Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Quality filter for 2017 Subaru 2.5 Ltr
by Ishmael - 11/19/19 10:39 AM
Kendall GT-1 Max vs PP
by c5z06 - 11/19/19 10:25 AM
Toyota Sienna FWD in Snow / Ice
by tiredguy - 11/19/19 09:32 AM
7.62 x 39 Top Three?
by CCI - 11/19/19 09:30 AM
MOTUL Specific VW 508.00 Unboxing
by ARCOgraphite - 11/19/19 09:14 AM
dshadow, Hansvoytek, DeltaP71, 300Kncounting, Bill67
69917 Registered Users
111 registered members (2oldtommy, 53' Stude, A310, 92saturnsl2, 2002 Maxima SE, 10 invisible), 1,984 guests, and 23 spiders.
Topics297,642
Posts5,119,884
Members69,917
Most Online3,589
Nov 2nd, 2019
2019 duramax l5p; Delvac 1300 15w-40 3k mi #5236554 10/11/19 03:22 AM
R
Robm626 Offline OP
R
Hey guys. I have a new 2019 duramax l5p and my oil life indicator has been dropping much faster than I’m used to. I’m lucky if I get 3000-3500 miles on an oil change. Also the last sample I had tested came back higher copper. Any idea what would cause that? I just changed the oil again at 8166 miles and sent the sample in. I will post new report next week when it comes in. This report is my last 2.
Attached PDF document
Re: 2019 duramax l5p [Re: Robm626] #5236555 10/11/19 03:31 AM
demarpaint Offline
With only 5,000 miles on the truck I wouldn't panic just yet. What are the oil cooler internals made of on that truck? If copper, that could be the source and it can take quite a while to wash out. The numbers might rise and fall in the process. Stick with the shorter OCIs for a while would be my suggestion, and continue to monitor.
God Bless Our Troops
Re: 2019 duramax l5p [Re: demarpaint] #5236564 10/11/19 04:05 AM
R
Robm626 Offline OP
R
I’ve heard in previous generations they were copper but I wasn’t sure for mine so I figured I’d ask. The oil life monitor however is boggling my mind. 3,000 miles and down to 0% on a diesel is weird to me. And my idle times aren’t that long either. 325hrs on the truck. I figured I should be getting 5,000 mile intervals with my amount of hours
Re: 2019 duramax l5p [Re: Robm626] #5236580 10/11/19 04:42 AM
B
BlakeB Offline
B
It’s a software problem and GM knows about it. Change your oil every 7,500 miles, 300 engine hours or once per year.
TSB #PIP5629
Re: 2019 duramax l5p [Re: Robm626] #5236585 10/11/19 04:51 AM
demarpaint Offline
2019 and there are still some issues with the OLM, as indicated by the TSB above. Don't feel bad, I posted about my Liberty OLM telling me the oil needed to be changed at 2,451 miles into the interval. Typically it was wrong stating to run the oil too long. I ignore mine, and have done so since the vehicle was new. I suggest keep doing what you're doing with UOAs. Find an OCI you're comfortable with based on the UOA data and ignore the OLM. hide Some people swear by them, some swear at them, and some ignore them.
Re: 2019 duramax l5p [Re: BlakeB] #5236592 10/11/19 05:09 AM
R
Robm626 Offline OP
R
Thank you! I’ve been searching around multiple forums for a TSB on the matter. I’ve seen other people had the same issue but I wasn’t sure if GM changed the programming on purpose or by accident. l5p still is a pretty new motor and I was thinking maybe they know something we don’t which would make them want the oil changed sooner. I’m going to start going by hours. More than 50% of my driving is city driving so I think hours would be the better option.
Re: 2019 duramax l5p [Re: demarpaint] #5236593 10/11/19 05:10 AM
R
Robm626 Offline OP
R
Thank you. I guess I’m gonna start to ignore it until they come up with a fix maybe
Re: 2019 duramax l5p [Re: Robm626] #5236595 10/11/19 05:11 AM
Donald Offline
Get a UOA and see the real condition of the oil.
2015 Ford F250 w/Powerstroke
Re: 2019 duramax l5p [Re: Robm626] #5236610 10/11/19 05:44 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I don’t think the first few OCIs being shorter when new is a bad thing, especially in a diesel.
Software glitches are another thing, but I wouldn’t be going full length OCI the first few anyway... I’m not a “change immediately” person, but when you’re doing it seems good.
Re: 2019 duramax l5p [Re: JHZR2] #5236634 10/11/19 06:12 AM
demarpaint Offline
thumbsup
thumbsup
Re: 2019 duramax l5p [Re: Robm626] #5236645 10/11/19 06:32 AM
B
BoiseRob Offline
B
Personally, I would take it to the dealer to have a record of it in the VIN file so "IF" there's a warranty problem down the road, GM can't deny it due to not changing the oil. I've heard there's a flash fix for the trucks with this issue which causes the OLM to go to mileage based...
2007 Chevrolet Silverado 2500HD LBZ Duramax
2016 Jeep Grand Cherokee Ecodiesel
Re: 2019 duramax l5p [Re: Robm626] #5236963 10/11/19 11:36 AM
W
wensteph Offline
W
The copper is oil cooler oxidation. Don't worry about it. My 2019 Duramax dropped from 500 on the first UOA to 139 on the second one.
Re: 2019 duramax l5p [Re: wensteph] #5237009 10/11/19 12:24 PM
R
Robm626 Offline OP
R
Thanks. I thought that’s what it could be but mine went up between first and second. I should have the third results back next week. I’ll post results
Re: 2019 duramax l5p [Re: BoiseRob] #5237011 10/11/19 12:24 PM
R
Robm626 Offline OP
R
I’ve been trying to find time to go to the dealer. Thanks
Re: 2019 duramax l5p [Re: Robm626] #5241655 10/16/19 05:41 PM
A
A_Harman Offline
A
And if I remember correctly, the L5P oil cooler is larger than the previous Duramax's, so it would have more Copper to shed.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
