Originally Posted by FordBroncoVWJeta
Originally Posted by UG_Passat
Also, because a shop has to dismount the tire to do a plug/patch, it means the tire & wheel gets rebalanced also.
We never balance them unless the customer asks us too. We mark the tire in Crayon where the valve stem was and weights. Then put it back where it was. I wouldn't be surprised if DT did the same thing.
'Ime', DT always rebalances the tire after the plug/patch procedure. At least to this point that's how it's been done. Next time I'm in for a rotation and balance, I'll confirm. It is interesting to read how WM does it though.
Since the topic of the tire removal plug/patch procedure has been discussed this sub-forum recently, I've noticed some things. The procedure afaik initially came under the RMA, Rubber Manufacturers Association. It appears that RMA is now USTMA, US Tire Manufacturers Association and assumes same roll for the plug/patch repair. The specific USTMA procedure can be on the GY site
in this pdf.
I also noticed that according to some experts
in this recent thread that the USTMA procedure is done if not solely, primarily for "cosmetic" reasons. That being the case, someone needs to inform tire establishments like Discount Tire, Costco, WM, Goodyear and many
others that they doing the USTMA primarily for cosmetic reasons. I imagine they all could save a lot of money and time if they only knew. It's on the internet, so it must be true.
