Engine overhaul calls for 21.3 hours
"Includes: Measure Cylinder Bores, Crankshaft & Pistons For Proper Size & Hone Cylinders. Renew Pistons, Rings, Main & Rod Bearings, Grind Valves, Clean Or Renew Spark Plugs, R&I Engine & Make All Necessary Adjustments"
At $150 an hour which is HIGH but not unheard of is $3,195.
Your Invoice.....
Remove engine....................................................$660
Teardown longblock..............................................$660
Build shortblock....................................................$880
Assemble longblock.............................................$825
Install engine........................................................$660
Disassemble & Reassemble cylinder heads........$330
Adjust valve clearance.........................................$330
Total......................................................................$4,345
Didn't add the valve job, Though I should have, The turbo install might have been more involved....But I doubt it.
To top it off.....Spend $28,000, And still charge for a diagnostic fee!
$330 to flush the heater core
I didn't check part markup.....I'm sure it's beyond ridiculous!
