1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
76 registered members (Best F100, aray, alarmguy, andyd, ABN_CBT_ENGR, AlienBug, 10 invisible), 1,129 guests, and 73 spiders.
Topics306,080
Posts5,287,005
Members71,596
XG 9641 images #5237512 10/11/19 11:49 PM
M
miden851 Offline OP
M
after 10K and 2x oil changes
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2017 Honda Accord EX-L; @20K miles
2016 Honda CR-V EX-L; @57K miles
Re: XG 9641 images [Re: miden851] #5237532 10/12/19 01:10 AM
T
tundraotto Offline
T
WOW - printed cardboard!
Re: XG 9641 images [Re: miden851] #5237613 10/12/19 07:40 AM
J
JC1 Offline
J
Looks good. What vehicle was that on? Thanks for the post.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: XG 9641 images [Re: tundraotto] #5237657 10/12/19 08:50 AM
Snagglefoot Online Content
Online Content
Fram xG
smile Now, now. This is an Ultra. You might be thinking it’s an Extra Guard with cardboard ends. That’s one confusing thing about Fram. Some folks see XG and think it stands for Extra Guard.
If you want the job done right......do it yourself.
Re: XG 9641 images [Re: miden851] #5237668 10/12/19 09:08 AM
M
miden851 Offline OP
M
yes, the filter is from my 2.3L Mazda engine
Re: XG 9641 images [Re: miden851] #5237714 10/12/19 10:28 AM
J
JLTD Offline
J
Can go further....(so can your oil).
Lates.
Re: XG 9641 images [Re: miden851] #5237766 10/12/19 11:24 AM
slacktide_bitog Offline
Looks good thumbsup
What did you replace it with? What kind of oil did you use? smile
Re: XG 9641 images [Re: miden851] #5237787 10/12/19 12:04 PM
F
Farnsworth Offline
F
The intruding fuzzy stuff in the center tube from the seal would be a "deal breaker" if that is how it came out when removed.
Re: XG 9641 images [Re: slacktide_bitog] #5237932 10/12/19 03:40 PM
M
miden851 Offline OP
M
Originally Posted by slacktide_bitog
Looks good thumbsup
thanks;
I have used over the years a verity oil and filters, from basic/dino to synthetic; lately I use only XG filters and Mobil 1 HM oil
Re: XG 9641 images [Re: Farnsworth] #5237997 10/12/19 05:39 PM
shibby6600 Offline
That was most likely caused by installing or removing the filter, I'd guess install judging by its direction. It doesn't get like that under normal use. It's also nothing to worry about since almost all of these cartridge filters sit against a flat bottom and very little oil reaches even the outside of that seal.
Re: XG 9641 images [Re: shibby6600] #5238093 10/12/19 08:04 PM
CR94 Offline
If end with the frayed "fuzzy stuff" went over the center tube first when it was installed, there was nothing to stop any loose fragments from going into the engine.
The XG10358 for 1.8L Toyotas (including mine) is similarly constructed, except that it lacks the felt seal on the ends. That eliminates any risk of loose fuzzy bits going where they shouldn't, but may not seal against bypassing oil as effectively if the filter geometry is not perfect.
Anyway, we need more posts of cartridge filters, especially since they're easier than spin-ons to dissect.
2011 Toyota Prius now at 110K
Re: XG 9641 images [Re: miden851] #5238309 10/13/19 08:15 AM
M
miden851 Offline OP
M
any oil filter I have replaced had that spongy/cotton pressed ring in the center of a oil filter and the engine still reached that high miles
Motorcraft example
[Linked Image]
Re: XG 9641 images [Re: miden851] #5238354 10/13/19 09:16 AM
CR94 Offline
Originally Posted by miden851
... Motorcraft example ...
That Motorcraft end cap looks like it's from Purolator---very similar to those of the Purolator L16311 I bought several years ago.
Re: XG 9641 images [Re: miden851] #5238361 10/13/19 09:21 AM
M
miden851 Offline OP
M
totally; imo, they all come from the same supplier its just different labeling for those that do not know grin
