How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
79 registered members (1978elcamino, 97prizm, 2015_PSD, 53' Stude, 73guna, aba4430, 9 invisible), 1,862 guests, and 19 spiders.
Topics306,113
Posts5,286,731
Members71,588
Best Lube for Ratchet #5235291 10/09/19 09:07 PM
U
user52165 Offline OP
U
I disassembled a 40 year old Craftsman (forged in USA) ratchet. More for curiosity than necessity. Once the snap ring was off, very easy.
Very well made - where did we lose our way??
Remarkably clean after all these years. Cleaned parts with solvent. What is best lube to use? Lithium grease or ?? Does it really matter that much?
Re: Best Lube for Ratchet [Re: user52165] #5235295 10/09/19 09:14 PM
SubieRubyRoo Offline
Silikroil
De omnibus dubitandum.
Re: Best Lube for Ratchet [Re: user52165] #5235302 10/09/19 09:26 PM
M
maxdustington Offline
M
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Best Lube for Ratchet [Re: user52165] #5235324 10/09/19 09:53 PM
clinebarger Offline
2001 Chevy Camaro L92/4L80E
Re: Best Lube for Ratchet [Re: user52165] #5235494 10/10/19 04:48 AM
K
Kruse Offline
K
Talk about opening a Pandora's box or a can of worms.
You're going to get all kinds of opinions on the subject. Some will soak the ratchet head in oil every night and others put in a dab of grease. I've always been in the "dab of grease" opinion, as nothing bothers me more than a brand new ratchet that has loud clicks when in use.
Re: Best Lube for Ratchet [Re: user52165] #5235518 10/10/19 05:54 AM
T
Trav Offline
T
On my Snap on and other sealed ratchets I use the Super Lube (not often and only a very small amount) which is Snap on OE on others inc the old non sealed Snap on I toss the head in a jug of ATF over the weekend if it got a lot of use.
Working a cold climate really makes a difference. Grease tends to increase back drag significantly which really sucks, the ATF works great and although it does not have the same noise cushioning effect as grease the tooth wear is not any greater and the back drag is minimal, it also keeps them very clean inside.
Re: Best Lube for Ratchet [Re: user52165] #5235547 10/10/19 06:28 AM
demarpaint Offline
For fine tooth ratchets I soak them in ATF, as per Trav's recommendation. For coarse geared ratchets I use Super Lube grease, sparingly. I want to gears to mesh, not float on the grease.
God Bless Our Troops
Re: Best Lube for Ratchet [Re: user52165] #5235597 10/10/19 07:39 AM
K
Kira Offline
K
Friend had an OLD, worn Snap-On ratchet.
I took it downstate (where people and commerce dwell) and approached a Snap-On route driver parked at a Chevy dealership.
You know I enjoyed doing this.
He must've had 7 styles of rebuilding inserts but none for this relic. He ordered up 3 sets and told me to return in a week. He told me to keep possession of the tool.
He popped the guts out and applied a dab of dark grease to the new inwards. He circled the new ratchet wheel with the thinnest of smears.
Re: Best Lube for Ratchet [Re: Kruse] #5235713 10/10/19 09:43 AM
T
The_Eric Offline
T
You've got that right!
I tend to prefer heavy oils like assembly lube.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Best Lube for Ratchet [Re: Kruse] #5235758 10/10/19 10:40 AM
demarpaint Offline
Just like our oil debates, and the thick vs. thin oil wars. wink
Re: Best Lube for Ratchet [Re: user52165] #5235770 10/10/19 10:56 AM
T
TurboLuver Offline
T
I still use Permatex 81950 engine assembly lube.
2015 Lexus GS350 F Sport RWD
2008 Civic SI
1999 GMC Suburban K2500
1997 Jeep Cherokee Country
