Forums Migration
Please read this thread
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
HydroxZ, JDMorgan, sycboi, Chuck_Ellison, BakonBittz
71871 Registered Users
106 registered members (55hambone, antone, Anthony, 28oz, ABerns, 4WD, 14 invisible), 2,080 guests, and 27 spiders.
Topics307,552
Posts5,313,039
Members71,871
Any harm in hooking up trailer lights backwards? #5237501 10/11/19 11:07 PM
M
motor_oil_madman Offline OP
M
So apparently I don't pay attention to how things go together like I used to. Then again I didn't count on not being able to decipher the color of the wires on my trailer. They were painted black and even after removing the paint the colors are about the same. Is there any harm in hooking up the brake like wire to the running light bulb accidently if I have them backwards? The other issue is I have a ground issue where the lights only seem to ground through the trailer hitch ball even though I grinded the paint down to bare metal on the tongue and both tail lights.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5237507 10/11/19 11:38 PM
T
tundraotto Offline
T
only if the trailer brakes come on with the lights.....
Re: Any harm in hooking up trailer lights backwards? [Re: tundraotto] #5237513 10/11/19 11:50 PM
M
M
I got ya. The brakes would be on the entire time the running lights are on. This trailer has no brakes anyways. Obviously I'm going to switch them around if I have them backwards.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5237525 10/12/19 12:32 AM
O
oldhp Offline
O
Pretty sure the brake filament is brighter than the tail light filament, so it does make a difference. Hook a dedicated ground wire up thru your wiring connection that goes from the light bulbs/lightbulb sockets thur the connection to a known ground on the truck.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5237713 10/12/19 10:26 AM
J
JLTD Offline
J
Why not just test them as installed and if they work properly, they work properly. Switch wires if they don't. You could also trace the wires back a bit to where they hadn't been painted.
Most bulbs don't care about which way the current is flowing.
Lates.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5237802 10/12/19 12:36 PM
CT8 Offline
Other than the wires causing a direct short what makes you think damage would occur
2015 F150 2.7
2018 F350 6.2
Re: Any harm in hooking up trailer lights backwards? [Re: JLTD] #5238104 10/12/19 08:27 PM
M
M
I don't think they were concerned with color coding when they built this trailer, otherwise I would have done that.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5238106 10/12/19 08:28 PM
M
M
It's only the passenger side that looks the same. Somehow the brown and green look the same.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5239206 10/14/19 09:56 AM
M
mk378 Offline
M
Plug in the truck, turn the running lights on, then touch what you think is the brown trailer wire to each light wire. Use the one that lights up dim. If the "brown" wire seems dead, try the other one. By elimination, the other wire is the turn / brake.
Always run a network of ground wires (standard color is white) to each light and the truck plug. Do not count on grounding through the frame.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5239793 10/14/19 09:57 PM
M
M
Mk378 do I have this right? I have a ground wire on each tail light attached to clean shiny metal on the trailer and then one ground wire that.goes from the truck plug to the tongue of the trailer, also connected to clean shiney metal. It still seems to only be grounding through the ball though.
Re: Any harm in hooking up trailer lights backwards? [Re: motor_oil_madman] #5240084 10/15/19 10:23 AM
M
mk378 Offline
M
Run a ground by wire all the way from the truck plug to each light. You don't need an individual wire for each light, you can tee them into a common wire. Don't involve the trailer frame at all.
It is also possible that the ground socket on the truck is not grounded to the truck. That would cause what you're experiencing. With the lights on, the ground wire in the trailer plug should be zero volts measured to the truck frame.
