Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
31 registered members (CapriRacer, Dmstrbav, Char Baby, Amkeer, bernardch, classic70, 3 invisible), 914 guests, and 54 spiders.
Topics306,278
Posts5,289,445
Members71,616
Distributor Cam Grease #5235853 10/10/19 12:19 PM
B
bunnspecial Offline OP
B
From what I can find, the giant $50 tube of Bosch brand grease had been discontinued/is NLA.
With that gone, are there any favored brands for this now? Amazon has grease branded Enduralast and WVE. Any thoughts on those two? Are there any good alternatives that are not necessarily labeled for this application but will work,
Judy to be clear, I’m asking about the stuff that is used as a lubricant between the center cam and the heel of the points. There’s not a ton of pressure on this spot. But it’s critical that it stay in place while the cam is turning(up to 3k rpms for my cars).
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Distributor Cam Grease [Re: bunnspecial] #5235860 10/10/19 12:23 PM
O
Oily_Thing Offline
O
In 1977 I bought a tube of AC/Delco distributor cam lube. The small tube was a lifetime supply.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: Distributor Cam Grease [Re: bunnspecial] #5235870 10/10/19 12:32 PM
K
kschachn Offline
K
Oops, never mind.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Distributor Cam Grease [Re: bunnspecial] #5235875 10/10/19 12:37 PM
O
ordinarybloke Offline
O
Love it. That's a classic Bobis... post if ever we saw one. I too was wondering if the grease for this was still available. And anyone that knows would also be able to tell us...
Is rear-view mirror grease still sold in quart tubs or do they make you buy the whole gallon?
Re: Distributor Cam Grease [Re: bunnspecial] #5235887 10/10/19 12:46 PM
B
B
Unfortunately that lifetime supply of Bosch grease I bought had a lifetime until someone stole my toolbox....
Re: Distributor Cam Grease [Re: bunnspecial] #5235934 10/10/19 01:22 PM
Chris142 Offline
I was taught to use wheel bearing grease. It's always worked for me.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Distributor Cam Grease [Re: bunnspecial] #5235985 10/10/19 02:13 PM
M
michaelluscher Offline
M
Mallory used to have a good dist. lube, but it's been discontinued
I checked eBay, there's more then a few NOS and newer options under "distributor lube"
'17 CTS Performance AWD 3.6 11K
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: Distributor Cam Grease [Re: bunnspecial] #5236090 10/10/19 04:13 PM
N
nthach Offline
N
The guys on the Samba use SuperLube for their distributor cams - a big tube of Bosch grease is pricey. Someone translated the German SDS for it and it seems like a mineral oil based, sodium soap thickened grease. I think Molykote 33 can also work.
https://www.thesamba.com/vw/forum/viewtopic.php?t=652724
Re: Distributor Cam Grease [Re: bunnspecial] #5236142 10/10/19 05:09 PM
A
andyd Offline
A
Used a match head sized glob at a time any grease should be fine. Don't new points come with a little red capsule anymore? My '77 Stihl FarmBoss is still on its original points and grease, BTW grin2
Thick oil is better grin2
Re: Distributor Cam Grease [Re: bunnspecial] #5236250 10/10/19 07:20 PM
B
B
Thanks everyone for the responses. I’ll see use a tiny amount of heavy axle grease.
BTW, the last several sets of points I’ve bought have not included any grease at all. I’ve run across NOS Lucas red box that didn’t have any either. With that said, points for the Lucas 45D(what’s on the Marina-the MG has a 25D) have a felt pad that “wipes” the cam constantly and is supposed to be greased. Old ones might have come pre-greased, but new ones certainly aren’t.
Current points and condensers-at least for Lucas distributors-are so terrible now that I sometimes wonder if Pertronix pays off the companies making them. Condensers in particular have such a high failure rate that I no longer replace them when changing points provided that there’s no evidence of the current one being bad. The one in my MG now has probably 5k miles on it, but I went through 3 to find one that would last more than a few hundred miles.
Re: Distributor Cam Grease [Re: bunnspecial] #5237562 10/12/19 05:34 AM
L
Lubener Offline
L
I have a tube of Niehoff moly dist. cam lube. Napa has this stuff. I wouldn't use anything else not meant for this purpose.
The "thinking" man's friend.
Re: Distributor Cam Grease [Re: bunnspecial] #5237887 10/12/19 02:31 PM
B
billt460 Offline
B
I'm thinking most any thick bodied grease will work fine here. What is the diameter of the cam 1" or so? Even if it's turning at 3K, (which translates to 6,000 RPM on the crankshaft), it's not going to be generating enough centrifugal force to remove it. Especially if you have a pad wiping and reapplying it on every revolution.
Re: Distributor Cam Grease [Re: billt460] #5238247 10/13/19 05:39 AM
L
Lubener Offline
L
Don't bet on it.
Re: Distributor Cam Grease [Re: bunnspecial] #5239886 10/15/19 05:44 AM
B
billt460 Offline
B
Just look on the inside of the distributor in line with the cam. If you don't see grease flung all over, whatever is being used is staying put.
Re: Distributor Cam Grease [Re: nthach] #5241071 10/16/19 08:31 AM
A
alcyon Offline
A
Super lube fixed my electrical digital speed sensor on my toyota, i lubed the rotating magnet and hall effect sensor. And it sprung back to life.
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
