Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
27 registered members (4WD, Dave_Mark, Bjornviken, bamorris2, dishdude, 14Accent, 2 invisible), 1,703 guests, and 24 spiders.
Topics300,515
Posts5,177,582
Members70,518
Amsoil EaAU vs. AFE Pro Dry S Filter? #5235848 10/10/19 11:14 AM
K
krazi3azn Offline OP
K
Seeing if anyone has experience with these two filters. Want more flow in my car.
Amsoil is cheaper but website states it is not washable but can be cleaned. Also should be replaced every 4 years or 100k miles
Afe is washable and reusable. But another website states it can only be cleaned so much before replacement is needed.
Product im specifically looking at
AMSOIL 4075
Afe 21-90096
Also i believe the amsoil is a bigger filter
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5235865 10/10/19 11:28 AM
K
kschachn Offline
K
Are you getting insufficient flow now?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5235888 10/10/19 11:47 AM
rooflessVW Offline
I ran an aFe Pro Dry S on both my 911 and Q7 with no complaints. Both were very well constructed and fit perfectly. Intake tracts remained spotless.
"Zed's dead baby, Zed's dead."
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5235894 10/10/19 11:51 AM
d00df00d Offline
welcome to BITOG!
I second kschachn's question. Do you know for sure that your current filter is a point of restriction?
2008 BMW M3 Sedan 6MT
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: kschachn] #5235983 10/10/19 01:09 PM
K
K
Yes, I have a deleted 335d (diesel) with a oiled K&N drop in filter. A few other owners said they added the afe and significantly reduced the amount of smoke from the car.
Reason im looking at the amsoil is because its cheaper (member discount), easier to obtain and there is a local store. Just seeing if AFE is significantly better or more or less the same.
Originally Posted by d00df00d
welcome to BITOG!
Thank you! Been a long time lurker
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5236016 10/10/19 01:39 PM
d00df00d Offline
Those testimonials on the aFe: were they comparing vs. the stock filter, or a K&N drop-in? Or both?
What's the relationship between smoke and air filter flow rate?
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: d00df00d] #5236028 10/10/19 01:51 PM
K
K
Comparing to stock air box in general, with and without K&N. More flow rate means more diesel burnt which in return less smoke at WOT.
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5236280 10/10/19 06:40 PM
K
kschachn Offline
K
Help me out, diesel engines don't have a mass air flow sensor? What kind of car do you have and what year?
1994 BMW 530i, 251K
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: kschachn] #5239958 10/15/19 07:10 AM
A
A310 Offline
A
Newer diesels do have mass air flow sensors.:)
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: A310] #5240015 10/15/19 07:49 AM
d00df00d Offline
I think kschachn was actually pointing that out in his post. In other words, doesn't OP's car have a MAF? The idea would be that a marginally more or less restrictive intake filter shouldn't affect combustion quality much because the engine would use the MAF to adjust for the actual flow rate.
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5284918 12/04/19 12:34 PM
A
ARB1977 Offline
A
I like AFE which is what I have in my 15 Tacoma. Since AFE didn’t make one for my wife’s 19 Pilot I ordered a AEM. Construction on those seem good.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5315818 01/07/20 01:15 PM
Clayslayer Offline
Either should be fine. Both have good reviews all over the internet. I have a diesel car (2002 Jetta) and use a stock air filter because there is little, if any, gain from using a performance filter. The stock air box is capable of flowing a great deal more air than the engine can ever use. Mine has moderate performance parts, Bosio DLC 1019 nozzles, BW BV39 turbo, deleted, 3" turbo back exhaust, fueling and timing mechanically adjusted then fine tuned with VCDS, Malone Stage 3 tune. Diesels like a dry filter because of the darn MAF right there on the airbox. Mine was nuked by an over oiled K&N (MY fault, not K&N's). I roughly doubled my factory horsepower but am still close to a hundred short of what your car is rated at. Do you have any performance mods? If you do black smoke is something you're going to have to get used to when you're having fun. If you tune the smoke out by reducing fuel it will proportionately slow the car down. Mine is smoke free with "normal" sane driving but when I want to bust the tires loose through the first three gears it'll roll coal pretty bad.
Re: Amsoil EaAU vs. AFE Pro Dry S Filter? [Re: krazi3azn] #5318493 01/10/20 08:38 AM
J
jeepman3071 Offline
J
I put the AFE pro-dry S in my parent's cars (2011 Fit and 2013 Grand Cherokee 5.7L) and they have been great for several years. I clean them about once a year (wash and dry in the sun). The ability to wash them makes them superior to the Amsoil in my opinion. I had the Amsoil in my Jeep Cherokee, and while it was a good filter it was not washable, so the only option was blowing it out with an air compressor. I usually just rinse the filters with mildly soapy water.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
