G Gebo Joined Sep 18, 2002 Messages 6,056 Location VA Oct 11, 2019 #1 What is the temp range needed to check the ATF fill on a 2009 Toyota Highlander? I have the Scangauge. I found a PDF for all my Lexus but can't seem to locate one that applies to Toyotas.
C CharBaby Joined May 25, 2005 Messages 15,635 Location ROCHESTER, NY Oct 11, 2019 #2 Try looking it up under an '09 Lexus RX350.
G Gebo Thread starter Joined Sep 18, 2002 Messages 6,056 Location VA Oct 11, 2019 #3 Char Baby, that is a most excellent idea. I follow you but I just looked at my Lexus chart and it only goes to '08
C CharBaby Joined May 25, 2005 Messages 15,635 Location ROCHESTER, NY Oct 11, 2019 #4 Hmmm sorry 'bout that. However, the '08 RX may be the same as an '09?!?! IDK! I think the major change came in 2010? CB Last edited: Oct 11, 2019
G Gebo Thread starter Joined Sep 18, 2002 Messages 6,056 Location VA Oct 11, 2019 #5 They do have same engine and transmission. Genius thought process. I am impressed.
M millerbl00 Joined Feb 11, 2008 Messages 1,183 Location Louisiana Oct 11, 2019 #6 My mechanic says 175F Mine seems to be very sensitive to even the slightest overfill Last edited: Oct 11, 2019
L LotI Joined Jan 1, 2013 Messages 2,057 Location America's Dairyland Oct 11, 2019 #7 It's best to get the correct range...can you ask your dealer politely? Try someone in the parts department that has access. May have to call multiple dealers. The two Aisin's I've worked on were both 35-45C. ‘05 MINI & 19 Buick Regal.
G Gebo Thread starter Joined Sep 18, 2002 Messages 6,056 Location VA Oct 11, 2019 #8 Actually, I'm looking for the PDF Most all the Lexus are between 97-133F or 36-56C I'm thinking 104-113 like Lotl said.
C CharBaby Joined May 25, 2005 Messages 15,635 Location ROCHESTER, NY Oct 11, 2019 #9 Originally Posted by Gebo Genius thought process. I am impressed. Who, me?
G Gebo Thread starter Joined Sep 18, 2002 Messages 6,056 Location VA Oct 11, 2019 #10 Originally Posted by Char Baby Originally Posted by Gebo Genius thought process. I am impressed. Who, me? Who else could it be? ...
