Forums Migration
Please read this thread
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
Beater trifecta
by Red91 - 07/11/20 01:08 PM
ILoveOil111, quantalume, SUmeme22, DaveCaddell, SharkNC
71909 Registered Users
90 registered members (92saturnsl2, Alaskanmont, 2strokeNorthstar, aba4430, Aichiguy, 2010Civic, 4 invisible), 1,408 guests, and 27 spiders.
Topics307,744
Posts5,316,900
Members71,909
Havoline boxed oil. #5235487 10/10/19 04:28 AM
J
jakewells Offline OP
J
Been doing some thinking about this oil and just realized this since my truck only hold 4-1/2 qts with filter i would have 1.5 qts left over after every change.
I can get a full oil change after three oil changes just from the left overs this would be cost savings to me since what i usually buy is out of stock. I would like to know how good the regular dino is compared to the synthetic though.
2001 Mercury Cougar base 2.5l CD4E automatic.
1986 Chevy s10 4x4. mildly built carbed 4.3 700R4 automatic.
Re: Havoline boxed oil. [Re: jakewells] #5235491 10/10/19 04:41 AM
ctechbob Online Content
Online Content
I split the difference and settled on the HM version. Its only something like $.60 more for a semi-syn.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Havoline boxed oil. [Re: jakewells] #5235492 10/10/19 04:44 AM
J
J
I would go for the HM since that is what they usually have couldn't hurt either since the factory engine has 240,000 on it.
Re: Havoline boxed oil. [Re: jakewells] #5235506 10/10/19 05:15 AM
M
Mad_Hatter Offline
M
How long are your typical drain intervals?
I just changed out Kendall syn blend and replaced it with Havoline 5/30 HiMi SB. I've used this lube before up to 5k miles (I never go beyond 5k) without issues. I like it's stout AW pkg.πŸ‘.. and the added seal conditioners help keep my 164k mile engine leak free.πŸ˜‰
Re: Havoline boxed oil. [Re: jakewells] #5235509 10/10/19 05:23 AM
J
J
5,000 miles is what i usually go for 50/50 mix city highway mine doesn't leak or burn any oil
Re: Havoline boxed oil. [Re: jakewells] #5235511 10/10/19 05:35 AM
B
bbhero Online Content
Online Content
B
Yeah the Havoline oil is a very good oil jake... It has 170 ppm of molybdenum and 110 ppm of boron, a TBN of 8+, and the high mileage oil has a HTHS of 3.4... Rather stout.
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Havoline boxed oil. [Re: Mad_Hatter] #5235560 10/10/19 06:37 AM
JohnnyJohnson Online Content
Online Content
Well I'm using the Havoline Pro DS right now in 10w-30 I'm currently at about 6300 miles with a couple weeks to go before I change it out and do a UOA.
2004 Corolla 140744
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Havoline boxed oil. [Re: JohnnyJohnson] #5235896 10/10/19 12:52 PM
M
Mad_Hatter Offline
M
I'll be keeping an eye out for that UOA.πŸ‘ Starting this spring I'm gonna start running 10/30 in the spring and summer months and the 6qt box is perfect. I got the 5/30 HiMi on rebate this summer and it ended up being like $9 for the 5qt jug. Hard to beat that...
Re: Havoline boxed oil. [Re: jakewells] #5235901 10/10/19 12:54 PM
M
Mad_Hatter Offline
M
Then I would say try it out..at 5k miles that Havoline won't disappoint.πŸ˜‰
Re: Havoline boxed oil. [Re: Mad_Hatter] #5235911 10/10/19 01:03 PM
Online Content
I'm going to PUP 0w-20 HM this next change. Got it on sale at WM for $14 and change. Then shock of the year I scored (1 out of 3 times) and got the SOCUS rebate. So my oil change this fall will run me around $6.85 to include the filter. The Corolla has never used this oil weight before so we'll see how oil consumption runs with this light stuff the Toyota has just over 136,000 miles on it now. It will be closer to 137,000 by the end of October.
2004 Corolla 140744
2006 Duramax 77117
Re: Havoline boxed oil. [Re: jakewells] #5235976 10/10/19 02:02 PM
B
BLND1 Offline
B
My ford 4.6 2v takes 6 quarts, so I swapped to the high mileage synblend box last oil change. It’s a fantastic value and the engine hasn’t fallen apart yet. I guess it will work. smile
Re: Havoline boxed oil. [Re: jakewells] #5236025 10/10/19 02:48 PM
T
tiger862 Offline
T
I ran Havoline ProDs in my Caravan for 6 months and 2800 miles so I can say my opinion is that it is a cheap oil that meets specs not a great oil. My fuel mileage has been down and a whine in motor at 1500 rpms. I changed oil to Valvoline Daily Protection and noise is almost gone. I will see about fuel mileage over next 6 months before I make a judgement. Didn't lose any oil between changes.
Tiger862
2018 Grand Caravan
