange lighting issue in house... [Re: dja4260] #5238452 10/13/19 10:42 AM
F
Fawteen Offline
F
Assuming you're using your multimeter correctly, if the contacts inside the socket have power, then the issue is with the bulbs. Try a standard bulb and see what happens.
Been using them throughout the entire house (inside and outside) and garage for a few years now (116 bulbs total) without a single issue. They work for most of us just fine.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: Strange lighting issue in house... [Re: dja4260] #5238460 10/13/19 11:07 AM
KJSmith Offline
I have seen a lot of cans where the center contact gets pushed to far in.
With the power off, you can find something to hook it with and pull it down.
This is assuming you are checking power from the center contact to the shell.
If not, try checking it that way.
Could be the common is not there.
Loose wire at the fixture that works or the first non working fixture could be the issue.
Re: Strange lighting issue in house... [Re: dja4260] #5238492 10/13/19 12:15 PM
B
Blkstanger Offline
B
Cheap fixtures! I bet I can guess where they were made.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5
Re: Strange lighting issue in house... [Re: dja4260] #5238581 10/13/19 02:27 PM
dareo Offline
Wierd electrical stuff usually means a partial or loose connection, so perhaps redo the connection starting with the light that works. Had one that worked enough to show a solid ground on a multimeter but still not light up.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: Strange lighting issue in house... [Re: dja4260] #5238624 10/13/19 03:38 PM
M
mk378 Offline
M
If you're using the typical "Not for Totally Enclosed Fixtures" type of LED bulbs in your totally enclosed fixtures, you're going to have a bad time.
