Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
110 registered members (2015_PSD, another Todd, aquariuscsm, 4WD, 53' Stude, Anduril, 6 invisible), 2,171 guests, and 53 spiders.
Topics306,138
Posts5,288,229
Members71,608
Hi Tack glue? #5237138 10/11/19 03:25 PM
E
Eddie Offline OP
E
I have some wallpaper that is come loose right at a tile edge. I am looking for some type of glue that will hold immediately when I bond the wallpaper to the wall. Ed
2014 CX5 Touring 2.5L :-)
Re: Hi Tack glue? [Re: Eddie] #5237181 10/11/19 03:56 PM
M
maxdustington Offline
M
Contact cement for immediate bond, but I would use superglue and hold it/ tape it. You can get superglue in single use syrettes that are perfect for small jobs like this one. Superglue sets up pretty fast even without an accelerator.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Hi Tack glue? [Re: Eddie] #5237189 10/11/19 04:04 PM
E
Eddie Offline OP
E
I have about a 2&1/2 foot section that needs fixing so I will look for some Contact cement. Thanks maxdustington
Re: Hi Tack glue? [Re: Eddie] #5237222 10/11/19 04:36 PM
T
tcp71 Offline
T
Superglue doesn’t bond well to porous materials, like wallpaper and drywall. Contact cement, or, if it doesn’t need to be instant, RTV sealant, for humid environments like bathrooms.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Hi Tack glue? [Re: tcp71] #5237233 10/11/19 04:46 PM
M
M
You are correct, but there is a good chance the wallpaper adhesive is still on the wall that would act as a sort of....drywall sealant. You could always paint the exposed drywall and then glue it if it tore away cleanly. I'm not sure if RTV is the same as construction silicone adhesive/sealant, I've seen mirror installers with caulking gun tubes of actual RTV instead of the clear silicone you can buy at home improvement stores. Either way it would be much easier to brush a thin layer of contact cement than try to smooth a bead of silicone on a piece of wallpaper that is still attached to the wall.
PUP 5W30/Ultra
Re: Hi Tack glue? [Re: Eddie] #5237477 10/11/19 10:05 PM
J
jalf Offline
J
I live in an old Victorian house and have wallpapered probably 25 rooms in my life. Regular Elmer's white glue works well enough for reattaching loose paper. Or you can look for a product commonly known as "vinyl on vinyl" adhesive. It's nothing more than thick Elmer's white glue. It's meant for attaching wallpaper border to wallpaper. In your situation, lift up the loose wallpaper carefully, then, using a cheap 1-inch paint brush, thinly apply the white glue to both the back side of the wallpaper and the wall itself. Press the paper against the wall, then use a hard rubber roller to work out any air bubbles. Sponge off any excess glue that emerges at the seams. It should set up nicely in an hour or two. The advantage of white glue vs. contact cement is that the latter might tend to clump up, whereas the former distributes more evenly. You could also use clear cellulose wallpaper paste, but it's getting harder to find as fewer homeowners hang wallpaper anymore.
2015 LaCrosse 26,000
2009 Outback 86,000
2002 Corolla 101,000
5W30 X 3. The Buick gets the pricey oil.
