Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
Selling my dump trailer
by Sunnyinhollister - 12/15/19 11:43 AM
Motorcraft 5W-20 canada
by xXF150Xx - 12/15/19 11:40 AM
Brake caliper pins
by Donald - 12/15/19 11:14 AM
Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
xXF150Xx, NCBuckeye, Maik, Pluckster, DerekPho
70131 Registered Users
93 registered members (alchargo, 53' Stude, AC1DD, austinlunsford, Aredeeem, andyd, 9 invisible), 2,129 guests, and 26 spiders.
Topics298,832
Posts5,142,278
Members70,131
Most Online3,589
Nov 2nd, 2019
Page 1 of 5 1 2 5
Brake Fluid Change #5236171 10/10/19 04:49 PM
Z
ZeeOSix Offline OP
Z
I was looking in my 2005 Tacoma Owner's Manual and there is no mention at all about changing the brake fluid. Wondering if other car makers call it out in their maintenance schedule?
I know most motorcycle manuals call out a brake fluid change in the maintenance schedule to be performed every 2 or 3 years.
So my 2005 Tacoma (only has 50K miles) still has the original brake fluid, and it still looks new (color wise) in the clear brake fluid reservoir. But I'm going to change it out anyway since it's really old. Probably should have did it years ago.
Changing brake fluid is probably even more neglected by car owners than changing coolant. eek
Re: Brake Fluid Change [Re: ZeeOSix] #5236186 10/10/19 05:06 PM
Z
zfasts03 Offline
Z
Change it!
I would change it every 2-3 years. 5 years max. Brake fluid is hydroscopic. Especially in humid/moist locations change more frequently.
I use a Mity Vac vacuum extractor and suck it out at the brake caliper bleeders. 1 qt usually does a car, unless it is a Z06 or something with big calipers with two bleeders per caliper. Then get 2 quarts.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Brake Fluid Change [Re: ZeeOSix] #5236187 10/10/19 05:08 PM
K
Kira Online Content
Online Content
K
Is it always right to activate the ABS pump (and valves?) as part of a complete job ?
Re: Brake Fluid Change [Re: ZeeOSix] #5236189 10/10/19 05:11 PM
G
Gebo Offline
G
It seems all my used that were serviced at the dealerships before my ownership had their brake fluid changed on a regular basis.
Funny you mentioned this as I just finished doing the last of mine 5 minutes ago. That bleeder system where you use your front tire pressure is
"THE" bomb! So easy....
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Brake Fluid Change [Re: ZeeOSix] #5236201 10/10/19 05:24 PM
ctechbob Offline
Queue the 'I've never changed it and my car is great' people.
My opinion (What I do)
Every time I change brake pads, or every 18-24 months. When I had my track car it was before and after every event as I swapped pads/rotors to dedicated pieces for the track event.
I will also do it after a spirited drive if I notice I got the brakes particularly hot. Its not hard, and fluid is cheap so I see no reason not to.
2008 Acura TL Type S-155k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Brake Fluid Change [Re: ZeeOSix] #5236223 10/10/19 05:52 PM
SLO_Town Offline
On all my cars I bleed my brakes yearly. I do it during a warm, low humidity summer day. I never activate the ABS while bleeding, but over the course of the year I take advantage of appropriate opportunities to exercise the ABS (e.g. a smooth, out of the way, no traffic, wet road covered with autumn leaves). This moves fluid in and out of the ABS system.
Unless you have a "professional" pressure bleeder, I don't suggest those. Pressure bleeders pump in ambient humidity and contaminate the new fluid (professional pressure bleeders have a diaphragm that separates the pressurized air from the fluid). I've never had success with vacuum bleeders. My wife pumps the pedal for me. I put a block of wood behind the pedal so the pedal does not travel beyond its normal range. I suck the old fluid out of the reservoir and fill with fresh fluid before starting the bleeding process. I use a full liter of fluid per car to insure a full flush.
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (BMW TPT 5W-30)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Brake Fluid Change [Re: ZeeOSix] #5236236 10/10/19 06:04 PM
Dave9 Offline
^ Sure but the never changed it and my car is great people are probably 95% of the population, just not as much on automotive forums which emphasize token gestures towards vehicle maintenance. If there is one thing this site, like some others, is known for, it is overkill, making mountains out of mole hills.
Manufacturers do not specify changing it because for "most" vehicles you don't need to. The fluid being hygroscopic means almost nothing in this context. It means you can't leave a bottle open or use most of it, let it absorb ambient moisture then use the rest later. It does not mean that any significant amount will get into the braking system which being hydraulic is necessarily sealed, unless it is a design that draws in ambient air as it is used out of the fluid reservoir instead of having an expanding diaphragm design to displace the fluid level, which is far more common.
