Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
104 registered members (71Chevyguy, 53' Stude, 97tbird, 14Accent, 97K15004WD, 4WD, 8 invisible), 2,876 guests, and 55 spiders.
Topics305,851
Posts5,281,423
Members71,525
Modded my Stormcat generator. #5237182 10/11/19 03:56 PM
B
BSeward Offline OP
B
I posted previously about the brand new Harbor Freight generator I swapped for. Being the tinkerer that I am, I couldn't leave it alone.. Right after I got it, I followed advice I'd read and changed out the plug and cap for NGK items. At the same time, I added a fuel filter and better quality fuel line. An hour meter came next, one of those small digital ones that wrap a thin wire around the plug wire.
I've got about 8 hours on the generator, running a 40:1 mix for break in. It runs and starts like a champ.
Still tinkering, I went onto EBay and found a neat little 0-500VAC digital meter. For a dollar and a half. It got here yesterday, so I started figuring out where to put it, and how to hook it up.
I took the tank off, and found the perfect spot for it. Directly to the left of the off-on switch. Drilled a 7/8" hole in the panel and it fit perfectly. Wiring it was even simpler. I cut the 2 red wires, and spliced the meter wires in, secured with a couple wire nuts.
I started the unit up, and was getting voltage readings between 90 and 135 volt, no load. As soon as I put a 600 watt heater on, the engine ran very smoothly, and the meter read a rock solid 117 volts. Turning the heater to 900 watts saw a pretty steady 105-110 volts, and trying the 1500 watt setting made the unit run like crap and produced wildly varying voltage around 80 volts.
Husky 22V46 mower.
TroyBilt snowblower. RIP.
Ariens 5522 snowblower.
Power Smart 4 stroke trimmer.
1985 Yamaha Vmax motorcycle.
2002 Yamaha Roadstar.
2011 Kia Soul.
Re: Modded my Stormcat generator. [Re: BSeward] #5237183 10/11/19 03:59 PM
M
maxdustington Offline
M
That's cool. I love small nerd mods like that.
You should swap the wire nuts for butt connectors, wire nuts are not meant for vibrations or really any non-construction use.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Modded my Stormcat generator. [Re: maxdustington] #5237188 10/11/19 04:03 PM
B
BSeward Offline OP
B
Yeah, I know.. They're there until I break out the soldering gun and heat shrink tubing and do it right. Just wanted to see if it worked.
Husky 22V46 mower.
2011 Kia Soul.
Re: Modded my Stormcat generator. [Re: BSeward] #5237276 10/11/19 05:38 PM
J
JTK Offline
J
Is this installed on that little 2-stroke genny you got?
I've never seen one of those rated up to 1500W
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Modded my Stormcat generator. [Re: BSeward] #5237293 10/11/19 05:58 PM
B
BSeward Offline OP
B
Yes, it is, and I knew I was running it way over its rated output, only for a few seconds. No way I'd run anywhere near that wattage for more than a couple of seconds.
Husky 22V46 mower.
2011 Kia Soul.
Re: Modded my Stormcat generator. [Re: BSeward] #5237407 10/11/19 08:40 PM
9
92saturnsl2 Offline
9
I have one of these little 2-stroke generators, bought it in 2011. Still works good, can run at rated power for hours on end; a full tank of gas is good for about 4-5 hours.
I use it to run my fridge/freezer (uses about 800W) for longer duration power outages. Sometimes it can require quite a few pulls to start when stone cold, but other than that, no complaints!
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Modded my Stormcat generator. [Re: BSeward] #5237474 10/11/19 09:57 PM
Donald Offline
You need a Hz meter to show that, and how about a small oscilloscope to show the sine wave (or lack of)?
And make it WIFI capable so you can see all these things on your phone.
2015 Ford F-250 w/Powerstroke
Re: Modded my Stormcat generator. [Re: BSeward] #5237704 10/12/19 10:11 AM
Cujet Offline
I broke the fuel shut off valve on mine. Might want to upgrade that too.
Mine makes rates power without issue, but voltage sags badly and rpm decreases with any excess load.
Even so, mine has been tasked with running halogen lights at an Airshow. It ran at rated load every night for the week. No issues at all. Fuel burn was Not bad at all. About a gallon per night
Re: Modded my Stormcat generator. [Re: Cujet] #5237718 10/12/19 10:30 AM
B
BSeward Offline OP
B
Here's a pic of the meter mounted on the Benny, 600 watt draw.
Husky 22V46 mower.
2011 Kia Soul.
Re: Modded my Stormcat generator. [Re: BSeward] #5237800 10/12/19 12:36 PM
J
JTK Offline
J
I've got the same one. Actually just gave it to my brother. Anyway, Just to try, I plugged a space heater into it once. It would run it on low. Once I switched the heater to high it just stalled the little generator out.
Re: Modded my Stormcat generator. [Re: BSeward] #5240825 10/15/19 10:45 PM
J
jakewells Offline
J
on the top of the carb on the right side next to the throttle lever is a round metal plug behind that is the mixture screw for the carb.
2001 Mercury Cougar base 2.5l CD4E automatic.
