Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
122 registered members (2003f7, 97prizm, 14Accent, 87sammy, agarb, 4WD, 13 invisible), 2,486 guests, and 48 spiders.
Topics305,921
Posts5,282,780
Members71,537
Page 1 of 3 1 2 3
Frequent Redline #5237070 10/11/19 02:28 PM
A
Al Online Content OP
OP Online Content
A
At least a couple times per week I bounce my 19 Crosstrek off of the redline a couple times. I have done it since the vehicle had a couple hundred miles on it. The vehicle has 5000 miles on it now and uses no "detectable" oil. I also do it to my 18 Forester XT again since new. Again no oil use after 14K miles.
Anyone else do this? I can't say if it will help with a DI engine but I do know that since the XTis the wife's vehicle. She drives like a little old lady, which she is. It was a couple thousand miles that I didn't do it...there was much black smote. The day after I really hit it hard..there was no smoke. LOL
Re: Frequent Redline [Re: Al] #5237087 10/11/19 02:45 PM
E
Eddie Offline
E
Let us know how that works out for you after 150,000 miles or so. Ed
2014 CX5 Touring 2.5L :-)
Re: Frequent Redline [Re: Al] #5237089 10/11/19 02:47 PM
skyactiv Offline
My GTI has a stick and I take it to 6800 RPM every time I drive it. The car has 166K on it. I add 1/2 a quart of oil around 4K miles. My wife drives pretty hard, too.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Frequent Redline [Re: Eddie] #5237096 10/11/19 02:49 PM
SubieRubyRoo Offline
Works out fine. I redline my vehicles at least 2-3 times each way to work and back, I was especially hard on my 2011 Fusion, and ran OCIs out as far as 17k. Never once did the iron numbers get above 1.2ppm/1k miles traveled, and I never in the 117k miles I owned the car had to add any oil in between oil changes.
My current Subarus I redline every time I pass someone on two lanes (mostly because you have to if you want to live) and neither of them burn oil either. Use a good oil, don't beat the crap out of the engine until coolant and oil temps are above 150* and there is no reason anything untoward should happen from using an engine as it's designed.
De omnibus dubitandum.
Re: Frequent Redline [Re: Eddie] #5237099 10/11/19 02:53 PM
K
kschachn Offline
K
My ECHO spends a lot of time at or near redline due to the tiny engine. Working great so far at over 280K, probably the lowest consumption of any of my old cars.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Frequent Redline [Re: Eddie] #5237113 10/11/19 03:04 PM
Donald Offline
+1 but on 100,000 miles.
2015 Ford F-250 w/Powerstroke
Re: Frequent Redline [Re: Al] #5237124 10/11/19 03:14 PM
Skippy722 Offline
I do it as well. 300 or van it doesn’t matter. I paid for the entire rpm range all the way to redline, I’m using it! LOL
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Frequent Redline [Re: Al] #5237134 10/11/19 03:21 PM
dailydriver Offline
I take mine up to just below the rev limiter every time it is warm enough to do such, a couple of times a day. drive
This engine does not eat a single drop of oil whatsoever, but yeah, it only has ~22K miles on it so far.
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Frequent Redline [Re: SubieRubyRoo] #5237148 10/11/19 03:32 PM
CELICA_XX Offline
Yeah, but it's just unnecessary / avoidable wear.
... and I drive a 100 horsepower car as my commuter!
No need to bounce off anything
20 Toyota RAV4 Hybrid - factory 0w16
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: Frequent Redline [Re: Al] #5237156 10/11/19 03:39 PM
B
buster Offline
B
I used to think that was bad for engine but I no longer do. You'd be surprised how many people that have cars over 200k + miles that give it a redline every day. Sustained high rpms are a different story and that is where you'll see higher wear rates. When you think about it, when you floor it it's only at the high rpms from a small amount of time.
Re: Frequent Redline [Re: Al] #5237186 10/11/19 04:03 PM
M
maxdustington Offline
M
Italian tune up!
My old Jetta used to consume A LOT of oil (around 1L/1300km). The trans started slipping so I had to wind it out a lot, and the oil consumption reduced dramatically.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Frequent Redline [Re: Al] #5237190 10/11/19 04:04 PM
F
Fawteen Offline
F
I've never driven any vehicle I've owned like that on a regular basis-other than the occasional merging onto a highway or interstate they all get driven pretty sedately. I've never felt the need to flog a vehicle like that.
The only one I can ever remember using any significant amount of oil is a 70's vintage Ford pickup with a 351 in it, and it was only a quart or so between changes. Everything I've owned in the past has always gone at least 100,000 miles, most of them more than 150,000 miles, and a couple over 200,000 miles without any abnormal engine issues, and every one of them was running without issues when it was sold or traded.
I would be seriously concerned about any engine that only has 14,000 miles on it that was blowing "much black smoke" no matter how it was driven.
Re: Frequent Redline [Re: Eddie] #5237308 10/11/19 06:20 PM
W
Ws6 Offline
W
So far the only vehicle's I've taken to 150K miles were flogged relentlessly that were performance oriented were my 1995 and my 2001 Trans Am's. They both did amazing, engine wise! The diff on t he '01 WS6 did give out ,though, but really, it's a known issue. The transmission was doing alright except for the T/O bearing, which I replaced and noted the clutch had a LOT of life left, at 80K, and reverse's syncro was starting to really suck (a known issue with the T56). The 1995 Trans Am had the transmission destroyed at 120K miles before I bought it, as well as an axle sheared in half (neutral drops, I bet...). It went to 170K miles for me, with just a heater core replacement. Both engines were running strong with very minimal oil consumption, and no smoke. The LS1 burned the same amount from 70K miles when I bought it, to 150K when I sold it. About 1/4 quart per 4K miles. Both ran amazing the day I got rid of them.
Now, the other cars I have experience with, a G20 (SR20DE), I took to 145K miles, and it was fine 100% except the transmission went out a few k after a fluid drain/fill at 115K miles. IT wasn't acceleration induced failures. I flogged it relentlessly, too. Ran great.
Multiple police cars, my Dad and I b eat the [censored] out of them, AFTER the PD's did for 60K miles. We averaged about 220K miles out of the 4.6L mod motors. By then they were using a fair amount of oil where you poured a quart in at every fill-up. Pretty lame. Not a Ford fan.
My 2015 CX5 constantly got t he stick. Everything was flawless to 106K miles when the fuel pump and fpr both died at the same time, 5 minutes after fuelling up...also a diff I flooded during a stream crossing at flood stage. Neither have anything to do with WOT usage.
I guess in short, I have not yet found a problem with going WOT in a vehicle, ESPECIALLY from a roll where the diff,etc. isn't stressed.
Maybe it's after the 200K mile mark that it matters? Oh, well. So much more that can go wrong with a car than the drivetrain to worry about that, specifically.
Re: Frequent Redline [Re: Fawteen] #5237328 10/11/19 06:49 PM
A
OP Online Content
A
I am really not bc it was driven like a little old lady for a couple thousand miles on short trips. Now that I blow out the carbon every couple weeks. Its fine. And I have another 66K miles of warranty on it. I intend to keep each car less than 8 years.
Sounds like I am not alone. Its quite enjoyable. No downside that I can think of.
Quote
The SR20DE was one of the best engines ever made. Mine consumed to a traffic accident at 165K miles after I gave it to family. Used no oil at that point. I thrashed it hard on occasion.
Re: Frequent Redline [Re: Al] #5237376 10/11/19 08:01 PM
T
The_Nuke Offline
T
For me, a day without WOT is like a day without oxygen to a regular person.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Page 1 of 3 1 2 3