If it makes you feel better to change it often, or if you observe overheating brakes (a sign you need better brakes, or better driving habits, or the vehicle is simply unsuited for the task) then by all means, change the fluid.
If people were having brake failures from not changing it every 2 years, every manufacturer would recommend it and there would be a recall of many millions, decades of vehicles where this was not specified. The last thing a manufacturer would do is get this wrong when it's a service item at the owner's expense if it were needed.
Then again manufacturers now have lifetime transmission fluid, etc. which isn't really true but trannys cost a lot more to fix than brakes once you notice some mushiness hot. The point is that you should consider changing it once in a while, every several years, but you shouldn't have any problem going 5+ years unless the brake system is defective by design and a fluid change won't really fix that.
Re: Brake Fluid Change [Re: ZeeOSix] #5236254 10/10/19 06:23 PM
slacktide_bitog Offline
Honda says to do it every 3 years regardless of mileage. It is not an item on the MM. Just do it every 3 years smile
To my knowledge, Honda is the only non-European mfr to recommend any brake fluid interval at all! Most cars go to the junkyard with their original factory-fill brake fluid
That being said, it's most practical to change the brake fluid when replacing the pads and rotors. This is what I do. Speed bleeders are awesome smile
Re: Brake Fluid Change [Re: ZeeOSix] #5236275 10/10/19 06:37 PM
E
eljefino Offline
E
If you have a defined, working way to bleed ABS, go for it, but I wouldn't do it with "shadetree" methods.
The worst muck hangs in the corners, by your wheel cylinders and calipers. Bleed them and you're ahead of the game.
Siphon your reservoir before you start-- it sees air and water even if it looks okay. Obviously refill with fresh before and after the job.
Re: Brake Fluid Change [Re: ZeeOSix] #5236289 10/10/19 06:49 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I'll do my cars every 2-3 years, but I won't recommend it to my friends who would have to pay for the service. I'll explain the benefits to them. They can decide for themselves whether they should get their brake fluid exchanged.
Re: Brake Fluid Change [Re: ZeeOSix] #5236292 10/10/19 06:50 PM
Z
Zolton Offline
Z
I bleed mine dry, add fluid and close the valves.
Used cars will get a bleed even if brakes look ok. If the fluid looks nasty I'll re-do it in a year.
Otherwise it's plenty enough to just do it when replacing pads.
I noticed the new VW manual says to do first flush at 3 yr, then 2yr subsequent. This is consistent with my thinking that new parts will not even have any corrosion to resist.
[Linked Image from i.imgur.com]
At one point I was told DOT 3 lasts longer than DOT 4 because it doesn't need the high temp character in it's formula, more anti-corrosives can be delivered. This is somewhat consistent with mfg recommendation, where Euros spec 2yr and others spec none.
Re: Brake Fluid Change [Re: Zolton] #5236304 10/10/19 07:01 PM
ctechbob Offline
Wait, what?
Trans-Idemitsu H+
Re: Brake Fluid Change [Re: ZeeOSix] #5236311 10/10/19 07:09 PM
Z
ZeeOSix Offline OP
Z
I plan on doing the brake fluid change this weekend, so I'll post later what I found when bleeding the brakes.
Still strange that Toyota doesn't say to change the brake fluid anywhere in their maintenance schedule documentation. I even looked at newer Tacoma owner's manuals and maintenance schedule documents (2015-2019) on Toyota's website and it still says nothing about changing the brake fluid.
Toyota also still specs DOT 3 only brake fluid even on their 2019 Tacomas.
Re: Brake Fluid Change [Re: ZeeOSix] #5236315 10/10/19 07:12 PM
B
BHopkins Online Content
Online Content
B
Bleeding brake fluid on a regular basis is a smart thing to do. More and more manufacturers are recommending brake fluid change as part of their maintenance. As mentioned above, brake fluid collects moisture, and when it does, it becomes even more corrosive, and can destroy brake system components.
I bleed mine every 30k miles using a Motive brake bleeder, which is about every 2 years. The 3 year cycle that Honda recommends would be a good schedule too. But I personally wouldn't recommend a schedule much longer than that.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Brake Fluid Change [Re: ZeeOSix] #5236320 10/10/19 07:18 PM
B
BISCUT Offline
B
In the past I drained and filled the reservoir before I realized that was futile. I now do a bleed at the caliper at each pad/rotor change and leave it at there. Much better process.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(40k)
2017 Sub OB M1 5-30 EP FRAM Ultra(70k)
Page 1 of 5 1 2 5
