Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
23 registered members (bbhero, ChrisD46, ctechbob, 4WD, Darren_L, dixon66), 727 guests, and 55 spiders.
Topics306,079
Posts5,286,969
Members71,596
Annyone else having issues with Windows 7 lately #5236157 10/10/19 05:27 PM
007 Offline OP
For years I never had a single problem with my Windows 7 Professional. Now in the last couple of weeks I am having issues with corrupt windows files, disc issues and so on. My surfing habits have not changed which makes me wonder what is going on. Anyone having similar issues??
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236175 10/10/19 05:53 PM
Z
ZeeOSix Offline
Z
Sounds like it could be the hard drive going south. You have any hard drive health checking tools?
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236181 10/10/19 05:59 PM
B
BigD1 Offline
B
Run the windows memory diagnostic. Failing memory will definitely cause corrupt files.
Also, it could be your power supply going bad too.
1992 Toyota Pickup--SuperTech 10W-30 conventional--Fram PH3614
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236226 10/10/19 06:54 PM
Dave9 Offline
Agreed, in order of likelihood given the systems it is either drive failure (or bad cable connection to it), bad PSU, or memory.
I would stop running windows in case it gets worse to the point of corrupting important files or failing to quite booting.
Instead I'd boot to a flash drive/etc to run memtest86+ and again to run a HDD diagnostic. If you have another drive then I'd do a testbed install of Win7 on it. If you have another system then I'd clone your current HDD/SSD to it, BUT if there is already significant file corruption, there may be no smooth sailing until you reinstall the OS after the problem is pinpointed and fixed.
Of course you could just restore your partition backup, which we all make regularly, right? wink
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236379 10/10/19 09:16 PM
L
loneryder Offline
L
Lately there has been a couple of updates and my Win 7 will hardly run. Doesn't respond to commands. Just seems to lock up. Takes a very long time to do anything. Wonder if it is the updates?
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236492 10/10/19 11:52 PM
U
user52165 Online Content
Online Content
U
FWIW:
Support for Windows 7 ends 1-14-2020
Re: Annyone else having issues with Windows 7 lately [Re: Dave9] #5236507 10/11/19 12:26 AM
R
rubberchicken Offline
R
Why YES we do !! Emergency boot image to USB flashdrive, and full backup to Carbonite.
Re: Annyone else having issues with Windows 7 lately [Re: loneryder] #5236546 10/11/19 03:32 AM
B
billt460 Offline
B
I have similar issues. The more they "update" it, the worse it runs. Now I get that pop up that say's, "Windows is searching for a solution to the problem". Windows NEVER finds ANY solution to ANY problem. I just wait a minute or 2 and it comes back. I just wish they would stop "improving" it.
Re: Annyone else having issues with Windows 7 lately [Re: user52165] #5236547 10/11/19 03:33 AM
B
billt460 Offline
B
Originally Posted by user52165
FWIW: Support for Windows 7 ends 1-14-2020
Good. Perhaps when they stop "supporting it", it will start running better.
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5236615 10/11/19 06:50 AM
L
Lubener Offline
L
I would clone asap.
The "thinking" man's friend.
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5237184 10/11/19 03:59 PM
007 Offline OP
Just had my computer checked. It was found that the last few Microsoft updates were an issue. Seems they were back loaded with a lot of junk. I am no expert but I can say since things were deleted and/or cleaned everything is fine. Tech told me that many were having the same issue within the last month. I will get a new laptop in the near future but I DO NOT TRUST Microsoft! Funny how the same thing happened when XP was replaced!
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5237509 10/11/19 11:42 PM
U
Online Content
U
What do you have against Windows 10?
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5237536 10/12/19 01:55 AM
Z
ZeeOSix Offline
Z
That's strange because my Windows 7 seems to be running fine, and it has all recent updates. One thing I do is wait awhile when an update comes out before I install it. If there's an issue with the update Microsoft typically hears about it and pushes out a fixed version.
Re: Annyone else having issues with Windows 7 lately [Re: ZeeOSix] #5237933 10/12/19 03:41 PM
007 Offline OP
Just sharing my experience and what I was told. If your system works fine that's a good thing!
Re: Annyone else having issues with Windows 7 lately [Re: 007] #5238814 10/13/19 08:45 PM
O
OVERKILL Offline
O
That sounds like a lot of "we ran disk cleanup but had to make it sound like we did more" language. Windows updates aren't "back-loaded" with junk, and I'm not even sure what that statement is supposed to mean shrug They replace files with bugs/vulnerabilities with updated versions that don't (or they haven't been discovered yet).
You really should take advantage of the free upgrade to Windows 10.
