1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
75 registered members (4WD, 53' Stude, ArrestMeRedZ, ARB1977, amblerman, 94astro, 2 invisible), 1,460 guests, and 64 spiders.
Topics306,081
Posts5,287,043
Members71,596
Synthetic #5235196 10/09/19 07:10 PM
B
Bettez88 Offline OP
B
What’s everyone’s consensus on what the best synthetic filter is? Can be blend can be full synthetic.
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Synthetic [Re: Bettez88] #5235201 10/09/19 07:15 PM
wemay Offline
You won't find a consensus but here are a few...
Purolator Boss
Fram Ultra
Royal Purple
Wix XP
Mobil1
Napa Gold
STP XL
etc..
2019 Volkswagen Passat Wolfsburg TSI: VW OE 0W-20, OE o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: Synthetic [Re: Bettez88] #5235202 10/09/19 07:17 PM
B
bullwinkle Offline
B
I personally like the Ultra, because on eBay 6 of them can be pretty cheap, under $25. There's others that are pretty good too-Fleetguard Stratapore, Amsoil, Donaldson Blue, Royal Purple in synthetic media, M1, Bosch Distance Plus, even Fram EG/TG in blend. Ultra beats them in bang for the buck, though!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Synthetic [Re: wemay] #5235263 10/09/19 08:27 PM
blupupher Offline
Purolator Boss
Fram Ultra
Royal Purple
Wix XP
Mobil1 synthetic blend
Napa Gold synthetic blend
STP XL I think it is a synthetic blend?
etc..
I think the Ultra will get the most "best" votes, mainly due to availability and price.
Boss has had issues with sliced ADV (with no definitive proof of it being an actual issue).
Royal Purple (and Amsoil, same filter) are good, but costly.
Wix XP (and NAPA Platinum), are good filters, but lower efficiency than others.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Synthetic [Re: blupupher] #5235272 10/09/19 08:37 PM
B
bbhero Offline
B
Purolator Boss
Fram Ultra
Royal Purple
Wix XP
etc..
Very good analysis here ^^^^^^^^^
I would add that the real world difference in motor longevity with either a Napa Gold and Fram Ultra would be so miniscule that it would not be measurable or meaningful.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Synthetic [Re: Bettez88] #5235275 10/09/19 08:44 PM
Z
ZeeOSix Offline
Z
Depends on what people's definition of "best" is.
What's your main top 3 requirements for an oil filter?
Re: Synthetic [Re: bbhero] #5235279 10/09/19 08:50 PM
J
JLTD Offline
J
Purolator Boss
Fram Ultra
Royal Purple
Wix XP
etc..
Maybe. There's no test data. If someone wins the lotto we might see a test but until then.....
That said maybe we DO have data after all - millions of Toyotas going long distances on the OEM filter, which is 50% at 20 microns.
Lates.
Re: Synthetic [Re: JLTD] #5235307 10/09/19 09:38 PM
T
tundraotto Offline
T
Yes - maybe multi-pass efficiency is too overlooked. As the filter gets more clogged its efficiency goes up...but the bypass does not open. Wonder how quickly and often that happens on super tight mesh filters? Because - once the bypass opens, the filtering efficiency is 0%. This is why there's more to it than just the media. The bypass valve PSI and filtering media efficiency go hand in hand.
Re: Synthetic [Re: blupupher] #5235316 10/09/19 09:47 PM
B
Bettez88 Offline OP
B
Purolator Boss
Fram Ultra
Royal Purple
Wix XP
etc..
Is the ultra worth $14 when the Mobil1 is only $10 at Walmart? Which would filter better? And what about Mobil1 clones like the ecogard synthetic filter?
Re: Synthetic [Re: JLTD] #5235322 10/09/19 09:50 PM
Z
ZeeOSix Offline
Z
I think of engine wear due to dirty oil as a function of the average particle count (APC) level times how long the oil is ran during the OCI.
APC x OCI = Wear Index
APC could just be the average PC at 6μ and 14μ, or even the average of all 4 test points.
Example
(6μ PC + 14μ PC)/2 X OCI = Wear Index
A longer OCI drives the necessary for a higher efficiency oil filter to keep the partical level down since the time factor increases. In other words, if someone did 5,000 mile OCIs with a 50% @ 20μ filter, the level of wear due to dirty oil may be about the same as doing a 10,000 mile OCI with a 99% @ 20μ filter.
If someone changed the oil every 750~1,000 miles you might not even need an oil filter.
Higher efficiency oil filters became more available and more popular as the average OCI inreased.
Re: Synthetic [Re: bbhero] #5235416 10/09/19 11:41 PM
blupupher Offline
I agree, but I know some like to get all caught up in numbers, and while we don't know the exact specifics of Wix, we can get an idea from what they provide.
I know I ran nothing but Wix for many years without any issues related to filtration (and really, how often do we hear of issues caused by filtration problems)
What Ultra is $14 with a comparable M1 being $10?
I know for my F150 an XG2 is $8.97 and a M1-210A is $9.97. An Ecogard Synthetic S4651 is $6.82.
For the Soul, an XG9688 is $10.97, a M1-104A is $9.97. Ecogard S10479 is $8.34.
Maybe some of the cartridges are priced that way though. Not sure.
I think if your wanting a syn blend filter, just go with a cheaper Wix, Fram TG, or an Ecogard. No point in getting a M1 that cost more and does the same thing.
Re: Synthetic [Re: blupupher] #5235552 10/10/19 06:31 AM
B
Bettez88 Offline OP
B
All the filter you list last are all around the same cost for me. Fram tough guard is $6.82, ecogard synthetic is $7.78, Wix is 8.54, m1 is 9.97
I used to use Fram TG all the time when I was younger but the end caps turn me off.
Re: Synthetic [Re: Bettez88] #5235696 10/10/19 09:26 AM
K
kschachn Offline
K
But then again, the only end cap separation photos we have seen on here have been metal caps. I used to think metal was better but now I don't. Now it's either fiber ones or no caps at all.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Synthetic [Re: Bettez88] #5235717 10/10/19 09:48 AM
K
kstanf150 Online Content
Online Content
K
I’ve never used a Mobil 1 filter
Never heard anyone here complain about em so I just might try one next oil change
Re: Synthetic [Re: kstanf150] #5235828 10/10/19 11:46 AM
JohnnyJohnson Offline
I have used them on both my DuraMax and the Corolla. But frankly I've seen nothing that makes me
believe they work any better than a Fram TG. I've done C & P's on both of them. My vehicles are never going to
see over 7500 mile OCI so to me the TG is just as good.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
