1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
69 registered members (AJB0009, 14Accent, aba4430, Alfred_B, 69Torino, 1978elcamino, 7 invisible), 1,652 guests, and 79 spiders.
Topics306,083
Posts5,287,066
Members71,596
Page 1 of 3 1 2 3
High Oil Consumption need help #5237379 10/11/19 08:07 PM
H
Henus Offline OP
H
I have a 2012 Honda fit that seems to consuming oil. Every two weeks I check my dipstick it is at the half mark. I live in the Caribbean where the temperature is hot. I experimented with alot of different oils mainly synthetic blend and full synthetic . I even used 20w 50 to top it up and it still consumes the oil. I have no obvious leaks, no smoke, and vehicle performs just the same. The weird thing is that no matter the amount of kilometers I travel the oil is still at the half way mark after two weeks. any recommendations? Also I checked 3 mechanics and they didn’t recommend engine overhaul only to top it up and watch it
Re: High Oil Consumption need help [Re: Henus] #5237390 10/11/19 08:14 PM
A
atikovi Offline
A
That's what I would do. $10 a month for oil (plus you don't need to change it anymore) vs. thousands for engine work on a $5,000 car.
Re: High Oil Consumption need help [Re: atikovi] #5237395 10/11/19 08:23 PM
H
Henus Offline OP
H
Yes thats what i have been doing for over a year now.
Re: High Oil Consumption need help [Re: Henus] #5237398 10/11/19 08:27 PM
T
tundraotto Offline
T
Check the pcv valve and maybe just change the filter when you would change the oil....
Re: High Oil Consumption need help [Re: tundraotto] #5237400 10/11/19 08:28 PM
H
Henus Offline OP
H
Ohh forgot to mention that changed the pcv valve too already
Re: High Oil Consumption need help [Re: Henus] #5237402 10/11/19 08:28 PM
P
paoester Offline
P
Assuming you are checking the oil in the morning before driving it, and on level ground each time, you could try this:
https://www.bobistheoilguy.com/foru...mium-blue-restore-10w-30-in-a-honda-2-4l
which is something very serious which dissolves carbon on the piston rings since its a common issue with some 6+ year old engines.
But before you use that stuff---->
You mentioned it was always at the halfway point on the dipstick. Does it continue to get lower on the dipstick, like below halfway to the lower line or other mark on the dipstick? It is perfectly safe to run the engine halfway on the dipstick, no problems with that. It is fine, as long as it doesn't get much below the lower line, like 8 mm below the bottom line, no lower than that, estimated. (The oil pickup is very low in the sump.)
Also, do you ever see bubbles on the dipstick right after running it at the full line? Bubbles indicate it is hitting the crankshaft, which would cause some oil consumption, and means it is over-filled there. I mention that in case the wrong dipstick, of the wrong length, maybe from another Honda, was accidentally put on the engine at some point.
Re: High Oil Consumption need help [Re: paoester] #5237403 10/11/19 08:34 PM
H
Henus Offline OP
H
Always top it up once it reaches there never observed to see if it gets lower. And never yet observed bubbles.
Re: High Oil Consumption need help [Re: Henus] #5237405 10/11/19 08:38 PM
P
paoester Offline
P
It might stop going down at the halfway point. Maybe! I remember Nissan told their GTR owners a while back to always race the car with oil halfway on the dipstick, not full, since they saw it sloshed too much and consumed more oil the more full it was.
Re: High Oil Consumption need help [Re: paoester] #5237409 10/11/19 08:43 PM
H
Henus Offline OP
H
Good idea considered that once but afraid to do so...dnt want to take any chances.
Re: High Oil Consumption need help [Re: Henus] #5237419 10/11/19 08:49 PM
J
JamesBond Offline
J
I had a 4 cyl dodge minivan that would burn oil from the top of the dipstick to halfway in a couple hundred miles and then it wouldn’t burn a drop in the next few thousand miles. It took me a while to realize this as I would usually try to keep it full so I was always topping it off.
Re: High Oil Consumption need help [Re: Henus] #5237421 10/11/19 08:49 PM
P
paoester Offline
P
I do that too. Checking it once a week is probably often enough to catch it getting too low. An engine can probably get 2 quarts low (in a 5 quart sump type engine) without losing oil flow and pressure.
I've heard that. Like Henus, I've rarely tested it since I'll top it off in a hurry if its down much. We can call it the "Nissan GTR Effect" since Nissan says: "Engine oil maintenance
. When the vehicle is delivered, the
engine oil level is 0.39 in (10 mm)
below the H mark on the engine oil
dipstick for optimum high performance driving. The engine oil can be
filled up to the H mark if not engaging
in performance driving."
Re: High Oil Consumption need help [Re: Henus] #5237448 10/11/19 09:21 PM
H
Henus Offline OP
H
Ok thanks. Just going to keep on watch it and top up with only 10w 30.
Re: High Oil Consumption need help [Re: paoester] #5237451 10/11/19 09:24 PM
Dinoburner Offline
Wifes `16 Equinox settles to half way on the stick and stays there til the next OC. Fine with me.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: High Oil Consumption need help [Re: Henus] #5237485 10/11/19 10:15 PM
J
Jethro_Bob Offline
J
If it stops at halfway no mater how many miles you drive, why not keep checking it without adding oil for a few days. Just wait and see how long it takes to get to the add mark.
Re: High Oil Consumption need help [Re: Henus] #5237488 10/11/19 10:22 PM
G
geeman789 Offline
G
I have a 2012 Honda Fit that seems to consuming oil ...
A 2012 Fit with how many miles on it ... ?
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Page 1 of 3 1 2 3
