What is your favorite airline and why?
by ZZman - 11/22/19 11:35 AM
Costco Instant rebate for M1
by Joephu - 11/22/19 11:25 AM
Serpentine belt
by Grambo - 11/22/19 10:50 AM
My 2016 Ford Fiesta Failure
by Mr_Luke - 11/22/19 10:37 AM
Starter Tool set - hand tools for professional work?
by btanchors - 11/22/19 10:20 AM
Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69938 Registered Users
104 registered members (69Torino, 28oz, 330indy, 53' Stude, 9 invisible), 2,262 guests, and 26 spiders.
Topics297,775
Posts5,122,303
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 2 of 2 1 2
Re: Gabriel vs TRW struts [Re: perfect_oil] #5238173 10/12/19 09:55 PM
slacktide_bitog Offline
Originally Posted by perfect_oil
Originally Posted by 92saturnsl2
When I looked earlier today, the only Monroes they had on clearance are the OE Spectrum line, which is their bottom dollar budget strut. Would rather spend a few bucks more on something more premium.
OK makes sense. I didn't know OE Spectrum was the bottom of the barrel.
It's not. That would be the Gas-Matic/Monro-Matic or anything that ends in -Matic smile
The OEspectrum is their premium line, OE quality.
Re: Gabriel vs TRW struts [Re: 92saturnsl2] #5238568 10/13/19 02:10 PM
9
92saturnsl2 Offline OP
9
Thanks for the input fellas. I'll probably go with the TRW; sounds like you can't really go wrong with that brand, whereas the others have lines of varying quality.
I'm going to avoid Monroe this time around, I replaced the front struts about 50k ago with Monroe Limited Edition struts, which were a premium line at the time. The drivers side is already leaking fluid. So what was going to be a simple tie rod end replacement has now turned into lower control arms, struts, strut mounts and the tie rod ends. Might as well replace the sway bar end links while I'm in there. I did all this together about 50k ago but the boots have cracked and hemorrhaged grease on both the tie rod ends AND ball joints. I always err on the side of quality when buying parts, so this was all reasonably name brand stuff-- seems it's terribly difficult to find quality parts that hold up nowadays! Seems like I'd be better off buying the cheap Ultra Power and roll the dice... I digress. Will give the name brand stuff another go-around, the last set was supposed to follow this car to the grave!
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: Gabriel vs TRW struts [Re: 92saturnsl2] #5246394 10/21/19 06:48 PM
A
alchargo Offline
A
I ordered some TRW struts that were on clearance on RockAuto for $25.XX. They arrived today and appear to be rebadged Sachs, which IMO is a good thing.
Re: Gabriel vs TRW struts [Re: 92saturnsl2] #5246485 10/21/19 08:06 PM
Definitely worth it to use quick struts. Just too bad KYB doesn't make quick struts for the 4th gen Maxima mad
If you want to go cheap, Rock Auto does have SenSen speedy struts on closeout smile
Sensen is an OE supplier to Chinese-market European-nameplate cars like Volvo and VW. Their aftermarket shocks are said to be a Chinese copy of KYB. So if you're going to do teh cheap no-name, it might as well be Sensen
Re: Gabriel vs TRW struts [Re: alchargo] #5246558 10/21/19 09:24 PM
9
9
Yep, I received mine the other day and they are rebadged Sachs as well. Not bad for $25!
Re: Gabriel vs TRW struts [Re: alchargo] #5246888 10/22/19 09:10 AM
Z
zzyzzx Offline
Z
Those clearance struts are usually old and often bad due to age out of the box.
Re: Gabriel vs TRW struts [Re: zzyzzx] #5247495 10/22/19 06:56 PM
A
alchargo Offline
A
ZF Friedrichshafen, parent company of Sachs, didn't acquire TRW until 2015. I'll take my chances thumbsup
Re: Gabriel vs TRW struts [Re: zzyzzx] #5247603 10/22/19 09:25 PM
9
9
That's a $50 gamble I'll take every time. I don't buy the idea that a strut sitting in a box in a climate controlled environment for a few years is going to magically kill a strut. Given that many struts last the life of the vehicle, exposed to years of abuse & climate variations, I don't think a few years sitting in a box is going to hurt them much. Sure the seals could be affected and compromise lifespan some, but I doubt many people are receiving these DOA. So far I'm 4/4 on closeout struts and have an extra ~$200 in my pocket.
Finished Installed the TRW/Sachs struts today and they work as expected. Ride is substantially firmer, not in a bad way. Everything feels nice and tight, ride height seems higher on the front, but the old struts had lost most of their fluid, so that probably explains it given that I didn't change the springs.
Re: Gabriel vs TRW struts [Re: 92saturnsl2] #5247769 10/23/19 06:22 AM
M
MaximaGuy Offline
M
All of then are replacement parts but for shocks go OEM - hard lesson learnt to stay away from OEM. Its a real job and time consuming - sticking with OEM will be well thought
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Gabriel vs TRW struts [Re: 92saturnsl2] #5247775 10/23/19 06:33 AM
M
meep Offline
M
^^^ unless you own a ford ^^^
2018 F150
2015 crv (wifey!)
Page 2 of 2 1 2
