Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
95 registered members (ammolab, 97K15004WD, aquariuscsm, AandPDan, 53' Stude, 4WD, 8 invisible), 2,687 guests, and 21 spiders.
Topics305,841
Posts5,281,306
Members71,525
‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles #5236006 10/10/19 02:31 PM
A
Ambo87 Offline OP
A
Here's my recent UOA with Shell Rotella Gas Truck 0w20(5 qts.) and TGMO 0w20(.7 qts or 22oz.) total of 5.7 qts. with oil filter changed. Oil had 8,144 miles.
The vehicle was driven normally aside from the last 2,200sh miles of road trip from Tulsa, OK to Seattle WA. During the trip, a 5x8 U-haul cargo trailer was attached with roughly 2,600 lbs. of stuff. The van had about 400 lbs. with the driver, passengers and luggage. The trip had a lot of long steep inclines in the Rockies and Cascades with elevations reaching up to 11,000 feet. Driving on steep inclines, it was very noticeable that the 3.5 V6 was struggling and loosing power with the RPM's reaching 3,700-4,500. No overheating or anything unusual during the whole trip and ambient temperature varied between 40-95 degrees Fahrenheit due to location and elevation.
I'm curious if the high altitude, high RPM moments/stretches compounded and caused the aluminum and copper to rise? Currently, the van is good, drives fine and sounds normal. In fact, the MPG slightly improved.
By the way, a Lucas upper cylinder lube/injector cleaner was added before I drained the oil.
-VCM disabled
-Honda A01 oil filter
-AEM DryFLo air filter
-Shell Rotella Gas Truck 0w20--5 qts
-TGMO 0w20--.7 qts(22oz)
I would gladly appreciate any input!
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236008 10/10/19 02:33 PM
P
parshisa Offline
P
no report
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: parshisa] #5236010 10/10/19 02:34 PM
A
Ambo87 Offline OP
A
Originally Posted by parshisa
no report
Phone glitched. Just updated. Thanks
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236012 10/10/19 02:35 PM
P
parshisa Offline
P
i don't think these "extended" intervals are working well for you. I've learned that 4-5K works the best with my '16 pilot. you might want to try same schedule
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236033 10/10/19 02:56 PM
P
paoester Offline
P
Rotella Gas Truck by itself doesn't have that much molybdenum. Leftover from the previous used oil might boost it by +100 ppm at the most, then another +125 ppm from the TGMO added (0.7 qts), and Rotella contributes 150 ppm, added up its 375 ppm estimated. That corresponds to the 400 ppm OK.
Those high wear metals are puzzling. Engine is not new any more. I'd guess some hard contaminate scarred a bearing somewhere and its slowly shedding some material from ridges formed initially. It should settle down later you'd think and you can't do anything about it.
That is not long mile intervals. Viscosity held up well.and I don't think shorter intervals would help at all.
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236049 10/10/19 03:17 PM
demarpaint Offline
The copper stands out to me. If it were mine I would try a synthetic 5w30 and shorten the OCI.
God Bless Our Troops
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236067 10/10/19 03:46 PM
B
buster Offline
B
I'm familiar with these engines but I believe they do show high wear metals for some reason. I'd stay with one oil for a few intervals because otherwise you're never going to know what is working. I don't think the oil had anything to do with what you're seeing here.
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: buster] #5236070 10/10/19 03:53 PM
N
NormanBuntz Offline
N
Yes, but the 8,144 miles probably did. I like the suggestion of a 6K run.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236073 10/10/19 03:58 PM
J
JC1 Offline
J
Could you have higher wear metals driving in the Rockies while towing? I do recall when I was in Denver in July 2000 how you had to hammer the throttle to keep up when heading westbound.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: JC1] #5236111 10/10/19 04:37 PM
P
paoester Offline
P
This vehicle has had high metals earlier when using TGMO, and assuming no towing back then. Towing shouldn't significantly change things anyway.
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: paoester] #5236128 10/10/19 04:53 PM
A
Ambo87 Offline OP
A
JC1, you’re right that’s why I specifically stated that driving on those uphill climbs were so taxing on a NA engine especially on the Rockies heading west(almost pedal to the metal). Also, Paoester is correct too for pointing out the previous fills with TGMO and the wear metals associated with it. No towing back then. I really do appreciate you guys chiming in!
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236158 10/10/19 05:28 PM
P
parshisa Offline
P
All UOA for J35 engines i’ve seen with 8k+ miles onOCI produced high wear metals. Cut it down to 4K for couple of OCI and sleepwell
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236165 10/10/19 05:34 PM
R
Railrust Offline
R
I'll tell you what, I just don't like going past 5,000 miles on a GDI engine anymore. That aluminum count would concern me enough where I'd never go 8,000 miles on that Pilot again. Isn't that Honda's engine with the fuel dilution problems? Or is the 4 cylinder in the CRV? Honestly I think they both have had it. And of course Honda wants the lightest weight oil possible...surprised they don't suggest the 0W16.
I "like" the 0W20 Rotella Gas Truck oil...been using it all year...it seems "good", but after reading your report I've got to admit I'm now having my doubts a little bit.
Maybe try a different oil and cut the interval down. Keep your receipts...if you ever - heaven forbid - need to use your power train warranty, Honda is going to want to see them.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Ambo87] #5236193 10/10/19 06:12 PM
P
PWMDMD Offline
P
Those are in line with what I saw in my Pilot last oil change. I'm doing a shorter 5K run from 20-25K to see what happens. If things don't start to look better then let's just say the Pilot is not a longterm keeper. I want a pickup truck anyway....just waiting to see what Toyota does with the Tundra....
Current: 2019 Lexus RX 350 (Mobil AFE 0W-30 and Toyota OEM Filter) and 2018 Honda Pilot Touring (PP 5W-30 and Mobil 1 EP M1-110A Filter)
Re: ‘18 Odyssey 3.5 DI, Rotella GT/TGMO 0w20, 8,144 miles [Re: Railrust] #5236197 10/10/19 06:17 PM
domer10 Offline
Unless you are doing the drive he did, and towing none the less I don’t think you should be worried at all. There is more at play than the oil. Go watch TFL when they tested the Jeep gladiator towing up the IKE pass. That poor V6 sounded like it was going to grenade.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
