Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
102 registered members (53' Stude, Anduril, 4WD, 2015_PSD, another Todd, aquariuscsm, 8 invisible), 2,129 guests, and 74 spiders.
Topics306,138
Posts5,288,212
Members71,604
Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) #5236078 10/10/19 04:03 PM
F
Fanatichuman Offline OP
F
Hi all,
The GM automatic transmission (390R) in my 2001 BMW e46 330xi doesn't have any metal shavings or such stuff. Did 2 drain and fills + filter in last 2 years. Shifts just seem a bit off. 250k miles.
Would you recommend adding some of this? https://www.amazon.com/Liqui-Moly-20040-ATF-Additive/dp/B004X63XVU?ref_=ast_sto_dp
It states though that it should be added to ATF 3, whatever that is....Dexron 3?
As I have Dexron 6 in my tranny, what would you recommend?
Thanks for your input guys!
Cheers,
fana
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5236094 10/10/19 04:17 PM
CT8 Offline
I recommend nothing unless a band aid is needed for some reason.
2015 F150 2.7
2018 F350 6.2
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5236103 10/10/19 04:29 PM
slacktide_bitog Offline
Not needed if the transmission is fine smile
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5236153 10/10/19 05:25 PM
N
nascarnation Offline
N
I'd say keep using what got me to 250,000 miles.
If you want to feel really good, put some Transynd (Allison TES-295) in.
FWIW the 5L40 was designed and released (1998) well before Dex VI came out (2006)so no problem with the thicker stuff.
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5236166 10/10/19 05:35 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Fanatichuman
H
Cheers,
fana
Quote
Areas of application
Suitable for power-steering and automatic transmissions that are filled with ATF II and ATF III oils.
What is ATF II or III?
What is its chemistry and how will that chemistry affect your transmission and most importantly, how will it affect the friction coefficients with respect to your wet clutches?
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5236884 10/11/19 11:26 AM
U
UG_Passat Online Content
Online Content
U
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: UG_Passat] #5236887 10/11/19 11:29 AM
K
kschachn Offline
K
Odd they say it has dexron III G approval when that can no longer be obtained.
dexron II is inferior to dexron III (and subsequently inferior to dexron VI), correct?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5237004 10/11/19 01:20 PM
F
F
Jeah, I'm not wanting the LM stuff anymore since they only talk about compatibility with ATF 2 and 3. Now thinking about going with Lubeguard red bottle.
Re: Liqui Moly ATF Additive in Dexron 6 (GM auto tranny of e46 330xi) [Re: Fanatichuman] #5237091 10/11/19 02:48 PM
K
kschachn Offline
K
One can only (properly) claim compatibility or "recommended for" when it comes to those designations. The licensing was discontinued many years ago.
1994 BMW 530i, 252K
