1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
97 registered members (2oldtommy, 77GrandPrix, Ag76, ammolab, 2015_PSD, 4WD, 5 invisible), 2,143 guests, and 36 spiders.
Topics306,139
Posts5,288,240
Members71,608
Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage #5236548 10/11/19 03:36 AM
The Critic Online Crying OP
OP Online Crying
2013 Mazda 3 2.0L Skyactiv with 98.6K miles. The oil control valve (OCV) had been seeping oil for the last 20-30K miles and I finally had time to repair it. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4951986/all-mazda-3-s-have-bad-ocv-s
The “seal” is actually a soft, stepped rubber sleeve (with a metal retention ring at the base) that is pressed into the valve cover itself. When the valve cover is removed, the oil control valve remains bolted to the valvetrain. To remove the sleeve, you simply push the sleeve out of the valve cover (from the outside). A new sleeve gets pushed into place via the backside of the valve cover, which is why valve cover removal is necessary to replace the OCV seal/sleeve.
The old seal/sleeve was not torn, it was just slightly harder than the new one. I am not sure if installing the new sleeve will fix the oil seepage; buster’s dealer did the job several times and ultimately installed a new OCV in addition to replacing the seal/sleeve. No TSB’s were found. We shall see if this fixes the problem. MSRP for the valve cover gasket and OCV seal/sleeve from Mazda was $59.39.
388D55A6-2D76-4E02-97A0-B60022206B8F.jpegF8DD4488-E165-4181-9741-104DC8162710.jpeg3FF93B69-6BD3-474C-83B0-EA1E7056A1A3.jpeg1F6D6FE6-B99C-4AC6-8827-393D34BA5AA1.jpeg2138DB0C-3B30-4C6B-9360-9EE4DF128DCF.jpeg5E153E75-2DF0-42BA-AAE8-46C078E8B3B4.jpeg
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236617 10/11/19 06:51 AM
SOHCman Offline
Nice clean engine there!
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236715 10/11/19 08:43 AM
PimTac Offline
Looks great.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236729 10/11/19 08:54 AM
B
buster Offline
B
Looks great. Great engine.
Critic, I'll be curious if this fixes it. My case was a bit unusual. What ultimately fixed it was a new valve cover. I originally brought the car in for the parking brake recall. While there, they rushed to also fix the OCV and didn't properly seal the valve cover. I had to take the car back and in doing so they replaced valve cover which finally fixed the issue.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236749 10/11/19 09:13 AM
P
paoester Offline
P
Is that OCV for the variable valve timing hydraulics? And does this engine have variable valve lift?
Wonder if just a little coating (not much) of silicone rubber RTV gasket stuff around the rubber seal would seal it enough. ... Or is that considered more like a duct-tape style of fixing cars?
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236914 10/11/19 11:50 AM
bdcardinal Online Content
Online Content
I wish Mazda would sell that seal with the valve cover gasket. It would make my life a lot easier.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5236931 10/11/19 12:14 PM
B
buster Offline
B
It's either a poorly designed part, or the crankcase pressure is the issue. You'll find some that weep with only 30k miles. Still a fantastic engine if that's the only thing wrong with it.
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5237229 10/11/19 04:42 PM
P
pezzy669 Offline
P
Are those oil squirters for the cam lobes I am looking at? Don't know if I have seen that before.
2016 Volkswagen e-Golf SE - 59k
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5237247 10/11/19 05:00 PM
wemay Offline
That looks great!
2019 Volkswagen Passat Wolfsburg TSI: VW OE 0W-20, OE o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: pezzy669] #5237258 10/11/19 05:16 PM
Online Content
Mazda calls them "pipe, oil" p/n's PEDD-14-280 and PEDD-14-290.
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5260004 11/06/19 03:47 PM
OP Online Crying
Update:
I meant to update this thread a while ago. After a few days of driving, the area was rechecked. Unfortunately it appears that the leakage is coming from the oil control valve itself; the seal/sleeve may or may not have been leaking.
As you can see in the picture, the oil is leaking out from between the electrical portion of the valve and the metal housing itself. From my limited testing, leaking is most prevalent if the engine seems high-rpm conditions.
A new valve is $200+ from Mazda.
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5260008 11/06/19 03:59 PM
Mr Nice Offline
So it’s a simple ‘pop out old part’ and insert new valve ?
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: The Critic] #5260014 11/06/19 04:05 PM
PimTac Offline
Have you checked shopmazdaparts.com?
It looks more like a nuisance based on the photos but I am guessing it will get worse over time.
2017 Mazda CX5
Roki OEM filter.
Re: Repair: Mazda 3 2.0L Skyactiv Oil Control Valve Oil Seepage [Re: PimTac] #5260026 11/06/19 04:23 PM
OP Online Crying
Yes, but the valve cover has to be removed.
More of a nuisance than anything else; it won't leak enough oil to run off of the valve cover.
I don't think the owner is going to spend money to fix a non-critical issue, so this one may not get resolved.
