Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
108 registered members (aquariuscsm, another Todd, 2015_PSD, 4WD, ArrestMeRedZ, AandPDan, 11 invisible), 2,105 guests, and 57 spiders.
Topics306,137
Posts5,288,205
Members71,604
Do we really need paper media filters? #5235356 10/09/19 10:19 PM
O
onespiritbrain Offline OP
O
***This would not pertain to vehicles with engines that have extremely tight bearing clearances***
Do we really need highly restricted paper media oil filters when the oil is changed at 3k miles? I’m thinking a felt style media that will catch 50 micron particles well but pass the smaller stuff should be fine.
The engines own wear particles should be the only contaminates in the oil and by nature would be very small anyway.
What am I missing here? Where are these large contaminates coming from?
Obviously I don’t think robust oil filters are unnecessary for everyone. Those who can’t change their own oil (not hating I’m too stupid to change my own sometimes) and those who live in arid/sandy places come to mind.
Wouldn’t gas mileage benefit from the reduced engine strain.
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235373 10/09/19 10:44 PM
T
tundraotto Online Content
Online Content
T
Felt releases its own particles.....kind of like Fram used to release cardboard from the glued end pieces.....
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235380 10/09/19 10:52 PM
clinebarger Offline
Bearing inserts are designed to embed contaminates. It's the needle bearings & rollers found in so many valvetrains today along VVT actuator solenoids that need clean oil.
Engine's didn't used to have full-flow oil filters & bypass filters were a option. I think Chrysler was the first of the big 3 to install full-flow filters.
Engine are now using Electronic Flow-Control solenoids on oil pumps to reduce parasitic loss from driving the oil pump to mechanical relieve during cold starts & high RPM.
The GM Ecotech3 engines are what I'm most familiar with using this set-up, They use variable displacement pump similar to the pump in a Automatic Transmission. It has precise control over the pressure from what I've seen.
2001 Chevy Camaro L92/4L80E
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235403 10/09/19 11:22 PM
Z
ZeeOSix Offline
Z
Most oil filters are running around 3~4 psi delta-p most of the time. Google hydraulic HP equation and run the required HP numbers to overcome 3~4 psi of fluid pressure. It's miniscule.
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235409 10/09/19 11:34 PM
G
geeman789 Offline
G
You really need highly efficient AIR filters ... keep the dirt out, and the oil filters job is easy.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235434 10/10/19 12:19 AM
Z
ZeeOSix Offline
Z
Where's the actual flow vs delta-p test data that shows certain oil filtets are highly restrictive.
There use to be a long lived internet tale that Purolator PureOne oil filters were "very flow restrictive" because they were so efficient. Then actual test data of the flow vs delta-p was shown, which kiboshed that false tale.
Re: Do we really need paper media filters? [Re: ZeeOSix] #5235490 10/10/19 04:41 AM
4WD Online Confused
Online Confused
What happened to microGreen filters … used to be lots of chatter here over those
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235536 10/10/19 06:22 AM
shanneba Offline
Isn't most of the contamination in the oil from combustion byproducts?
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235548 10/10/19 06:29 AM
B
BMWTurboDzl Offline
B
Do we really need highly restricted paper media oil filters when the oil is changed at 3k miles?.
I believe this is called a strawman argument.
435i
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235620 10/10/19 08:12 AM
PimTac Offline
I would ask the expert from Dagobah.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235643 10/10/19 08:35 AM
E
edwardh1 Offline
E
I am surprised that there is not a market for higher efficiency AIR filters
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235649 10/10/19 08:39 AM
O
O
Most, or really all, of my thoughts about anything relating to oil/filters, originates from an issue I am having with my vehicle.
I am fighting low oil pressure in my VG33 engine. Is it bearings or a worn pump, I don’t know, but I feel like a filter with less restriction would benefit me.
After some research the anecdotal consensus says that K&N oil filters provide the least resistance to flow. If I’m not too poor for the $15 filter I will try one next OCI.
Something I notice having a worn engine is that while I don’t have oil pressure low enough to signal the idiot light, I do have poor flow at idle enough that valve train noise appears and disappears with higher RPM/oil flow.
My thought is that as a vehicle’s oil pump begins to have trouble delivering oil to the valve train, a filter with less restriction to flow might help.
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235662 10/10/19 08:51 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
50 microns seems too generous. Why did you pick that number? I work with bearings and contaminant analysis. 50 microns is huge.
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235682 10/10/19 09:13 AM
circuitsmith Offline
Most likely worn bearings. Worn oil pump making low pressure is virtually unheard of.
Gaining 1 psi with lower filter restriction won't make a meaningful difference.
How many miles on the engine?
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Do we really need paper media filters? [Re: onespiritbrain] #5235859 10/10/19 12:22 PM
DGXR Offline
I think paper media is a good choice for standard /economy filters going up to 5k mile OCI. Assuming the engine has received regular service, 5k miles is not long enough to load up the media. Who changes their oil at 3k anyway? Even conventional oil in severe service can go at least 3750 miles.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
