Walmart Gear Lube in Rear Diff
Been talked to death on here.
But what car man? Flying Saucer landing gear lube?
75W-90 Synthetic is great for light duty diffs.
Last qt I bought was like $5.88
I run it in the Subaru and Nissan rear diff with no issue other than IMPROVED operation.
I dont recall LS compatibility w/o friction mod additive
Warren makes good stuff, under many different private labels, I wouldn't hesitate to use ANYTHING they make, whether it has an ST label, or Mag1, or any other name!
FWIW, drained the transaxle in my high hours John Deere 216 (vintage) lawn tractor and refilled it with ST 75-90 gear lube. Had a small leak before the drain/refill.
Leak stopped!
Originally Posted by Hot_Ajax
I need Supertech 75W--90. Is this stuff decent? Thanks.
I use it in all my diffs. Using the syn 75w-140. Seems better than the M1 75w-90 it replaced.
From another thread I posted.
SupertTech Syn
75w90
100C 16.15
40C 109.3
VI 159
75w-140
40C 27.64
100C 171.8
VI 200
SuperTech Conv
75w-90
100C 13.98
40C 130.9
VI 104
75w-140
100C 26.39
40C 347.7
VI 100
Thanks for organizing that data. Very useful. That conventional 75w140 might be a bit harsh for the -35 C mornings in Saskatchewan this winter.
No thanks for me?
Yes I dinged you BC you didn't list your application.
but ...
I am hurt now...
ST synthetic does contain LS additive per email with Warren Distribution:
"Gary,
You asked about Supertech Gear Oils. They do contain friction modifier which makes them limited slip ready.
Ben Retzer​
Sr. R&D Chemist
(402) 977-5892
[email protected]
950 S. 10th St., Suite 300
Omaha NE 68108
www.warrendistribution.com"
Originally Posted by Snagglefoot
The 40 C vis of 347 seems a bit high for the conventional 75w140.
Yes, it is high but most conv W140's I've checked are 250 or higher.
"Gary,
Ben Retzer​
Sr. R&D Chemist
(402) 977-5892
[email protected]
Omaha NE 68108
Good job.!
Actual firsthand knowledge and response.
Rare in the forum
I though I read it on the bottle too. when I did my subaru diff.
Didnt need FM there but it doesn't hurt too much!
