Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
49 registered members (2015_PSD, 2002 Maxima SE, alcyon, AlienBug, ArrestMeRedZ, 7 invisible), 974 guests, and 18 spiders.
Topics298,820
Posts5,141,925
Members70,129
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5235285 10/09/19 08:00 PM
G
Gannet167 Offline OP
G
Amsoil’s reply to my email said the product code on the bottle is from Jan 2015.
Draining and remixing isn’t really an option since there were multiple bottles, some had more, some had less separation. It’s unclear how much of that stuff I’d have to mix with the front diff, the rear diff and the transfer case. That’s assuming I could even get it to mix uniformly.
I guess I’ll drain and refill, and chalk this up to an expensive “flush” and a learning experience.
The vehicle is a 4Runner, has open diffs and a Torsen transfercase. I chose the Amsoil Gear Lube for good cold temp performance (gets to -40 in my area), long life and no limited slip additive which I don’t need or want. The latest bottle for this product is grey.
Thanks for the advice,
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: kschachn] #5235473 10/10/19 01:50 AM
B
bbhero Offline
B
Originally Posted by kschachn
Will an oil even heat up in a microwave?
I am sure you are not serious right ???
LOL
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5235483 10/10/19 02:59 AM
R
Railrust Offline
R
All this talk of mixing, shaking and heating it up...if you can pour all of the ingredients into that diff, isn't the differential the ultimate mixer? I imagine after an hour those ingredients have been mixed and heated pretty well.
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5235486 10/10/19 03:23 AM
4WD Offline
Delvac 1 does not have LSD adds … $33 for gallon jugs at Summit …
meant for HD equipment but the Porsche track guys like it too
(no crud left in bottoms)
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: bbhero] #5235675 10/10/19 08:01 AM
K
kschachn Offline
K
LOL
Well, microwaves only heat up polar molecules so I didn't think it would heat up a non-polar hydrocarbon molecule.
I looked it up and no it would not, but motor oil is not just non-polar hydrocarbons so maybe it might heat up somewhat.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5235909 10/10/19 12:02 PM
MolaKule Offline
Global Moderator
Global Moderator
There are some polar molecules but not the ones in which the molecules would rotate efficiently with microwave energy.
I was thinking of the wife and the kitchen. smirk2
Let's say it did heat up. With the cap on it might explode and cause a fire. shoot
With the cap off it might gurgle or percolate up and over the top and spill. "Honey, what's that smell coming from the microwave? shocked2 ???
Solar heating or setting over a hot air register, IMHO, is the better way of warming it up.
I think what you are seeing at the bottom is a very minute amount of potassium borate, sulfur, and some thickener settling out of solution.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5235928 10/10/19 12:18 PM
J
Jetsfan421 Offline
J
You could use a double boiler to try and dissolve the additive fallout. Basically boil some water and pour contents into a mason jar, then place jar in boiling water.
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: MolaKule] #5236244 10/10/19 06:16 PM
A
AC1DD Offline
A
If you have sunny days just put the stuff outside and let it sit, occasionally shake the bottle and then let sit in the sun I bet in several days of continuous sunlight most of the drop out will disappear back into the product.
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: Gannet167] #5236374 10/10/19 08:14 PM
G
Gebo Offline
G
You could use it as a play toy in the bath tub. banana
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Additive Fallout / Separation Amsoil Gear Oil [Re: AC1DD] #5236490 10/10/19 10:50 PM
4WD Offline
Know anybody with a black car ?
Page 2 of 2 1 2
