Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
105 registered members (97tbird, 53' Stude, 14Accent, 97K15004WD, 4WD, 86cutlass307, 7 invisible), 2,833 guests, and 58 spiders.
Topics305,851
Posts5,281,408
Members71,525
Water decarbonisation #5235495 10/10/19 04:50 AM
F
FordCapriDriver Offline OP
F
Tried the old trick of water decarbonisation last Sunday on my '75 Capri.
Came back from a long drive, whipped off the air filter box and sprayed distilled water right down the carb using a spray bottle, i used a little over half a liter while holding the engine at 2000-3000rpm.
It wasn't immediately noticeable but i really began noticing it yesterday :
- Idle is smoother
- Acceleration seems more linear and engine seems to rev more freely.
Until August 2016 when i changed the valve stem seals, the engine used a lot of oil, i estimated about a quart / liter every 600 miles, after changing them the oil consumption completely stopped, so i assume the inlet valves are probably very cruddy.
These are ofcourse not scientifically demonstrable, but the butt dyno says it runs better!
Bonus revving video after doing it : https://www.youtube.com/watch?v=dilsdyH5d1Y
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Water decarbonisation [Re: FordCapriDriver] #5235585 10/10/19 07:28 AM
K
Kira Offline
K
How many miles/kms are on your Capri?
Re: Water decarbonisation [Re: FordCapriDriver] #5235602 10/10/19 07:47 AM
E
Eric Smith Offline
E
Did the same on our RV couple weeks ago but haven't drove it yet. The driveway was clean before I started.. and so was my youngest leg. He just happened to walk by right as I hit it lol. Was having issues with pinging. I'll find out the results tomorrow.
[Linked Image]
05 Chevy 3500 (Class C RV) 71k
04 Escape 170k
02 Focus 152k
00 Dakota 95k
Re: Water decarbonisation [Re: FordCapriDriver] #5235626 10/10/19 08:19 AM
B
billt460 Offline
B
Is there a down side to this procedure? Can you damage anything like electronic sensors in these modern vehicles? I've heard of water injection used as a way to increase power in older military aircraft. But for some reason spraying water into a running automobile engine doesn't sound like something most should be doing.
Re: Water decarbonisation [Re: FordCapriDriver] #5235640 10/10/19 08:33 AM
csandste Online Content
Online Content
Bringing back memories here. Bought a '71 Renault R6 new and fell for a JCWhitney water injection bottle. Did it do anything? It bubbled and that was interesting and it didn't hurt. Just nostalgic for the old days when everything was simple and there was a lot of room under the hood for putting quart jars of water in.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Water decarbonisation [Re: billt460] #5235842 10/10/19 12:04 PM
DGXR Offline
If someone is doing this on a modern FI engine, they should disconnect the air cleaner from the TB/intake and spray the water directly into the TB. Since this will remove the MAF sensor (and perhaps IAT) from the system, it might set a code. But as long as they aren't spraying fire hose quantities of water, no damage will occur and any codes will reset after the air cleaner system is reassembled.
None of this should be necessary in a healthy engine that has been maintained. But the OP had an oil burning condition that made this cleaning a good idea.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Water decarbonisation [Re: FordCapriDriver] #5235864 10/10/19 12:27 PM
O
Oily_Thing Offline
O
I used to use ATF to clean out carbon. Just slowly pour a quart of ATF down the carburetor while revving the engine to keep from stalling. It made a little smoke doing that.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: Water decarbonisation [Re: FordCapriDriver] #5235906 10/10/19 12:58 PM
SLO_Town Offline
I would never do that on a car worth more than $1000. Check that. I'd never do that to any car.
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Water decarbonisation [Re: billt460] #5236209 10/10/19 06:31 PM
E
Eric Smith Offline
E
I found a vacuum line that goes straight to the intake manifold. I wouldn't spray it in like a carb. I've used it on several EFI engines with no issues. The downside is doing too much you'll be buying a engine lol
04 Escape 170k
02 Focus 152k
00 Dakota 95k
Re: Water decarbonisation [Re: FordCapriDriver] #5236414 10/10/19 09:50 PM
K
Kruse Offline
K
Quite a few years ago, I read on some forum where a Cadillac tech tried to do a decarbonization on a Northstar engine and filled up the intake runners with water because he was doing it at idle instead of high-revving it during the process.
As soon as he revved it up, the engine gulped a bunch of water and did a hydro-lock on a customer's engine. The dealership paid for a new one.
Re: Water decarbonisation [Re: Eric Smith] #5236572 10/11/19 05:28 AM
B
billt460 Offline
B
That's the potential problem I was referring to. How do you know when you choose to walk this mechanical tightrope, exactly when you have crossed the boundary into, "too much"? Sounds like an expensive gamble to me, regardless of how it's done.
Re: Water decarbonisation [Re: FordCapriDriver] #5236683 10/11/19 08:13 AM
M
meep Offline
M
I've done it many a time with no adverse effects, but the improvements minor. On really old/neglected vehicles I skip water and drizzle seafoam for a while more and more until it bogs and quits. Let it soak, then crank it up and drive it. Problem: on the worst vehicles, the CC carbon soaks up the seafoam, and after restarting, the dark cloud will absolutely engulf.... in personal experience, I had a bad experience with this - early one morning 1/4 mile of my neighborhood and the next 1/4 mile to the grocery, at which case I shut down and pulled over because it clouded up the entire route I'd taken.. Not a responsible citizen or kind neighbor..... I waited until there was wind, then re-started and idled it until it dissipated and I could come home. The engine ran remarkably better after.
2018 F150
2015 crv (wifey!)
Re: Water decarbonisation [Re: billt460] #5236809 10/11/19 10:12 AM
B
BMWTurboDzl Offline
B
It's more of a misting than spray and acts like a steam cleaner. Water does reduce combustion temps which can increase power. The current BMW M4 GTS uses water injection. IIRC this is the only OE water injection application produced for a modern car.
Owners of tuned euro cars will often install an aftermarket methanol injection system. I don't think they run pure methanol but it contains some percentage of water.
435i
Re: Water decarbonisation [Re: Kira] #5236824 10/11/19 10:24 AM
F
F
The engine isn't the original one but around 180k miles.
In good shape though, burns no oil at all, very little blowby, good compression and oil pressure still.
Re: Water decarbonisation [Re: FordCapriDriver] #5237754 10/12/19 11:06 AM
L
Linctex Offline
L
An old windshield washer nozzle in the inlet duct right before the throttle body works perfect.
It's BEST to do it under a load - you can use the washer fluid tank and pump, too.
Just disconnect the wiper motor so the wipers don't run while you are pushing the washer button.
