Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
52 registered members (ChiTDI, 92saturnsl2, cb_13, 2010Civic, bullwinkle, avi1777, 7 invisible), 1,261 guests, and 23 spiders.
Topics297,760
Posts5,121,987
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Annoying compressor oil requirements #5238274 10/13/19 05:46 AM
dlundblad Offline OP
[Linked Image]
This is the oil requirement for my compressor. Since it’s stored in a non climate controlled garage, it looks like technically I’ll have to change the oil 3 times a year with the seasons to be by the book, but at the minimum at least 2 since it’d get colder than 40*F more often than warmer than 80*F.
The manual says not to run it below 20*F. I won’t make an effort to do so, but if a tire needs inflated when it’s that cold, I’m going to use the dang thing.
Just curious if there’d be any issues running an SAE 20 as that looks to be between the SAE 10 and 30. I’m surprised it isn’t an option really.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Annoying compressor oil requirements [Re: dlundblad] #5238291 10/13/19 06:50 AM
M
Mainia Offline
M
I have run regular car oil in my compressors for 30 years in Minnesota winters. Never had an issue using detergent oils. I will go out in the garage that is -10 and start up the compressor. I use Redline 0w-30. I use it because of the high moly and zinc and Ester for the cold start. It keeps a barrier there since the cold oil has a hard time flinging until it gets warmer. I could care less what the manual says. I change the oil every 3-4 years. My tank went out, before the pump did.
Re: Annoying compressor oil requirements [Re: dlundblad] #5238317 10/13/19 07:31 AM
B
billt460 Offline
B
Compressors are not that oil critical. The biggest thing you don't want, is oil so thick it causes the motor to kick out in cold weather. Just use a 0W- Whatever, and you'll be good to go. They're not an automobile engine pulling a trailer up a mountain in the desert. They don't get that hot. Especially in a cold garage when they are cycling off and on all the time. Mine never gets hot enough to where I can't keep my hand the top of the cylinder head.
Re: Annoying compressor oil requirements [Re: dlundblad] #5238355 10/13/19 08:16 AM
E
edwardh1 Offline
E
hang a trouble light on it in cold weather b4 you start it to warm the oil.
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Annoying compressor oil requirements [Re: Mainia] #5238388 10/13/19 09:07 AM
L
Linctex Offline
L
Same.
For 99.9999% of consumers, they should just spec "any 10W-30 oil will do" already.........
Re: Annoying compressor oil requirements [Re: dlundblad] #5238400 10/13/19 09:32 AM
R
Rat407 Online Content
Online Content
R
To me the only time oil might come into play on how it effects the compressor is in an industrial setting where it is ran at 100% of it's duty cycle. Then just then it might make a difference. For us residential folks, not so much. To me just run a quality synthetic compressor fluid like AMSOIL's and press on.
At work when I was in the Air Force we had a huge compressor that we used to get air from to start the Jet Fuel Starters, (JFS) that started the F-15E's. When it got down to 30 degrees or lower it didn't want to start. I changed it out to AMSOIL's PCIQT which is ISO 46, SAE 30 and it would crank and run even down to 20 degrees. Ran great even in the summer heat of 98 degree weather that we get here in eastern NC.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Annoying compressor oil requirements [Re: dlundblad] #5238440 10/13/19 10:12 AM
Propflux01 Offline
Why do compressors want ND oil VS Detergent anyway?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Annoying compressor oil requirements [Re: dlundblad] #5238443 10/13/19 10:27 AM
R
ragtoplvr Offline
R
Compressors do not have filters so they do not want detergents, they want the dirt to settle out.
The IR compressor is kind of a semi pro unit with a longer intended life than consumer grade but I believe it still uses reed valves. This is opposed to disc valves that run forever. Some will use it in their repair shop and it will run several hours a day. This compressor is supposed to last in that environment for 20-30 years with maybe a occasional reed valve replacement. Then you do need to adhere to the oil requirement in that use.. Home use is so much less hours that any oil changed once and a while will work.
When we started our business we used a reed valve IR 2 stage. It ran with a 20 to 25% duty cycle for 5 years with no failure and was not heated in the winter, It is now the backup compressor.
I think any decent quality cast iron compressor will run the rest of your life on any oil regardless in home use. If it is real cold you might start it with the tank vented and let it run for a few minutes to heat the oil before you let it build pressure.
Rod
Re: Annoying compressor oil requirements [Re: ragtoplvr] #5238493 10/13/19 12:15 PM
M
maxdustington Offline
M
Rod
IR is not pro grade anymore. Indian pumps, Chinese motors.
99 Toyota Tercel CE 5EFE/C151
Re: Annoying compressor oil requirements [Re: maxdustington] #5238509 10/13/19 12:29 PM
Rod
Some pumps are Chinese. Others are Indian.
I’ll have to recheck, but my motor was made in Mexico.
Re: Annoying compressor oil requirements [Re: maxdustington] #5238631 10/13/19 03:49 PM
R
ragtoplvr Offline
R
Sad. Harbor freight it is then.
Is champion still good?
Rod
Re: Annoying compressor oil requirements [Re: dlundblad] #5238716 10/13/19 05:49 PM
J
johnnydc Offline
J
I installed the compressor in the basement. Running a 1/2 inch copper pipe to the garage. I'm lucky the garage is attached to the house. I use 30 weight 365 days.
2012 Ford Fusion SEL V6
2009 Mercury Milan Premier V6
Valvoline Advanced Synthetic 5/20 and Motorcraft Filters
Re: Annoying compressor oil requirements [Re: ragtoplvr] #5239017 10/14/19 03:14 AM
B
billt460 Offline
B
Compressors do not have filters so they do not want detergents, they want the dirt to settle out. Rod
In theory that's true. I will only add that I ran my compressor on average at least once to twice a week for almost 30 years before I decided to change the oil. I was surprised to find it came out just as clean as it went in. I refilled it with Mobil 1 0W-30, and I'm not going to worry about it again.
Re: Annoying compressor oil requirements [Re: dlundblad] #5240820 10/15/19 09:37 PM
J
jakewells Offline
J
They do sell all season compressor oil that is what i use.
1996 Chevy 1500 4.3 V6. Harvest King 5W40 Fram XG3980 oil filter
Pennzoil sycromesh >> transmission
Shell rotella nitrite free ELC >> radiator
Shell Spirax HD 80W-90 >> rear axle
Re: Annoying compressor oil requirements [Re: jakewells] #5241708 10/16/19 06:36 PM
That’s currently what I’m using. It’s my understanding that it’s around the 30 weight range.
