4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
92 registered members (97tbird, alchargo, aquariuscsm, 14Accent, aba4430, 2009Edge, 10 invisible), 2,702 guests, and 38 spiders.
Topics305,846
Posts5,281,365
Members71,525
Oil recommendation for engine storage. #5236412 10/10/19 09:49 PM
B
Boosted240 Offline OP
B
Is there something that "clings" well to engine internals over time, up to a year or more?
I have a few cars and motors that sit around in storage for long periods. On one vehicle with a Nissan SR motor, I started using some Amsoil Z-Rod 10W30 a couple years ago. I typically have the motor started up again within 7 months after being in storage over winter. This year I did not get around to it until about 13 months. I ran into issues getting oil pressure on the first start because the oil pump had lost it's prime. Luckily I was cranking with the plugs removed. I tried about 4 times cranking for 10-15 seconds with no luck, this was strange to me because typically in the past I would get pressure within 5 seconds, so I stopped. I removed the oil filter and using a filter bypass adapter block, was able to pour some oil into the filter housing so it could drain down and wet the oil pump gears. That did the trick and my oil pressure was back within 10 seconds of cranking.
Now I know a pre-oiler or accumulator (like an Accusump) would be ideal in my situation. But as for an oil, is there something better I could be using? Heavier/lighter? Especially to protect components during extended crank times with no oil pressure?
Thanks all!
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236419 10/10/19 09:55 PM
Chris142 Offline
Cranking it may take a while to get oil pressure. I bet that if you just started it that the oil pressure would come up immediately.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236447 10/10/19 10:33 PM
Z
Zolton Offline
Z
HDEO or Marine oil. Maybe fog it too.
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236467 10/10/19 11:06 PM
T
Trav Offline
T
Years ago Hein Gericke, Polo and other bike shops sold winter storage oil, it was basically a cheap heavy dino oil with no add pack to speak of so I would guess a heavy single grade oil with some thick snot like the old STP in the mix..
I did pull the rocker box off one engine a year after this stuff was put in and it was still hanging on the cam lobes.
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236504 10/11/19 12:16 AM
R
rubberchicken Offline
R
+1 on the marine oil- rumor has it that there is some extra anti-corrosion additives. You might consider using storage fogging oil in the cylinders . A can runs around $12 at marine supply stores, or www.wholesalemarine.com, or Amazon.
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236511 10/11/19 12:44 AM
N
nthach Offline
N
No oil you can buy will cling to engine parts for a long time - maybe Magnatec, Red Line or Cummins Premium Blue Restore due to the fact they are ester based.
Your best bet is to spray fogging oil through the intake and then treat each cylinder individually. Wouldn't hurt to close off the intake and exhaust.
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236623 10/11/19 06:57 AM
M
MetalSlug Offline
M
Mobil 1 , it’s well known for long term storage owner.
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236631 10/11/19 07:05 AM
E
Eddie Offline
E
I think any oil that you normally use is just fine for a least a year. If your concerned about dry starts, then pull the fuel pump fuse and crank the engine for 5 to 10 seconds to get oil flowing. Replace fuse, start and enjoy. Ed
2014 CX5 Touring 2.5L :-)
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236640 10/11/19 07:20 AM
L
ledslinger Offline
L
Re: Oil recommendation for engine storage. [Re: Boosted240] #5236969 10/11/19 12:40 PM
DavidJones Offline
Fire it up. That one start will make no difference.
My garage.....2012 Toyota Highlander (wife's), 2016 Ford 2.7EB F150(mine), 1969 Pontiac GTO, 2005 Double cab Tundra(son), 2015 Honda Accord EX(son).
