Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
47 registered members (92saturnsl2, cb_13, 2010Civic, bullwinkle, avi1777, 87sammy, 7 invisible), 1,248 guests, and 26 spiders.
Topics297,760
Posts5,121,987
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Conventional to synthetic #5238221 10/13/19 12:36 AM
CruiserRX Offline OP
Going to change my oil for the first time coming up, got a 04 Lexus rx330 140k miles Been fed whatever cheap dino the quick lube places had at 3-5k miles. I plan on changing it myself. Gonna try to go full synthetic with Supertech and a Bosch premium filter. Will run it for about 5k miles then change again and run a 7k OCI after that.
Does that sounds like a good plan?
Re: Conventional to synthetic [Re: CruiserRX] #5238225 10/13/19 12:45 AM
B
burla Offline
B
Yes, pretty reasonable oci. You may opt for a used oil analysis from blackstone at the 7k mile mark and make sure tbn is holding up. Every car is different, you never know. You may as well look into spun microglass filtration such as fram ultra as well. Paper degrades but spun microglass doesn't. I have even cut them open at 24 mos and they were still like new. Royal Purple, amsoil ea, fram ultra, wix xp and the most popular. Pair synthetic oil with synthetic filter for the win on a long oci.
Re: Conventional to synthetic [Re: burla] #5238265 10/13/19 05:27 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Agree it is reasonable. Paper works fine at 24 months as well.
OP, is the engine in there one of the sludge monster engines? Does it smoke?
If it has the risk of sludge, which many Toyota v6 engine sof that era did, I’d go slow. Supertech syn may have less solvency than others, but it may also clean.
You might consider doing 1-2 short OCIs on an HDEO as well if sludge is a possibility.
Re: Conventional to synthetic [Re: CruiserRX] #5238266 10/13/19 05:29 AM
W
wemay Online Happy
Online Happy
W
Just about every "Conventional" is now a Synthetic Blend. If you're keeping the intervals under 7k, I'd consider leaving things be and using a FRAM Extra Guard.
But your plan sounds fine as well. Congrats on the purchase and...
welcome
2018 KIA Sportage LX AWD
Shell RGT 5W30, STP S2808
2013 Hyundai Santa Fe Sport 2.0T
M1AP 5W30, OEM
Re: Conventional to synthetic [Re: CruiserRX] #5238284 10/13/19 06:25 AM
csandste Offline
Huge price spread for synthetics at quick lubes. Tiny price spread for synthetics in the bottle. Your plan is right on.
2017 Kia Soul Plus-- VWB 5w30-- 70,000 miles
Re: Conventional to synthetic [Re: CruiserRX] #5238285 10/13/19 06:26 AM
K
ka9mnx Online Content
Online Content
K
Your plan is solid and it sounds like it's had good oil changes in it's life. SuperTech is a fine oil but I would stick with 5k OCI's. I've switched numerous vehicles with 200+ k miles to synthetic with no issues (fingers crossed of course).
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Conventional to synthetic [Re: CruiserRX] #5238298 10/13/19 07:02 AM
JohnnyJohnson Offline
I've run the Bosch premium filter on my 2004 Corolla with Castrol 5w-30 EP 7156 OCI and got a stellar UOA.
I'd personally have no issue going 7K miles on change 1. Several good full synthetics on sale regularly. QSUD is also
another one I've used and a good value.
2004 Corolla 137003
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76800
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: Conventional to synthetic [Re: CruiserRX] #5238328 10/13/19 07:42 AM
P
Pelican Offline
P
Good plan, but why not Toyota's own TRD filters they are outstanding in filtering & construction.
Re: Conventional to synthetic [Re: CruiserRX] #5238360 10/13/19 08:20 AM
B
bubbatime Offline
B
No. You have a mild climate, so synthetic is not needed. Plus, you have a high mileage 15 year old engine, unknown maintenance history, probably quick lube bulk conventional its entire life.
Id run a synthetic blend in the required weight. Probably Maxlife.
Synthetic could start an oil leak, where there wasnt one before.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Conventional to synthetic [Re: CruiserRX] #5238608 10/13/19 03:05 PM
T
tundraotto Offline
T
If your conventional oil has plugged up oil leaks - it could probably benefit from cleaning up the sludge. If a synthetic can do that - it would probably be good. You could always sludge it back up on purpose with a conventional.
